997 : 2004- 56
Boxster : 1997- 24
Cayman : 2005- 22
Macca38
PostPosted: Tue Oct 15, 2019 9:31 am    Post subject: Reply with quote
Hi All
Relatively new to this forum so discovering old threads all the time. Read this one start to finish and have only seen one post from a Turbo 996 owner who said not to do Gundo hack on a turbo.
Anyone know of anyone who has done this on a Turbo as i'd like to change exhaust note on mine. Got a Europipe quote to be fitted at RPM and not much change from £4k.
Chris M.
PostPosted: Tue Oct 29, 2019 8:36 pm    Post subject: Re: Another option re gundo and banana Reply with quote
glenwells wrote:
James M-S wrote:
Les, I also have a Gen2 3.6 with crossover pipe. Did you go for conventional gundo, or the banana?
You have the blanked off second exit port nipple on the rear box. You cut that off then have a pipe taken from that port into the existing exit port. Use original size pipework and need to keep it tight in for easier refit. Also make sure you go into the correct pipe as they are different on gen 1 to 2 as Les informed me.
Effectively you are opening up the second exit port from the exhausts rear silencers.
It is personal, but to me a great improvement on original without sounding like a chavvy Tw*Tmobile - no backwards baseball cap needed. It is a little deeper at tickover and louder on higher revs, not dissimilar to cosha PSE.
I'm having this done as well but with a valve on the extra pipe.
C11BRA
PostPosted: Mon Jan 27, 2020 9:45 pm    Post subject: Reply with quote
My Gundo hack should happen on Friday. If things go to plan.
Follow the thread here http://911uk.com/viewtopic.php?t=137663
2006 997.1. Project GT3C. C stands for ???
2018 Audi A4 Avant Black Edition.
Ex 996 C2 Man.
Ex Ram Cobra V8.
Ex Series 1 RS Turbo.
Chris M.
PostPosted: Mon Jan 27, 2020 11:59 pm    Post subject: Reply with quote
Cool. Don’t do it like this, doesn’t sound good.
Valved hack
 Filesize:  104.23 KB
 Viewed:  703 Time(s)
C11BRA
PostPosted: Wed Jan 29, 2020 1:24 am    Post subject: Reply with quote
Hi Chris.
Do you mean. Don’t do it the way I’ve shown in my photo?
Or do you mean don’t do it the way in your photo with the pipe from the blanked off port?
Ex 996 C2 Man.
Ex Ram Cobra V8.
Chris M.
PostPosted: Wed Jan 29, 2020 1:35 am    Post subject: Reply with quote
C11BRA wrote:
Hi Chris.
Don't do it the way I did it. It changes the sound very little. You can't tell if the valves are open or closed. I am going to cut them out and re-weld them in the normal Gundo position which is what I recommend you do.
In the meantime I have a pair of the TopGear valved mufflers on the car right now and they sound great.
C11BRA
PostPosted: Wed Jan 29, 2020 9:01 am    Post subject: Reply with quote
Brilliant info. Thanks.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Tue Feb 04, 2020 12:30 am    Post subject: Reply with quote
After a catalogue of welding equipment failure, I finally have one side of the Gundo completed.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Sat Feb 08, 2020 5:35 pm    Post subject: Reply with quote
All completed and back in the car.
Absolutely blown away by the sound. I used 2” pipes & valves btw.
Ex 996 C2 Man.
Ex Ram Cobra V8.
Chris M.
PostPosted: Sat Feb 08, 2020 6:44 pm    Post subject: Reply with quote
Looks great. Got a sound clip?
C11BRA
PostPosted: Sat Feb 08, 2020 8:09 pm    Post subject: Reply with quote
Not yet. And how do I post a clip on here? More road testing in the rain tomorrow.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Sun Feb 09, 2020 4:04 pm    Post subject: Reply with quote
Try this.
https://youtu.be/eNebwi83xqA
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Thu Feb 13, 2020 10:54 pm    Post subject: Reply with quote
Ok. After a bit of head scratching (thanks to pins 12 & 13 on the switch pack being reversed vs the Porsche wiring diagram) I finally worked out the wiring and with a bypass on the circuit board, I finally got the Sport switch to activate the exhaust valves (GT3 style....kinda).
Road testing tomorrow.
Will post the DB test video soon.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Fri Feb 14, 2020 5:41 pm    Post subject: Reply with quote
With valves closed I did a DB test today. Approx 1 metre from the exhaust at 45 degrees.
https://youtu.be/YtSdVreclQE
Maxed out early at 102db. Very happy with that. Hopefully enough to pass 103/105 DB track day tests.
However, in Gundo 2” idiot mode. Well........
https://youtu.be/Pb8cbKhr0n8
Sounds incredible!!!!!
Ex 996 C2 Man.
Ex Ram Cobra V8.
aaron johal
PostPosted: Sun Feb 16, 2020 6:10 pm    Post subject: Reply with quote
Hey guys, I am really exited to get this done on my 997.1 C2.
I was looking to get 2m pipe. Has anyone had this done who lives near slough. Would love to have a listen to it before I get it done. There is always that worry.
Also can anyone recommend where to get it done close to slough?
chowgar
PostPosted: Thu Feb 20, 2020 6:06 am    Post subject: Reply with quote
Aaron, the majority of people get the 1.5" bypass done to their exhausts and it sounds perfect. If you go to large, the sound could prove to be overbearing and possibly fail track noise regulations. I had mine done at PCW exhausts and the guy is really good. He takes great care in doing the job and has done hundreds. He even replaces any rusted bolts with brand new stainless steel items. I had mine done last summer and it sounds phenomenal, compared to how it was from factory. Anyone would think this is how the car originally came.
Sound clips don't do it justice. You have to listen to it for real. But trust me it is well worth it and will be the best upgrade you will ever do to your car. I just kicked myself for not doing it years ago! It truly makes driving the car that much more fun.
https://www.exhaustmods.co.uk/
Sy
PostPosted: Mon Feb 24, 2020 9:28 am    Post subject: Reply with quote
Not heard a 2” mod, but I have the 1.5” done by PCW and appears to be a perfect balance.
He who dies with the most toys wins!
Goto page Previous  1, 2, 3 ... 18, 19, 20
Page 20 of 20
