997 : 2004- 58
Boxster : 1997- 27
Cayman : 2005- 22
Stoddy
PostPosted: Mon Jan 13, 2020 1:48 pm    Post subject: Aaarrrggghhhh!! Found a new leak!!!! Reply with quote
Howdy,
OK, nearly fed up with fettling my motor now.
Top mounts and shocks being replaced due to corrosion on the top collar, allowing the shock to slip upwards on one side.
Now found another leak as condensation wasn’t going after repairing the drivers door seal.
I poured some water down all the sunroof drains, and this happened! Yet, water still appeared to drain out in all the right places.
Am I missing something?
Hope someone can help?
Cheers,
Stoddy Dont know
The world is flat
2005 997.1 3.6 (Rufus -THE DUKE)
2002 996 3.6 C2 (Henry) For sale.
Restoring THE COLONEL, 1973 914.
X 944 S2 Cab (Miller)
X 3.2 Carrera (Gordon)
X 3.4 Cayman (George)
 Filesize:  119.84 KB
 Viewed:  1356 Time(s)
Stoddy
PostPosted: Mon Jan 13, 2020 1:49 pm    Post subject: Reply with quote
And here!
The world is flat
 Filesize:  117.83 KB
 Viewed:  1353 Time(s)
jl-c
PostPosted: Mon Jan 13, 2020 4:29 pm    Post subject: Reply with quote
Looks to me as both rear sunroof drains have come adrift. No idea how to fix it, sorry! Dont know Cue DeMort I think!
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Jan 13, 2020 4:42 pm    Post subject: Reply with quote
Loose drains may also explain the rattle you've reported previously... maybe an opportunity to kill two birds with one stone by taking the headlining off and having a look at what's adrift.
Anyway, hope you get the car sorted after this tricky honeymoon period!
Stoddy
PostPosted: Mon Jan 13, 2020 5:27 pm    Post subject: Reply with quote
Thanks man,
I actually went ahead and took the headlining off the back and found both drain fixings well and truly in place. I then repeated the water pour and realised I was pouring way too much in and it was going over the drains and in to the car!!
I guess they’re only meant to deal with the tiniest trickle, as if it was pouring with rain, you wouldn’t have the sunroof open! Floor so the sunroof seal itself, will only let a tiny bit in. Maybe that needs replacing?
As you say, when in there, I found a piece of black trim that runs from one side to the other of the back of the sunroof panel. It was very slack and rattles agains the sunroof panel it’s self, so, some single sided foam added to said panel and.............fingers crossed!
The door seal however seems to still leak, as the carpet just doesn’t want to dry out, I guess I can test this by removing the inner panel and pouring water against the glass and watching the bottom of the door.
OR I COULD JUST MOVE TO A DRYER BLOODY COUNTRY!!!!!!! Sick of this rain now.
Still don’t know how the rear carpet is still damp?
Thanks for the info.
Stodd thumbsup Dont know
The world is flat
Robertb
PostPosted: Mon Jan 13, 2020 6:52 pm    Post subject: Reply with quote
Floor
Do 997s have the same leaky door membranes as 996s?
Stoddy
PostPosted: Mon Jan 13, 2020 7:00 pm    Post subject: Reply with quote
Robertb wrote:
Floor
Never had a single leak in my 996. Sad
The world is flat
Robertb
PostPosted: Mon Jan 13, 2020 7:41 pm    Post subject: Reply with quote
Stoddy wrote:
Robertb wrote:
Floor
Me neither, in either of my 4Ss...
PostPosted: Mon Jan 13, 2020 8:10 pm    Post subject: Reply with quote
Oh Dear .. i thought it would be a while until i was answering another post from you Sad
Ok .. shocks first .. get .. i assume you have ? your garage to have a good look at the suspension and prove it needs new front shocks , mounts etc ..
The car seems to have no problems and is in spec on a geo .. i don't like money being spent when its not needed to be honest ... advice from your garage to say there is a fault which will cause a problem basically .
Your leak is a little unusual .. i would guess you poured rather a lot of water in there .. the sunroof seal stops most water ingress so these are not designed to handle large volumes of water .
It seems to be you may have a partial blockage of the rear drains ..
If i had the car .. i would remove the drain tube .. stick an airline down it to blow it out ... a partial blockage i think .
I would then tell you to stop pouring water down it !!!
Sometimes honesty is the best policy .. this i surmise is one of them .
lets just say i have never seen a wet head lining before like this ... 15 years so i pre date this model ... just about Wink
The rear carpet you have a red circle around .. if you lift this in the center you can pull it out to check for water in that area .. long term leak and there will be a puddle of water under the dme ( engine control unit ) .. lift the carpets at the back .. just behind the rear seat base .. is it damp ?
If not then the leak is minor .
I get the feeling we might need to chat on the phone .. happy to oblige , ill pm my number if you want .
Indy Mechanic .
Robertb
PostPosted: Mon Jan 13, 2020 8:27 pm    Post subject: Reply with quote
Do you definitely need new shocks? My ‘03 4Ss shocks were recently given a clean bill of health by Center Gravity’s test rig at 116k miles, last a lot better than many think apparently.
Stoddy
PostPosted: Mon Jan 13, 2020 10:20 pm    Post subject: Reply with quote
I’m beginning to wonder. I’ll try and speak to them
in the morning,
Thanks! thumbsup
The world is flat
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Jan 14, 2020 12:01 pm    Post subject: Reply with quote
They all rust at the top, and most mot places would mark it as an Advisory, however it is not unsafe and they do not need to be replaced. This section of the piston cannot possibly ever contact the shock body. It sounds like you are not using a company familiar with Porsche’s?
Stoddy
PostPosted: Tue Jan 14, 2020 2:03 pm    Post subject: Reply with quote
THE DUKE is at Centre Gravity, already identified a bent top mount, full inspection to be done of course but a good start!
Thanks for all the messages.
Stoddy. thumbsup
The world is flat
Robertb
PostPosted: Tue Jan 14, 2020 2:45 pm    Post subject: Reply with quote
Excellent! I bet you'll be surprised when you see their geo read-out of your car.
Stoddy
PostPosted: Sat Feb 08, 2020 8:51 am    Post subject: Reply with quote
Centre Gravity are awesome. Car feels 100% planted now.
The guys there are super friendly and enthusiastic, but above all, their knowledge is unbelievable.
The car felt a bit twitchy when I got it, under steering and a couple of intermittent rattles, nothing that made it bad to drive, but lacked something that my 996 had.
After Pete at CG got his hands on it, the car was transformed in to a weapon!
New Eibach Lowering Springs, new lower ball joint, new top mounts, bearings and stoppers, toe arm, and a pair of front discs ( the car came with skimmed discs which were below the minimum thickness recommended but looked new to me!) Bit naughty of the garage that one.
Anyway, I’ve done a couple of runs up my favourite road, ie, driven from South Wales to Manchester via the A470 a couple of times and it’s just amazing!
Can’t wait for my sports exhaust, new speakers and Red centre console now!
I can’t recommend CG enough.
The world is flat
 Filesize:  378.24 KB
 Viewed:  345 Time(s)
