997 : 2004- 58
Boxster : 1997- 27
Cayman : 2005- 22
ch3tman
1995 Porsche 911
PostPosted: Sat Dec 28, 2019 7:11 pm    Post subject: Retro-Quik Morimoto bi-xenon solution for the 993 Reply with quote
Has anyone installed this in the UK?
https://www.theretrofitsource.com/morimoto-retroquik-porsche-993.html
They appear to work with (?) Bergville F/X’s brilliant T-LIGHT kit that many of us already have. A few questions for those who have installed this for their C16 car:
1] Do you recommend the product?
2] How easy was the install compared to the T-LIGHT install? On a scale of 1-10...?
3] Does it work alongside Tore's kit?
4] Is it blindingly bright? Really dislike how modern cars/aftermarket kits are dazzling and wouldn’t want to blind oncoming traffic...
Photos | instagram.com/ch3tman
cableguy
Watkins Glen
PostPosted: Sat Dec 28, 2019 9:57 pm    Post subject: Reply with quote
Endoman: http://911uk.com/viewtopic.php?t=132603&highlight=morimoto Thumb
C.
Pork!
ch3tman
1995 Porsche 911
PostPosted: Mon Dec 30, 2019 12:48 pm    Post subject: Reply with quote
@Endoman - your thoughts on the numbered questions above invited.. Smile
Endoman
PostPosted: Mon Dec 30, 2019 9:54 pm    Post subject: Reply with quote
] Do you recommend the product? Yes
T-light 1
Morimoto 4
Yes in fact it is easier to fit with Tore's Hid's than the kit from USA
Not all all, a very sharp cut off, good foreground illumination.
Cons:- expensive, a bit fiddly to fit.
Pros :- good beam pattern, with Cyclops Led main you will stun bats, owls and Range Rovers.
Make sure you order rhd kit you can't mod lhd to fit. And the splice wire to main beam so you get double main
ch3tman
1995 Porsche 911
PostPosted: Tue Dec 31, 2019 10:18 am    Post subject: Reply with quote
Thank you Endoman! thumbsup
T-light 1
Morimoto 4
..hmm Embarassed bit of thinking to do - but it is tempting - maybe something for next year Smile.
In the meantime, have any had any issues come MOT time with this setup?
Also, looking at the install guide (https://www.theretrofitsource.com/media/custom/upload/File-1484753410.pdf) I'm going to assume that if running Tore's T-LIGHT, Page 7, 10 & 11 are the ones to focus on, whereas Page 8, 11, 12, 13, 14 can be ignored ...Confused If anyone sees different please shout!
Endoman
PostPosted: Tue Dec 31, 2019 11:54 am    Post subject: Reply with quote
Indeed with Tore's kit everthing fits inside the pod. No problems with MOT as the system mimics Porsches own litronics system (and that is expensive)
The american instructions miss the fact that euro headlights have a levelling motor which gets in the way a bit, you can twist it anti-clockwise temporarily which gives a bit more room and then lock it back into place. You are supposed to have headlight washers with hids but again I deleted mine and it passed MoT.
Main beam is much improved as you now have Hid main with instant response as the shutter flips up and you still have the halogen main for daytime flashing. I fitted an Led main but it's a bit overkill and the reflection from motorway signs quite dazzling.
The dip beam spread is vey good with the morimotos useful on country lanes.
I liked them so much I fitted them to the 944 which has very poor standard headlights.
It was much more involved but again the result was worth it.
Sililar to this:-
https://rennlist.com/forums/924-931-944-951-968-forum/802951-another-944-xenon-projector-mod.html
ch3tman
1995 Porsche 911
PostPosted: Tue Dec 31, 2019 12:27 pm    Post subject: Reply with quote
Really good to know, thank you.
That's actually the reason behind considering this type of kit... I took the 993 up to Scotland a few weeks ago, and on some of those rural country lanes, at night, where there is no other light source, I would've benefited from something extra! That said, Tore's kit has proved to be 'just right' for the past 5 years in normal city/town driving Thumb.
nickjonesn4
PostPosted: Tue Dec 31, 2019 1:04 pm    Post subject: Reply with quote
Excuse the probably very stupid question...
Just checking fitting these would remedy the terrible low beam performance of my Bergville kit? I'm happy with how the high beams perform.
1996 Carrera S Vesuvius Metallic
2016 Golf R
2005 AMG E55K Wagon
Endoman
PostPosted: Tue Dec 31, 2019 5:33 pm    Post subject: Reply with quote
I'm surprised Tore's kit is poor on low beam.
The Morimotos are a very similar projector to the std Porsche ones and it's difficult to tell them apart in situ.
The beam pattern though is quite different, as the above illustration shows, although the halogen pattern as illustrated is not the pie chart type we get as standard.
On the 993 I have Tore's hid bulbs with the Morimotos and on the 944 Retroquick's hids. The 993 lights are brighter and whiter than the 994 which appear a little blue.
There is no facility for a change to the beam pattern with the morimotos i.e. for continental driving.
Good post inc. fiting:- https://rennlist.com/forums/993-forum/1036362-best-hid-upgrade-5.html
nickjonesn4
PostPosted: Wed Jan 01, 2020 8:18 pm    Post subject: Reply with quote
Thanks thats super helpful
Happy new year!
2016 Golf R
2005 AMG E55K Wagon
andyobro
PostPosted: Wed Jan 01, 2020 9:22 pm    Post subject: Reply with quote
9elevenheadlights have just posted that they will be releasing their new 993 lights this year.......
993 Carrera
www.instagram.com/993andy
ch3tman
1995 Porsche 911
PostPosted: Wed Jan 01, 2020 11:27 pm    Post subject: Reply with quote
Worth noting their 964 option comes in at over two thousands dollars..Surprised
If I understand correctly Confused, the colour temp of the output, at least for the 993, where the T-LIGHT kit is used, is dependent on whether you chose the 4300k or 6000k kit from Tore, rather than an effect of the Morimoto solution..?
Endoman
PostPosted: Thu Jan 02, 2020 11:46 am    Post subject: Reply with quote
Yes the Retroquick bulbs have a different colour temp and appear to have lower light output than Tore's hids.
ATM300
PostPosted: Sat Jan 11, 2020 10:53 am    Post subject: Reply with quote
I have these and tores hid and night breaker laser main beam bulbs. the overall solution is very good I live in rural Yorkshire and this set up transforms night driving, I have had no issues with blinding on coming traffic. There are two things to note.
Firstly, the morimotos projectors can not be switched from rhd to lhd so would need headlight stickers if going aboard and doing night driving. The other is that at MOT time the internal levelling switch next to the ignition key wasn't working and was considered a fail. On investigation one of the headlight motors had failed but also the new protectors were restricting the movement of the levelling system. This could have been down to a bad install, but they had to be modified to get the 3 settings on the internal switch. Obviously this is a one off situation but worth noting or at least looking at at time of install.
Over all I am very happy with my lighting set up and even did a night stage on a closed road rally with them in Mallorca last year and lighting was excellent.
ATM300
PostPosted: Sat Jan 11, 2020 10:57 am    Post subject: Reply with quote
I sourced mine here and they were very helpful and efficient.
https://emtuning.co.uk/product/bi-xenon-morimoto-mini-h1-7-0/
9xxnick
PostPosted: Tue Jan 28, 2020 7:20 am    Post subject: Reply with quote
I also bought mine from EM Tuning and had a good buying experience.
They are not particularly simple to fit, because they will probably require some adjustment of the interior plastics of the light.
I say probably, because my lights had previously been modified to accommodate a home-made version of the fitting kit used in conjunction with an earlier version of the Mini-Morimoto so I cannot be certain that the newer version would need any plastic removed inside the light housing, but I think it's likely.
The improvement in lighting however has to be experienced to be believed.
Skay993
PostPosted: Tue Jan 28, 2020 10:42 am    Post subject: Reply with quote
Autofarm fit mine and they've been excellent.
Croydon
PostPosted: Wed Jan 29, 2020 5:01 pm    Post subject: Reply with quote
look great and the ease of install id say the money.
andyobro
PostPosted: Wed Jan 29, 2020 5:26 pm    Post subject: Reply with quote
Where have you seen them Croydon?
993 Carrera
Croydon
PostPosted: Thu Jan 30, 2020 7:45 am    Post subject: Reply with quote
Just searched and ended up on Facebook its going to be called the Falcon S, looking at the Raven S I got a rough idea of price $2,400. no further details nor release date as yet though.
