997 : 2004- 63
Early 911 : 1964-1977 2
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
Counter Of Beans
PostPosted: Fri Jan 24, 2020 10:55 am    Post subject: 993 parts prices and other costs - ouch! Reply with quote
My late 1995 993 is, I suppose, an old car - 24 years old to be precise. I'm becoming aware of the costs involved in keeping it in really nice condition. And I don't mean perfect, concourse standard - I dread to think what "perfect" would cost! I also don't mean regular servicing either; you get that on any Porsche, ditto discs/pads/tyres.
For anyone considering a 993, mine is in good nick, has done 102k miles and has had 21 services but still needs the following doing, amongst other things:
*Chassis leg inspection and waxoyl (no corrosion present, thank goodness)
*Air con evaporator needs replacing (estimate £3k, yikes!)
*Handbrake cable is frayed + new shoes needed
*Varioram seal is weeping
*various bulbs in centre console need renewing
*oil cooler fan resistor replacement
*door seal (OEM Porsche price is crazy!)
*engine sound pad sagging
*brake caliper refurb
*SSK and Golden Rod to sort gearchange
*front seats could do with restoring
And that's before I ask Center Gravity to look at the suspension! Now, some of these things I can sort out myself - the door seal and the saggy engine sound pad for example. And I'm not complaining; it was my choice to buy an old car and these costs go with the territory.
I really just wanted to highlight, for anyone considering a 993 (or 964 I suppose) that if you want your car to be really nice there will be ongoing costs, most of which seem to be age related. I imagine as time goes by 996 and 997 models will incur similar costs?
Thoughts?
1995 993 C2 manual coupe. L39C Nacht Blue / Marble Grey, RSR's, 200 cell cats, FD Motorsports SSK + G/R, HID's, 996 steering wheel. Enigma Audio upgrade and sound deadening.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Jan 24, 2020 11:34 am    Post subject: Reply with quote
Seems like a pretty modest list for a 23 yr old car.
I liked the gearchange on my 993... I've always thought of it as a strong point to the car. Funny how times change.
I would explore the idea of replacing the aircon with an electric system which will save weight, power drain and could cost a similar sum.
Billy Bumpsteer
PostPosted: Fri Jan 24, 2020 11:35 am    Post subject: Reply with quote
Where on earth did the £3K for the aircon come from? Dont know
berni29
PostPosted: Fri Jan 24, 2020 11:38 am    Post subject: Reply with quote
Hi
With any older car it pays to be handy with a spanner for sure.
I would think that 997/991/992 will be a lot worse in this respect because of the pervasive electronics and lack of user serviceable parts.
Time will tell!
I think the 993 is a very reliable car. It had enough development time after all.
Berni
993 C2 Tip 1994 197k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris at CG.
Tobesetc
PostPosted: Fri Jan 24, 2020 1:15 pm    Post subject: Reply with quote
It's easy to buy a 993 and spend the same again over the course of a few years. But it's fun deciding which bit to do next then enjoying the "improvement"! You can't take the money with you when you go, so enjoy!
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Photos at TobesEtc.com (work in progress)
PostPosted: Fri Jan 24, 2020 1:22 pm    Post subject: Reply with quote
Hand the 993 are one of the cheapest classic cars you can buy Thumb
most of the costs you have stated you could spend (and much more) on an MG, MX5 etc.....the aircon evaporator is probably the least cost effective / most expensive jobs as although the part itself is cheap (a few hundre £ at most) it involves a full front end strip down to get at it ie its the labour cost as its a few days work..........it is very much the exception.
As with any classic car you can "choose" to spend as much as you like but in terms of "have to spend" the 993 is very much on the cheap side and espcially so as a % of value Wink
Counter Of Beans
PostPosted: Fri Jan 24, 2020 3:03 pm    Post subject: Reply with quote
To answer literally: Precision Porsche. Actually 3.3k! But, it's only an estimate, and they might be including a new condenser, drier, evaporator, expansion valve, labour and gas in that number. I've read that it's 12 hours plus for the labour, so that's £1200 for starters. I trust them to charge me fairly for the work done and they are reputed to be totally competent.
Counter Of Beans
PostPosted: Fri Jan 24, 2020 3:07 pm    Post subject: Reply with quote
So true. And it's what I've told myself; it's a hobby and we all know hobbies are expensive, right? Phil997 will be along shortly to remind me that you can spend a fortune of playing golf or something. Or at the hairdressers in my wife's case.........
Luddite
PostPosted: Fri Jan 24, 2020 4:43 pm    Post subject: Reply with quote
COB, I guess you can feel fortunate you ain`t running a 21 year old Ferrari, Lambo, Masser or others...? Old cars have their issues, and old sports cars are likely to have more than most...? While the 993 is not a basic bit of kit it lacks the extra complexity of water cooling and ever more digital controls and circuitry of the later cars, not to mention the other all to obvious issues... CORROSION is something to keep an eye on for the long term.
Parts pricing is one thing, availability can be quite another... Helping a pall with K-Jetronic similar to 911 SC, parts for that system are expensive if available, and dare I comment that a Ford Capri hardly seems worth the bother in my book.... though each to their own.. Question
Billy Bumpsteer
PostPosted: Fri Jan 24, 2020 4:44 pm    Post subject: Reply with quote
Shouldnt be more than £1500
Mike_993
PostPosted: Fri Jan 24, 2020 5:32 pm    Post subject: 993 cost of living Reply with quote
I enjoy the planning of what to do next, spent a lot over a few years on mine with suspension, bodyworks and brakes plus loads of other bits and pieces. Most parts from OPC with discount not silly money.
1995 993 C2.
Albionmuz
PostPosted: Fri Jan 24, 2020 5:57 pm    Post subject: Reply with quote
We use the same Indie and they are a very professional outfit. would you like to hazard a guess on the price of a 993 Targa door seal. As a Bean counter you might well want to sit down first!
I have found a non Porsche one for £193 which still sounds excessive to me, but Porsche want to charge is frankly OBSCENE
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
pietrzj
PostPosted: Fri Jan 24, 2020 6:04 pm    Post subject: Reply with quote
COB,
When you say "...sort the gearchange" Is that personal preference or are you having shift problems?
Endoman
PostPosted: Fri Jan 24, 2020 8:32 pm    Post subject: Reply with quote
I did the evap a couple of years ago with a fellow 993 owner and a/c expert.
It's a real pia but not beyond diy, if you have the time and patience. Cost less than £500, but then I do like tinkering. I have the varioram converion badge and the engine drop t-shirt. I used to race an MGA in the 70's and 80's same then, diy or pay.
At least if it goes wrong you've only got yourself to blame but good mechanics are gold dust and charge what they are worth.
Counter Of Beans
PostPosted: Fri Jan 24, 2020 10:50 pm    Post subject: Reply with quote
pietrzj wrote:
COB,
Hello pietrzj, it's two things really. One is that I find shifts from 2 to 3, or from 4 to 5 (i.e. lower left to upper right) a rather long throw, and would like to shorten them a little bit. The other is that it is currently a tad rubbery for my taste; I prefer something more mechanical, ideally more precise. I'm hoping the FD SSK + GR will achieve this. So it's personal preference really.
Apparently, Singer use the FD items in their cars, and if it's good enough for the mighty Singer, it's good enough for my humble 993!
Counter Of Beans
PostPosted: Fri Jan 24, 2020 10:57 pm    Post subject: Reply with quote
Hello Albionmuz, yes it seems that Porsche parts prices have rocketed recently, which I'm now coming to realise. The door seal on mine is worn on the driver side, and a new genuine 993 one is silly money for what is just a rubber moulding thingy. But you can get a 964 seal for £35 instead so I'll use that I think. It all adds up if you want to keep these cars in top condition.
Counter Of Beans
PostPosted: Fri Jan 24, 2020 11:01 pm    Post subject: Reply with quote
Thanks Billy, it's useful to have a number, cheers. I know the part itself isn't too expensive. I might give the indy a call on Monday and check why the estimate is so high.
Billy Bumpsteer
PostPosted: Sat Jan 25, 2020 8:33 am    Post subject: Reply with quote
964 door seals start at about £15, there are 993 aftermarket ones out there now for about £140, not seen them in the flesh though!. Evaporator in OEM flavour about £170, condenser £120, filter £30.
PostPosted: Sat Jan 25, 2020 12:43 pm    Post subject: Reply with quote
I can get you an evaporator supplier and fitted for less than £1k.
Parts are cheap enough as evaporator can be less than £100, condenser similar and receiver/drier and expansion valve c£50
Job can be done in less than 8 hrs and you can get away without fully removing the fuel tank
The game's afoot. It's time to put a bit of (Colini) stick about......"Shall I open her up Miss Jones and show 'em a clean pair of heels?" "Do you think that's wise Mr Rigsby this is a very old car"
ch3tman
1995 Porsche 911
PostPosted: Sat Jan 25, 2020 12:52 pm    Post subject: Reply with quote
Not sure about the Singer comment, but I have continually read positive words about the FD SSK + GR kit - have been contemplating it about it for some time. Their transmission mount seems good too! Shipping is reasonable but customs is a potential sting/issue/delay... Whilst a friend has offered to assist with UK arrival (thank you if you're reading) it's not fair to burden them with that task.
Anyone have the capacity to lead a UK Group Buy?? Very Happy
Photos | instagram.com/ch3tman
