997 : 2004- 60
Boxster : 1997- 27
Cayman : 2005- 22
Marmoset
PostPosted: Thu Jan 30, 2020 1:02 pm    Post subject: DIY Litronic sensor arm Reply with quote
As part of the winter preservation project on my car I needed to replace the front sensor arm for my litronic headlight level sensor. I was stunned to find out that the part is close to £50. Not really wanting to spend that on something that simple I set about looking for alternatives.
Ideally I would have liked to use nylon and brass ball joint to keep weight down but couldn’t find any with boots on.
I eventually bought some metal/nylon ball joints(Ref AMG6) off eBay for £6 apiece and then a couple of pounds on m6 stainless rod and nylock nuts.
It weighs about twice as much as the original but should be a bit more serviceable as well. This will also work on the rear with a longer length of rod.
1999 996 Carrera 4
 Filesize:  672.64 KB
 Viewed:  512 Time(s)
 Filesize:  869.15 KB
 Viewed:  512 Time(s)
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Thu Jan 30, 2020 1:40 pm    Post subject: Reply with quote
Good idea... someone has bodged the rear one of mine with some cable ties, which could probably do with sorting properly.
Shalmaneser
PostPosted: Thu Jan 30, 2020 3:33 pm    Post subject: Reply with quote
If you wanted to go lighter and (probably!) more dirt resistant you could do worse than an IGUS rod end:
https://www.igus.co.uk/product/315
We use these a lot at work and one of the reps bought in the gear linkage for a 981 which is a moulded IGUS part.
Very light weight too, and not bad price either, actually.
205 GTI 2.0 16V - BMW E36 M3 Evo - BMW E46 M3 - Porsche 996 C2
Dammit
PostPosted: Thu Jan 30, 2020 4:44 pm    Post subject: Reply with quote
Something of a hijack, but hopefully close enough that you can forgive me:
I have litronics in a car that came with Halogens originally, therefore I don't have the level sensor and associated gubbins - if I got them from a wrecker/OPC are they hard to integrate, or is it all plug-in stuff?
Marmoset
PostPosted: Thu Jan 30, 2020 9:50 pm    Post subject: Reply with quote
I’m not sure, you’d have to check the wiring diagrams to see if the sensors feed a bcu which then tells the headlights how to set or if the sensors feed directly to the lights...
1999 996 Carrera 4
