997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
angryjonny
PostPosted: Sat Jan 11, 2020 11:49 am    Post subject: Routing a battery optimiser cable Reply with quote
Is there a best-practice for routing a permanent optimiser connection to the battery? If I’m going to leave the car a while I’d like to be able to pop the frunk, plug in the optimiser and lock it all back up again. But I’m not sure on the best way of routing an SAE cable to the battery so it does no harm to anything when in or out of use. Cheers.
997.1 C4S cabrio 2008
Magic919
PostPosted: Sat Jan 11, 2020 11:53 am    Post subject: Reply with quote
Use the scuttle area by the wipers.
997.2 C4S PDK
nickyg63
ive ran mine under the scuttle trim, it appears near the n/s hinge so the trunk is locked and i can still charge the car.
Thefinn
PostPosted: Sat Jan 11, 2020 1:15 pm    Post subject: Reply with quote
I have done the same along the scuttle, if you have a look through my thread it will give you a bit of a guide.
997.1 C4S CAB
angryjonny
PostPosted: Sat Jan 11, 2020 1:18 pm    Post subject: Reply with quote
Excellent - thanks all. Driver’s side would make things a shade easier but the battery position is a bit biased to passenger side and I haven’t quite got the reach. I’ve done the same as Nickyg for now.
PostPosted: Sat Jan 11, 2020 3:04 pm    Post subject: Reply with quote
Jonny, on the scuttle there are the two pop out sections where the fitting screws are ,if you use that then its not visible when not in use but easily pops off to connect the charger. if you want more details and pics PM member Monster as he wrote a thread about it a couple of years ago with pics . Thumb Thumb
PostPosted: Sat Jan 11, 2020 3:21 pm    Post subject: Reply with quote
Phil 997 wrote:
.............. if you want more details and pics PM member Monster as he wrote a thread about it a couple of years ago with pics .
The thread that monster contributed to is here.
---> http://911uk.com/viewtopic.php?t=124444&start=20&postdays=0&postorder=asc&highlight=charger
PostPosted: Sat Jan 11, 2020 3:55 pm    Post subject: Reply with quote
Nice one Terry , thats the thread with pics Thumb Thumb
