997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Mon Nov 18, 2019 10:33 am    Post subject: Reply with quote
Eibach Pro lowering spring kit for PASM 997.1 has the part number E10-72-007-01-22, you can buy the springs separately a lot cheaper than buying the kit:
Front springs: 117200701VA
Rear springs: 117200701HA
I used Autodoc.com and saved about £160! Thumb
FZP
PostPosted: Thu Nov 28, 2019 3:24 pm    Post subject: Reply with quote
Does anyone have a Pierburg part number for a 997.2 Tandem Pump?
v6matt
PostPosted: Thu Nov 28, 2019 3:58 pm    Post subject: Reply with quote
PIERBURG 7.02388.18.0
Very good value at autodoc at the moment
2008 Carrera 4 - Gen 1 997
FZP
PostPosted: Thu Nov 28, 2019 4:27 pm    Post subject: Reply with quote
Thanks Matt, was just about to update the thread as came to the same website. I'm ordering that ASAP
Hertsdriver
PostPosted: Wed Dec 04, 2019 10:22 am    Post subject: Reply with quote
Found a source in china for the Gen 1 bootlid 'Carrera' badges that are the rigth size (about 25cm long).
Available in either gloss black or silver. Best to message the seller first to make sure they have them in stock, he will sort you a deal out as they are a bit more expensive than the smaller 991 versions advertised. I paid $31 shipped:
https://www.aliexpress.com/item/4000056690058.html?spm=a2g0s.12269583.0.0.13004022TBXixU
 Filesize:  60.86 KB
 Viewed:  618 Time(s)
v6matt
PostPosted: Sat Dec 28, 2019 11:47 pm    Post subject: Reply with quote
Thats a nice saving on the original which is £45 from opc.
Typically mine is a 4, so has the titanium badge ie a dulled silver
v6matt
PostPosted: Sun Dec 29, 2019 11:38 am    Post subject: Reply with quote
OEM Porsche Bump Stops are actually cheapest from Porsche OPC, about £14 a pop (cheaper than ECP parts), but if you are ordering from Autodoc then they do the FAG 811 0098 30 (2x dust covers and 2x bump stops for £16)
Just added
Goto page Previous  1, 2
Page 2 of 2
