997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Mon Jan 06, 2020 3:41 pm    Post subject: 997.2 Brakes Reply with quote
My discs have slight lip on the fronts and some corrosion to the inner surface of the rears and I have been getting some quotes. I guess I need Genuine Parts as under warranty and plan on renewing in two years time.
My question is do I need all these other parts other than just the discs and pads or am I getting quoted on £340.00+vat of parts not needed.
Front
1 x Brake pad fitting kit
1 x Brake pad sensor
4 x Brake pad damper plate
4 x Brake caliper bolt
4 x Brake disc screw
Rear
4 x Brake pad damper 30mm
4 x Brake pad damper 28mm
2 x Brake pad sensor
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Jan 06, 2020 5:08 pm    Post subject: Reply with quote
What's in the fitting kit? You have everything you need there apart from ceratec.
Do you not need 2x pad sensors for the front, or do they come in packs of two?
SGH
PostPosted: Mon Jan 06, 2020 5:16 pm    Post subject: Reply with quote
The additional parts are how they were listed on the quote I have had two quotes now one from OPC and one from Indy.
Robertb
PostPosted: Mon Jan 06, 2020 5:23 pm    Post subject: Reply with quote
Looks like all you need is listed, apart from the discs and pads obviously. You do need two wear sensors per axle though, IIRC.
If you are a Porsche Club member, your OPC may give you a discount.
Magic919
PostPosted: Mon Jan 06, 2020 6:12 pm    Post subject: Reply with quote
I didn’t pay for any bolts when Porsche did mine. Was about £1100 each end. They discount parts a bit as these are in the older car bracket.
997.2 C4S PDK
Giff
PostPosted: Mon Jan 06, 2020 10:59 pm    Post subject: Reply with quote
Ouch.
- Brembo or Bosch high carbon & coated discs £130 a pair (Autodoc - currently 26% discount)
- EBC Red Ceramic Pads - £90 per axle - absolutely love them for road use.
All items in the first post's list of parts can be reused unless the sensors have been worn through.
Really nice DIY job too.
997.2 C2
Billy Bumpsteer
PostPosted: Tue Jan 07, 2020 8:41 am    Post subject: Reply with quote
Giff wrote:
Ouch.
He has a Porsche warranty!
Missing 1 sensor on the front
You maybe able to reuse the sensors and shims, the sensors get hot, brittle and break, the shims weld themselves in the piston so sometimes cant be removed without damaging them, if you do reuse them you need to clean up the backs and glue/double side tape them onto the pads.
The pin kit should clean up and be able to be reused
That list is what Porsche OPC would do as they dont reuse, clean etc. They just replace
The shims and sensors can be found outside OPC for about half price, Porsche discs & pads can be found cheaper so ask for a discount!
SGH
PostPosted: Tue Jan 07, 2020 9:04 pm    Post subject: Reply with quote
OPC and Indy both come out just under £1900 and Indy only £55.00 cheaper than OPC.
I might be able to get 10% off OPC on parts as they have done this in the past.
Robertb
PostPosted: Tue Jan 07, 2020 9:11 pm    Post subject: Reply with quote
I’d be surprised if an eagle eyed technician could spot non Porsche pads, shims and sensors... I’d chance it with carparts4less for those and go OPC on the discs.
Billy Bumpsteer
PostPosted: Wed Jan 08, 2020 8:21 am    Post subject: Reply with quote
Pads are the most likely thing to be spotted, shims and sensors no chance, discs maybe, depends on what you fit
PostPosted: Wed Jan 08, 2020 9:32 am    Post subject: Reply with quote
At that difference it's a no-brainer to stick with the OPC doing the job. It wouldn't hurt to ask them if they would 'price match'.
easternjets
Watkins Glen
PostPosted: Wed Jan 08, 2020 11:49 am    Post subject: Reply with quote
There has been a discussion before about changing the caliper bolts. As they are NOT a stretch bolt they are only replaced as a precaution, I've always reused them and never had an issue, they are a pretty substantial bolt.
Sensors do tend to deteriorate and you have to be pretty good to get one out without damaging it, sensors are £7 each from Autodoc.
A set of OEM discs are £836.40 from Autodoc
Pads are £170 a set back/front.
So your roughly a grand for parts and the rest is profit and workshop time!
As for the warranty, how long have you got before it expires and are you going to renew it? If not fit OEM and save a grand.
Fitting discs and pads on a 911 is very straight forward, in fact easier than a Honda Jazz that I did for someone recently!
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
Billy Bumpsteer
PostPosted: Wed Jan 08, 2020 3:31 pm    Post subject: Reply with quote
Genuine Porsche discs (x4) and Genuine Porsche pads (x2) are out there for a tad over £1100 delivered, from the UK
Magic919
PostPosted: Wed Jan 08, 2020 4:47 pm    Post subject: Reply with quote
Porsche parts should be 10% off at OPC as the car is more than 4 years old.
997.2 C4S PDK
