997 : 2004- 62
Boxster : 1997- 24
Cayman : 2005- 20
sim996
PostPosted: Wed Nov 20, 2019 11:27 am    Post subject: Forged 996 Turbo Engine 4.0L, 1000hp Reply with quote
Fully built now, ready to drop in, just needs an FPR. Will continue if no buyer, but i'm losing interest as the time goes on. Last time home was spent on school and nursery runs so the C63s is all the car i need at this point in my life.
You can see the fuel hoses coiled up, so doesn't need much. Gearbox will be up for sale only if the engine sells.
Bored and stroked 4.0L, 1000hp capable, receipts for over 42k. Put together by Fearnsport, Matt truly is an artist, the detail is pretty amazing.
CP Pistons
Crower forged billet crank
Crower Rods
LA liners
Everything balanced, checked and gauged
Porsche genuine bearings throughout
New crank cases
Standard dual mass flywheel
Spec 3+ full face ceremetallic clutch
Tial Alpha3076 xona rota turbos
Tial turbo actuators
New drip tanks and lines
All single use screws replaced, i.e camshaft bolts etc
Expensive oil/water lines beautifully fitted with custom water take-offs
Forge diverter valves
Syvecs S8 ECU
SRM Billet fuel rails and ASNU injectors
Rebuilt and ported heads
New valves, guides and springs
All new lifters, both inlet and exhaust
New timing chains and guides and timing checked
12mm ARP2000 head studs
Cases drilled, with stronger inserts
New oil and water pumps
New power steering pump
All new water hoses
Welded water fittings
New oil cooler
Silly rabbit 82mm inlet plenum (proper one)
GT3RS throttle body
Large air intake Y pipe (not shown)
All new plugs and coil packs
Engine loom
Tubi stainless exhaust
Large bore, top gear manifolds
Air injection system removed
Just speculating really, no doubt i'll continue and enjoy the car, but if anyone is in the market, then by all means make an enquiry, but i know it's not something that would sell quick, i also dont want it hanging around at Fearnsport as i want the car in my garage over winter, so build will continue.
Look at build thread and previous for sale ad for more details/pics.
https://www.ebay.co.uk/itm/996-997-Turbo-Mezger-Engine-Alpha3076-syvecs-meth-forged-4-0/202805000476?hash=item2f381eb91c:g:p7kAAOSw3k9dhRxG
27k gbp.
 Filesize:  1.12 MB
 Viewed:  731 Time(s)
