Posted: Sun Dec 01, 2019 4:42 pm Post subject: Electronics Problem
I installed a new single DIN radio yesterday using a harness from Dynamic Sounds....I took the dash binnacle off to route the phone mic during the process the tiny locking tab that you have to depress before you unlock the bigger black tab broke on the grey connector.
Today when I drove the car I noticed the following things Reversing sensor stopped working, the computer control arm is unresponsive, dash centre display is stuck and most importantly Tiptronic switch’s on steering wheel don’t work.
All other electronics....lights, wipers indicators and the new radio are all working perfectly.
The only other thing I think may have happened is the new wiring harness has dislodged something inside the dash
So what have I done? Where should I look to solve the problem? _________________ Porsche 996 Carrera 02 Tiptronic Seal Grey
Filesize:
116.24 KB
Viewed:
504 Time(s)
deMort Dijon
Posted: Sun Dec 01, 2019 4:52 pm Post subject:
As per the image these items all go into Plug C which is the grey plug.
It's not making a good connection so have a look if its come loose . _________________ .
Filesize:
237.9 KB
Viewed:
494 Time(s)
Moko Trainee
Posted: Sun Dec 01, 2019 5:41 pm Post subject:
Thanks as always that does look exactly like the list of what’s not working.
Do you think just pushing the connector back in harder should fix it? I guess after 18 years the tiny plastic parts will get brittle.
The big black lever part was ok and went back down so there maybe a way to fix it but if anyone has any suggestions I would love to hear them. _________________ Porsche 996 Carrera 02 Tiptronic Seal Grey
deMort Dijon
Posted: Sun Dec 01, 2019 5:47 pm Post subject:
see if its loose first .. if the black lever has no tab left and it wont stay closed then a small piece of duct tape perhaps to keep it in position .
Check the pins as well .. worst way and one is bent so forcing it in will only make it worse . _________________ .
maldren Suzuka
Usually ok on a hot summer day but they're especially brittle in this cold weather, a blast from a hairdryer can help. _________________ Mike
Moko Trainee
Posted: Sun Dec 01, 2019 8:02 pm Post subject:
The Force will not be strong with this one...
I will check the pins are ok before doing anything....duct tape maybe the answer _________________ Porsche 996 Carrera 02 Tiptronic Seal Grey
deMort Dijon
Posted: Sun Dec 01, 2019 8:27 pm Post subject:
Trust me .. after all these years i have learnt that if you have to force something .. then something is wrong !!!
tape is best as glue and you cant remove it again .. it may not look pretty but it will work _________________ .
Moko Trainee
Posted: Thu Dec 05, 2019 12:47 pm Post subject:
Once again you were absolutely right....a little bit of contact cleaner on the plugs and some gaffer tape to hold it in place and everything works perfectly
So thanks again for all of your posts ....for some of us they are an absolute god send. _________________ Porsche 996 Carrera 02 Tiptronic Seal Grey
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You can attach files in this forum You can download files in this forum You cannot post calendar events in this forum
