997 : 2004- 65
Cayman : 2005- 22
Macan : 2014- 8
Grey996
PostPosted: Wed Nov 06, 2019 7:23 pm    Post subject: Are the exhaust bolts M8 x 35mm? Reply with quote
And if so how many will I need please?
I’ve just ordered TopGear CATS so I’ll be replacing all the fixing bolts as I’m guessing I’ll need my angle grinder more than my spanner when I dismantle things.
I’m not touching the manifold by the way!!
2002 Porsche 996 C2
heed
PostPosted: Fri Nov 08, 2019 1:56 pm    Post subject: Reply with quote
Yes they are M8 x 35MM. Part number 900 074 287 02
Six of them in total.
Since you're asking I assume you will source your own. But for the benefit of anyone else reading this, do not waste your money on these from Porsche. They charge over £5 a bolt!
When I took my cats of I nipped into Homebase (nearest place) and got some yellow zinc high tensile M8 x 35MM ones.
They looked exactly the same as the Porsche ones and cost about £5 for 8...
'04 996 C4S, arctic silver, graphite grey
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Fri Nov 08, 2019 4:33 pm    Post subject: Reply with quote
stainless bolts, brass nuts Thumb
My 911 ownership thread: http://911uk.com/viewtopic.php?t=134228
Grey996
PostPosted: Fri Nov 08, 2019 4:43 pm    Post subject: Reply with quote
Thanks both
2002 Porsche 996 C2
Hamster75
PostPosted: Fri Nov 08, 2019 6:09 pm    Post subject: Reply with quote
Are they the exhaust flange bolts & would they be the same on a 991
991.1 C2S Red
997.2 C4 White
924 Blue
Lee997
PostPosted: Fri Nov 08, 2019 8:59 pm    Post subject: Bolts Reply with quote
Funnily enough I picked up various clamps and baskets so that I can re-gasket and replace clamps on my 997s exhaust as it’s leaking!
Picked up the bits from design 911 today but wouldn’t pay the £3 per bolt they wanted!
Having just read this thread iv3 just ordered 6x M8 x 35mm marine grade Ss nuts and bolts for the very job you are proposing.
Just cost me £2.99 with free P&p from our friendly auction site.
P9XX
PostPosted: Sat Nov 09, 2019 6:33 pm    Post subject: Reply with quote
My 997 (so slightly off subject) had new steel cat. to silencer bolts fitted about 6 months ago and had begun to start corroding.
Replaced them all (6) with stainless steel about 5 weeks ago.
30 mm bolts and All Metal Locking Nuts via internet.
25 mm bolts from local screw fixing shop.
https://www.ebay.co.uk/itm/ALL-METAL-SELF-LOCKING-NUTS-METRIC-A2-STAINLESS-STEEL-M3-M4-M5-M6-M7-M8-M10-M12/161748903172?hash=item25a8fc6504:m:mXNVEkt7gyAPgTm5wkX0HOA
Went for Lock Nuts rather than plain.
These suckers go on tight and should never fall off.
Lower bolts easy. Top, difficult.
2008 997.2 C2S PDK Basalt Black
 Filesize:  166.98 KB
 Viewed:  249 Time(s)
