997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
SP
PostPosted: Wed Nov 27, 2019 8:31 pm    Post subject: Tiptronic Gearbox - Manual Gear Selection Reply with quote
Evening,
Just wanting to check some tiptronic manual function logic:
On my early 996.1 the steering wheel gear selector switch does not work in D, only in M
On a 996.2 which I have driven the gear selector switch functions in D and M
Is this a function which was only introduced at some point during the 996 lifecycle or is this function dealer configurable etc?
Thanks for any pointers. bye
PostPosted: Wed Nov 27, 2019 10:33 pm    Post subject: Reply with quote
The functionality to do it in 'D' has been there in my 996.2C4 , 996T and 997.1T so it looks like it was a change after the 996.1.
I'd be interested to hear from other 996.1 Tiptronic owners.
Bluebird911
PostPosted: Wed Nov 27, 2019 10:49 pm    Post subject: Reply with quote
Mine is a yr2000 996.1 tiptronic.
When the steering wheel buttons are operated in D, they operate the gears manually and revert back to auto around 30 seconds after the last button press.
My buttons didn't work when my Torque Convertor Clutch ceased operation (probably not connected with this), but when the gearbox was overhauled, the transmission company sorted out the button operation and have worked ever since.
SP
PostPosted: Thu Nov 28, 2019 10:31 am    Post subject: Reply with quote
This was my expectation. Keen to keen from any other 98-2000MY owners to see if there was a logic change point.
OR if anybody knows if manual shifting can be enabled in “D”
RichiRich
PostPosted: Thu Nov 28, 2019 12:46 pm    Post subject: Reply with quote
Same for mine, though mine is a 2000 996 Turbo Tiptronic S - not sure if it makes any difference.
2000 996 Turbo
Speed Yellow / Black
Ex - 2003 996 Carrera 4S
Ex - 1992 964 Turbo X33 (#777)
PostPosted: Thu Nov 28, 2019 1:19 pm    Post subject: Reply with quote
RichiRich wrote:
....... mine is a 2000 996 Turbo Tiptronic S - not sure if it makes any difference.
All the 996s had Tiptronic S gearboxes however those fitted to the 3.4 cars were made by ZF and all later cars were made by Daimler/Chrysler.
My research has shown that they were all designed to function in the same way so it appears that SP's car may have a problem if he can't manually select gears whilst in 'D'.
PostPosted: Thu Nov 28, 2019 8:03 pm    Post subject: Reply with quote
Agree
30 seconds of manual if in D is what i thought all of these cars did .. check that if in manual both the buttons shift up and down as its common for a button to not work .
timm996
PostPosted: Sat Nov 30, 2019 1:58 pm    Post subject: Reply with quote
mines the same, a 98 996, buttons only work in M, later ones have the working in D etc.
I know I ain't doing much, doing nothing means a lot to me - Bon Scott:
Creationblue
PostPosted: Sat Nov 30, 2019 2:16 pm    Post subject: Reply with quote
My ‘99 only works in M too
'99 C2.1 Tip Vert
‘08 X3 3.0SD
'70 VW Westy Corvair T2
Moko
PostPosted: Sat Nov 30, 2019 5:03 pm    Post subject: Reply with quote
02 and buttons work in both D and M modes
Porsche 996 Carrera 02 Tiptronic Seal Grey
