996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
Daniel
2000 Porsche 996 GT3 Mk1
PostPosted: Thu Jan 29, 2009 10:51 am    Post subject: Gen 2 997 3.8 litre 435 bhp GT3 (video, pics and report) Reply with quote
435 horsepower and 317 ft-lbs of torque
Open Youtube Page
Power comes from an enlarged version of Porsche's naturally aspirated flat-six engine which now comes in at 3.8-liters and boasts 435 horsepower and 317 ft-lbs of torque. This allows the GT3 to sprint from 0-60 mph in 4.0 seconds and reach a top speed of 194 mph. Compared to the current GT3, the new model features an additional 200cc in displacement which helps to create the extra 20 hp.
Quote:
Following the release of the facelifted Porsche 911 Carrera and Carrera 4 models late last year and the new Targa, come the first details and images for the updated 911 GT3. Porsche has continued its tradition of only implementing minimal changes to the styling of its race-bred GT3, opting to focus on changes taking place under the revised sheet metal instead.
For the 2010 model year, the GT3 has been given more power, better handling, and a slightly higher base price. Following a world debut at March’s Geneva Motor Show, the updated car will go on sale in the U.S. this October at a price of $112,200 (without taxes), while Europeans will get it this May at a price of €116,947 (without taxes).
Power has been boosted by 20hp (15kW) over the outgoing model, with the car’s naturally-aspirated flat-six engine now pumping out 435hp (320kW). Changes to the powertrain include a larger 3.8L of displacement, as opposed to the former’s 3.6L, as well as an updated VarioCam system that adjusts both the intake and the exhaust valves for the first time. Engineers also focused on boosting torque levels at medium engine speeds. The end result is a 0-100km/h sprint time of 4.1 seconds and a top speed of 312km/h.
To improve handling, engineers have modified the PSM stability management system to allow more flexibility - offering the option to deactivate both Stability Control (SC) and Traction Control (TC) in separate steps. To give the driver maximum control, these functions are not reactivated automatically even under the most extreme driving conditions, but only at the touch of a button.
The new GT3 offers even better grip and stability also at high speeds, specific modifications of the car’s aerodynamics increasing down-forces both front and rear to such an extent that the overall pressure pushing down the car is more than twice as great as on the former model. At the same time the new aerodynamics package gives the GT3 a brand-new look further accentuated by the new bi-xenon headlights, LED rear light clusters, as well as modified air intakes and outlets.
To improve handling further, engineers increased the stiffness of the springs and anti-rollbars using the electronically controlled PASM active suspension management. New lightweight wheels have also been fitted and within these are an uprated brake system with larger carbon-ceramic discs and new aluminium covers.
Later this year, the GT3 will be available with a set of newly developed PADM (Porsche Active Drivetrain Mount) engine bearings. These special engine mounts automatically recognise hard-style driving, and adjust the normally elastic engine suspension and bracing to a firmer setting.
Finally, the GT3 will also be available with an optional lift system for the front axle that raises the ground clearance of the car up to 30mm, allowing drivers to tackle pesky speed-humps and steep driveways without any nasty scrapes.
Open Youtube Page
*Current - GT3 996.1 Clubsport (Manthey K400)
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Cayman 3.4 S 987.1
EX Megane R26R #36.
EX Cayman R
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Thu Jan 29, 2009 11:36 am    Post subject: Reply with quote
Quote:
Porsche builds the GT3 for a few thousand die-hards to show it still knows how to build a world-beating sports car
by Andrew Frankel
For one of only a very few times in its history, the Porsche 911 is under attack. The new version of the world’s most enduring sports car has been criticised for being less fun, less characterful and less like a 911 than any previous incarnation. And rightly so: the new 911s are fast, quiet and supremely easy to live with, though the price paid for that civility is a loss of the “old magic”.
However, anyone concerned that Porsche has forgotten how to make a car should stop worrying, because I’ve just driven the most exciting production Porsche road car of the past 35 years. It is the fourth 911 in a decade to wear the GT3 badge and it is the product of a band of delightfully unhinged engineers from Porsche’s motor sports division.
This is a 911 from the dark side. It squats malevolently outside the Porsche head office, all wings, slats, scoops and spoilers, none of which is there to look pretty. They develop downforce so that, bizarrely, the faster you drive the car, the heavier it becomes, air pushing it into the tarmac to generate cheek-rippling cornering grip. It actually develops five times more downforce than its predecessor.
Every significant change — and there are too many to mention here — has been made to make the car faster and better to drive. Unlike with everyday 911s, there hasn’t been even the slightest concession to making it quieter, more comfortable or better looking.
The engine has gone from 3.6 to 3.8 litres and has been given a further 20bhp, making 435bhp. Suspension is stiffened, the brakes are bigger and the transmission gearwheels have been lightened, while the seven-speed double-clutch transmission that’s now in lesser 911s was ruled out because it would add 66lb to the car’s weight. Mass is the greatest enemy of a car such as this, and every ounce that can be saved, has been saved. Besides, even changing gear manually, the GT3 will still scorch to 62mph in just 4.1sec.
This car is so extreme that, for no extra cost, Porsche will build you a Club Sport version complete with a roll cage, fire extinguisher and ignition cut-out — the basic safety equipment required on any modern car that is to be raced.
Despite the GT3 being a fully qualified track car, surprisingly, it’s an easy car to drive daily on the public road. The ride is better than, say, that of a Mini Cooper S, and because the engine is behind you, much of the noise gets left behind you when you’re cruising. And while its thin, racing bucket seats may look spartan, they actually offer more support than conventional seats, and are comfortable over even long distances. As long as you don’t need rear seats, you could happily commute in this Porsche; and then, just occasionally, you’d find a very quiet road or, much better, a racetrack. There you’d find an engine that revs to 8500rpm, and acceleration that is simply shattering. But, compared with the way the GT3 slows and goes around corners, that performance is probably the least remarkable aspect of the drive. Then there are the amazing brakes: a brick wall would scarcely slow the car any more effectively than these, and thanks to the downforce and tyres that look to be related to Formula One slicks, cornering speeds are almost incomprehensible.
Get used to the GT3, though, and you wonder why other performance cars just don’t feel as alive or in tune with their drivers. The GT3 really knows no equal, even allowing for the quicker yet less enjoyable 911 GT2.
It’s hard to think what true rivals it actually has. A Ferrari Scuderia is closest in concept but costs more than twice as much; and, according to Porsche at least, is slower around a track. A Lamborghini Gallardo is too soft, a Lotus
Exige is too impractical, and now that Nobles and TVRs are unavailable, it is probably the Bath-built Farbio GTS350 that comes closest to matching the GT3 for its blend of pace, practicality and price. But I would have the GT3 over the lot of them, irrespective of cost; it’s not a car to drive for a few years and then discard, it is a car to keep and enjoy for as long as your means allow.
Also, it proves what I have long suspected, that Porsche has quite deliberately made the standard 911 less focused because most of its customers buy for the badge and would rather have a more user-friendly car to drive.
Porsche builds the GT3 for just a few thousand die-hards to show the world that it still knows how to build a world-beating sports car, and that it’s still at the top of its game. But just how good is this latest 911? Well, there really is only one way to find out, and that’s to drive one for yourself.
Porsche 911 GT3
Engine 3797cc, six cylinders
Power 435bhp @ 7600rpm
Torque 317 lb ft @ 6250rpm
Transmission Six-speed manual
Fuel/CO2 22.4mpg / 298g/km
Acceleration 0-62mph: 4.1sec
Top speed 193mph
Price £81,914
Road Tax band G (£400 for a year)
Verdict Porsche’s greatest road car
On sale September
http://www.timesonline.co.uk/tol/driving/new_car_reviews/article6161942.ece
I like that.
The SC and TC function is taken from the 997GT2 IIRC, saw it on 'Jay Leno's Garage'...
The raising the front is a good idea but kind of detracts from the point of a GT3, that it's a hard core 911. I'm not complaining but isn't it turning it way too much into a 'daily driver' than an 'event'? Question
Disco
2010 Porsche 997 GT3
PostPosted: Thu Jan 29, 2009 11:41 am    Post subject: Reply with quote
Stuart wrote:
I like that.
Dunno - if it is any lower you would need it to get into Donnington without scraping the splitter Confused
Colin
Daniel
PostPosted: Thu Jan 29, 2009 11:46 am    Post subject: Reply with quote
I think you have hit the nail on the head there Stuart !
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Megane R26R #36.
EX Cayman R
wizard993
1966 Singer Gazelle
PostPosted: Thu Jan 29, 2009 1:01 pm    Post subject: Reply with quote
....those torque figures don't look too impressive
The 996 GT3 ran 285 lb of torque with 380 BHP only an extra 32lb feet for 55BHP on the latest car is a bit on the lowish side....I had expected more as torque is a primary factor for helping to fire/slingshot a GT3 out the corners Surprised
Just wondering if the emission regs are playing a part somewhere on the 997 GT3 or is the GT3 going just a tiny little bit softer now?.
How heavy is this car now?
"The smallest feline is a masterpiece"
- Leonardo da Vinci
ResB
PostPosted: Thu Jan 29, 2009 1:22 pm    Post subject: Reply with quote
Oh no...my OPC rang me this morning but I missed the call....wonder what he want!! wack
edit
I hope the UK price isn't based on the current exchange rate as that would mean the new GT3 will be over £107k or am I just being a bit thick...
I see dead pixels.
kryten
PostPosted: Thu Jan 29, 2009 1:44 pm    Post subject: Reply with quote
£81,914 inc VAT according to official site
Wife just told me to stock mucking about and "just bloody order one" so I have Wink
Waiting to find out likely delivery but may not be until 2010 Sad
bigu
PostPosted: Thu Jan 29, 2009 2:53 pm    Post subject: Reply with quote
Here is some more high resolutions pics for your desktop: Posche 911 Wallpapers
Bubbles
1999 Porsche 996 Carrera 4
PostPosted: Thu Jan 29, 2009 3:53 pm    Post subject: Reply with quote
Can I please marry your wife as well Smile
Cayman S Gen II PDK
Audi A4 Avant for work
Wife & Daughter's VW Up!
bigu
PostPosted: Thu Jan 29, 2009 3:59 pm    Post subject: Reply with quote
I'm too Very Happy
kryten
PostPosted: Fri Jan 30, 2009 8:48 am    Post subject: Reply with quote
Hehe, NO!
Anyway she's off to London with a mate next week and I fear there may be a significant Louis Vuitton and Tiffany/Boodles 'adjustment' made because of the order...
ResB
PostPosted: Fri Jan 30, 2009 1:42 pm    Post subject: Reply with quote
Yup,
The OPC want £10k deposit, September delivery, But can't guarantee I'll get one if I order it...lol....Oh, okay, I'll give you £10k to sit on whilst you figure out how to tell me I can't have one. B*****ks to that....
I see dead pixels.
Porsche
2003 Porsche 996 GT3 Mk2
PostPosted: Fri Jan 30, 2009 11:06 pm    Post subject: Reply with quote
Open Youtube Page
Porsche on Youtube!
964 Project Car
996 MK2 GT3 CS Manthey
993 Targa
kryten
PostPosted: Sat Jan 31, 2009 8:47 pm    Post subject: Reply with quote
Apparently, Porsche haven't confirmed delivery numbers or dates which is why the dealers can't give you any more info.
From what I've been told, deposit now will get you a car ok, but no guarantee of dates - could even be 2010!!
The deposit just books your place in line Sad
Big Bob
PostPosted: Sun Feb 01, 2009 12:31 pm    Post subject: Reply with quote
THE BASTARDS
I just get my 997 GT3 and they bring out a NEW GT3. The BASTARDS!!!!
Big Bob
wizard993
1966 Singer Gazelle
PostPosted: Sun Feb 01, 2009 2:06 pm    Post subject: Reply with quote
I think if I was in "the big" mans shoes I'd be rather miffed about this too!
Anyone know what this latest GT3 tips the scales at?
- Leonardo da Vinci
ResB
PostPosted: Sun Feb 01, 2009 2:16 pm    Post subject: Reply with quote
Unladen Weight (DN) - 1395kg
Unladen Weight (EC) - 1470kg (Inlcudes 68kg Driver and 7kg luggage)
I see dead pixels.
Big Bob
PostPosted: Mon Feb 02, 2009 10:15 am    Post subject: Reply with quote
Having got over the initial irritation Sad , that I moved from having the latest GT3, to having "the old model" Evil or Very Mad , I've done some "corporate" thinking Question .
It perhaps is more a reflection on the current difficult trading conditions for all car manufacturers Sad , including Porsche.
Bearing in mind the planned run of the original 997 GT3 sold out pretty quickly, and faced now with low order books on all the other more "production models" then to offer a new GT3 which might keep the production lines turning over, is eminently sensible, assuming the new edition attracts the same purchasing interest as the first Question .
Anyway since my GT3 tipped the financial scales originally 8000+ miles ago at £92K, I wont be changing. However I'm investigating how I might achieve the same power outputs without the cost of replacing the car food food
Regards Big Bob
gary h
PostPosted: Mon Feb 02, 2009 11:30 am    Post subject: Reply with quote
Hey Bob, I got my 997 GT3 in September and am still loving it thumbsup
Im sure the mk2 will be a fantastic car, but the one we have is truly the dogs b******s, the mk2 will have to be really special to top it in any significant manner. Just enjoy it fellah.... Very Happy
g
Oh, I prefer the rear valance on 'our' car Thumb
Big Bob
PostPosted: Mon Feb 02, 2009 12:11 pm    Post subject: Reply with quote
No worries Gary. It does not stop me enjoying every second in the car Smile
Glad though I did not have to use it in the snow today thumbsup
Best Regards Big Bob bye
