997 : 2004- 60
Boxster : 1997- 27
Cayman : 2005- 22
PostPosted: Tue Mar 17, 2015 7:39 pm    Post subject: Starter Motor screech - cured (hopefully) Reply with quote
My starter motor has been screeching for the last 3 months or so, so with the weather being ok this afternoon, I thought I'd have a bash at sorting it out.
It was doing this half the time:
Open Youtube Page
So I whipped it out, gave it a clean and some grease and back in. Time will tell if I've managed to cure it but as yet it seems fine.
Couple of pics and a how to below:
First disconnect the battery (with the key in the ignition to prevent alarm sounding) as the starter has a live direct to it.
Then start stripping all the parts out that are in the way, firstly the airbox. Disconnect the MAF sensor and undo the jubilee clip to the throttle body before removing the box (clamped in with one bolt in the middle at the front/back of the box).
Then disconnect the AOS air pipe from the plenum and power lead from the throttle body before undoing the 4 screws holding the body on (the bottom left one also has a clamp on that supports the body to the engine as well as the intake plenum, although mine was sheared off).
Before removing the plenum, undo the inner jubilee clips and rotate the plenum to break the seal.
Then re-tighten and do the same with the outer clips. Once all seals are cracked, undo all 4 jubilee clips and push the rubber pipes outwards away from the plenum. It can then be wriggled out.
Once removed you can see the starter motor.
Disconnect both earth lead and power lead from the soleniod.
Now remove the 2 bolts holding the starter motor on (the one on the right that's visible was quite easy, the one out of sight a bit of a mare).
At this point, job ground to a halt because my 1/2" to 3/8" reducer snapped nooo
So I had to nip up to my Dad's and rob his socket set whilst he's on holiday. At this point, the job became a bit harder as I had to use to 3/8" extensions and they weren't long enough so I was limited on access, but managed to get the other bolt out (and graze my hands!)
The other bolt is hidden in the depths of this photo (note I removed the LH rubber intake pipe to give myself more access) .
The starter just slides right out then.
Didn't look too dirty when I removed it and was a bit surprised as I thought it would be caked in clutch dust.
Gave it a good clean up and pulled the bendix drive out and applied some silicone grease round it. Whipped the cover plate off the back too and greased that end.
Put it all back together in reverse order, fired it up a few times and as yet, not a screech so hopefully cured it, but time will tell.
Was going to strip the solenoid down but the bolts holding it in are well and truly rusted up so left that for another time if need be.
Now to order myself a new reducer for my socket set.
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Tue Mar 17, 2015 9:32 pm    Post subject: Reply with quote
Nice work, Alex.
Mine tomorrow, or sometime this week.
Or next.
Harv
PostPosted: Tue Mar 17, 2015 10:08 pm    Post subject: Reply with quote
Top work!
It's really burried in there isn't it. Did the bearings look dry?
Mine seems to really spin the engine over well since I cleaned and greased the bearings, also worth removing and cleaning the engine to chassis ground strap located in the o/s rear wheel arch area.
PostPosted: Tue Mar 17, 2015 10:31 pm    Post subject: Reply with quote
It was a bit dry in the back end under the cap at the back so I cleaned that out and applied fresh grease. I was surprised how clean the bendix drive was and how free it moved. A cleaned all the gear up and greased the drive so hopefully the screech is no longer with us.
It was getting right on my moobs!
PostPosted: Wed Mar 18, 2015 10:25 am    Post subject: Reply with quote
Read out of context, the post above could take on a whole different meaning Sad
Friends
Devil
PostPosted: Wed Mar 18, 2015 10:32 am    Post subject: Reply with quote
I'm from Lancashire, not Yorkshire. wack
saddlepunk
PostPosted: Thu Mar 19, 2015 10:54 am    Post subject: Reply with quote
Really interesting and informative - thanks. Mines been screetching on and off for a couple of years! Now I know what to do.
1998 C2 Coupe
PostPosted: Thu Mar 19, 2015 10:57 am    Post subject: Reply with quote
I've had 2 freezing cold mornings now with the car iced over - the starter did seem to screech more in cold weather.
I've tried it throughout the day since doing the job and as yet screech free.
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Thu Mar 19, 2015 2:49 pm    Post subject: Reply with quote
Nice one Alex!
paul987
PostPosted: Tue Jan 12, 2016 3:09 pm    Post subject: Reply with quote
Mine has started making exactly the same noise as this on and off over the last couple of weeks. Question
So are you still screech free Alex? I'm thinking of having a bash at it sometime this month Thumb
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
PostPosted: Tue Jan 12, 2016 3:15 pm    Post subject: Reply with quote
Was just checking the date - wow, last March. Yes it is still screech free and has never made a single screech ever since doing the job. At the time I thought there's no chance I've cured this as the starter motor didn't even look dirty, but it's been fine since so must have done.
thumbsup
Cheap fix. I was reading rennlist earlier and their advice on it was fit a new starter Surprised Grin
paul987
PostPosted: Tue Jan 12, 2016 3:38 pm    Post subject: Reply with quote
Thanks Alex Good man Thumb
And still screech free after all this time it's definitely worth me giving it a bash.
Thank mate
worship
PostPosted: Tue Jan 12, 2016 4:00 pm    Post subject: Reply with quote
We're all in it together mate thumbsup
Mike!
PostPosted: Wed Jan 13, 2016 7:51 am    Post subject: Reply with quote
Mine does the same thing but only when hot. After a 10 mile + drive and stopping for fuel then starting the car 5 mins later.......It's on my list of things to do.
PostPosted: Mon Feb 20, 2017 7:15 am    Post subject: Reply with quote
Two years on and still perfect.
Kingb4
PostPosted: Sun Feb 25, 2018 8:55 am    Post subject: Reply with quote
Sorry for dredging up an old thread, however I also have this noise, so will have a go at greasing the starter motor.
Really appreciate the photos - will make life a lot easier.
Alex - You mentioned stripping the starter down, while you had it on the bench. Is it pretty obvious what's needed, when you have it out of the car?
Ben
martylennox
PostPosted: Wed Feb 05, 2020 6:04 pm    Post subject: Reply with quote
really helpful thread, im gonna get stuck into mine later this evening!
thumbsup
996.2 C4s in Lapis Blue
986 Boxster S 550 Anniversary, in GT silver
ex 968 in Guards Red
ex Mk 1 Golf GTI
ex Pug 205 1.9GTI phase 2 in Cherry Red
ex Pug 205 1.9GTI phase 1.5 in Sorrento Green
daily hack; VW Amarok Highline auto
