997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
Tycho
1995 Porsche 993 Carrera 2
PostPosted: Thu Feb 06, 2020 10:41 pm    Post subject: Power Steering Lines Reply with quote
I have recently got an early Boxster (1998) to keep me occupied during the winter. The last big job is the power steering pipes, pressure & return, pump to rack. The ones on my Boxster are showing their age & have suffered from missing / damaged undertrays (also being addressed). New Porsche ones are rather pricey & I have seen mention of getting lines made up by a hydraulic hose company. I have phoned round a few without success – they seem want to any originals to copy and my mechanic mate thinks that won’t work as mine are too bent out of shape.
Has anyone had any success replacing these pipes? I will put something on the 996 forum as I believe that they are pretty similar.
kurlykris
PostPosted: Thu Feb 06, 2020 10:51 pm    Post subject: Reply with quote
Are you talking about the steel lines on the rack or the hydraulic hoses from the pump to the front of the car ?
There is a company in Coventry that make the steel lines for the rack for around £50, I believe they are in Balsall Common, but I don`t the name of the company. If it`s the hoses, then I use a hydraulic hose company with my work, thay are called Pirtek and have mobile vans all over the UK Thumb
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
Tycho
PostPosted: Thu Feb 06, 2020 11:04 pm    Post subject: Reply with quote
It’s the back to front pipes I am after. I have phoned my local Pirtek & they said they needed good lines to copy in their workshop. I was hoping they could do something mobile but they did not seem keen.
kurlykris
PostPosted: Thu Feb 06, 2020 11:09 pm    Post subject: Reply with quote
Hmmm, that`s strange as in all the years I`ve been using them, they have come to site every time, I have never been to a Pirtek workshop/branch nooo
Can you pop the pipes off and take them to them or is that not possible Question
I would try another branch and see what they say Grin
Tycho
PostPosted: Thu Feb 06, 2020 11:29 pm    Post subject: Reply with quote
Thanks, I will try another branch, there are another couple in the area.
kurlykris
PostPosted: Thu Feb 06, 2020 11:39 pm    Post subject: Reply with quote
I`m a little bit confused Tycho, is it the hard lines back to the pump from the front that run under the car that are damaged or just the hoses where they join the hard lines Question
If it is the VERY common issue of where the hard lines join the hoses at the front of the car in the drivers side wheel arch then it is an easy fix !
The Alloy Ferrule on the hose corrodes and eventually lets go, the widely used fix is to put 1 ( or as I have done placed 2 ) small jubilee clips round the pipe and just pushed it back to it`s proper position and tightenned them up Grin
Tycho
PostPosted: Fri Feb 07, 2020 10:38 am    Post subject: Reply with quote
It’s the hard lines. I have done a lot of reading in the past few days & seen the jubilee clip fix mentioned – glad to hear that it works.
My mechanic mate tells me that these hard lines are been knocked around / bent out of shape in the past so that they are no longer fit into the support clips. He has a really practical approach but is wary of just trying to bend them back and causing worse damage. I am thinking that I may be making too big a thing of this but now I know I have a potential problem my usual approach is to get it fixed up front. I will have another chat with him, if the lines are sufficiently sound the pragmatic thing might be to just improvise some more supports.
Thanks for your help.
sim996
PostPosted: Fri Feb 07, 2020 11:09 am    Post subject: Reply with quote
Had the same problem. Didn't like the idea of a bodge job, so I stumped up the cash for proper replacements. Was about £2k all in, including dropping subframe and rack to get old pipes out that had welded themselves in!
Get it done properly however you decide.
Tycho
PostPosted: Mon Feb 10, 2020 7:36 pm    Post subject: Reply with quote
Quick up-date, managed to get my hands on some used lines in A1 condition at very good price. Also picked up 3 of the 4 undertrays I need. Still trying to get the back under engine tray, looks like it will be OPC for that one.
Thanks for the help.
sim996
PostPosted: Mon Feb 10, 2020 8:10 pm    Post subject: Reply with quote
Good man! You'll enjoy it more with proper parts. Just make sure it's the right lines, there are I think 3 or 4 different versions.
I'm going to fit the 997 rear triangle to the back of the rear undertray too, offers a bit more protection.
Tycho
PostPosted: Mon Feb 10, 2020 8:28 pm    Post subject: Reply with quote
Just when I think I have finished! What is the 997 rear triangle & do I need it! I have already got a rear axle protective plate (98633116301) ready to fit in the next phase. There is one on the car at present but its a bit bent, looks like it might have been used to lift the car.
