997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
toddy2
PostPosted: Fri Jan 10, 2020 4:00 pm    Post subject: MOT Failure - anti roll dust covers Reply with quote
Hi All,
Arrgh MOT failure (again) couple of points this year:
•Front Anti-roll bar ball joint dust cover no longer prevents the ingress of dirt both sides X 2 (5.3.4 (b) (ii))
•Offside Drive shaft joint constant velocity boot split or insecure, no longer prevents the ingress of dirt (6.1.7 (g) (ii))
I've seen a few threads regarding the ball joint dust covers but can't really see anything recent on whether they are available separately for the 996 4S - any suggestions greatly appreciated, along with best place for the driveshaft velocity boot (I'll do the pair)?
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
PostPosted: Fri Jan 10, 2020 8:42 pm    Post subject: Reply with quote
You need a new link rod im afraid .. a split in a suspension ball joint item is a failure .
Boots on their own .. i don't think so and i wouldn't bother to be honest .. the downside .. these are often seized in place and the link rod needs cutting to get it off the car .
Cut the rod ball joint end to leave the 17mm nut then airgun the hell out of it .
CV gaiters .. you always do the pair as you remove both .
ECP for parts .
Indy Mechanic .
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Jan 10, 2020 8:48 pm    Post subject: Reply with quote
The ARB drop links are cheap from carparts4less (offer on this weekend funnily enough) or ECP. A mate did mine for me while I peered over his shoulder, looked easy to fit, but it was a pain as DeMort says to get the old one off... I seem to recall he used penetrating oil and tapped the bolt with a hammer and it pinged out.
Mine failed MOT on CV gaiters too... my indy fixed it, so no idea on the cost of parts or how to do it.
toddy2
PostPosted: Fri Jan 10, 2020 9:15 pm    Post subject: Reply with quote
Thanks both, I start sourcing the parts. Just when I thought I was on top of the maintenance!
1968 911T
2002 996 4s
1988 944 (Sold)
Robertb
PostPosted: Fri Jan 10, 2020 10:08 pm    Post subject: Reply with quote
Our work is never done... it’s like painting the Forth Bridge!
DarthFaker
PostPosted: Sat Jan 11, 2020 3:08 pm    Post subject: Reply with quote
I had to do a CV boot last year, ceased bolts being the worst bit.
Drop links are usually easy enough, unless the rear ones they're a pig to get to without a ratcheting spanner.
But all doable by a home mechanic.
