997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
acer54
PostPosted: Fri Nov 08, 2019 2:02 pm    Post subject: 4 wheel drive system fault Reply with quote
I used to get this fault if the car had been stood for a week or so, once the car had been used for a few miles if you switched the car off and back on again the fault disappeared.
I found as time went on it was happening more often and I decided to change the Battery, once the battery was changed I had no more issues during the warm Summer months.
Now that we are experiencing colder temperatures overnight every time I use the car I get the fault again and after a few short miles if I stop and start the car again it disappears until the next start the following day after been parked overnight.
Anybody got any experience of this themselves and if so what was the fix?
2005 Porsche Cayenne V6 3.2 Litre
PostPosted: Fri Nov 08, 2019 8:28 pm    Post subject: Reply with quote
Do you have any kind of tester that might be able to check fault codes and then post ?
without any code then any answer is a stab in the dark i'm afraid .
acer54
PostPosted: Thu Nov 14, 2019 1:55 pm    Post subject: Reply with quote
I'm getting the codes read tomorrow, I will report back afterwards.
PostPosted: Thu Nov 14, 2019 8:17 pm    Post subject: Reply with quote
I'll be here tomorrow Very Happy
acer54
PostPosted: Fri Nov 15, 2019 3:12 pm    Post subject: Reply with quote
Had codes read and it pointed to low voltage issues, as I said previously battery was replaced by Porsche last July.
Put the battery on charge for 3hrs, starting voltage 11.4 volts and when charge was complete it was 14.4 volts.
Started the engine and hey presto no 4 wheel drive system warning alarm which would confirm that it's voltage driven.
This only started a week ago during the cold nights, I don't use the car every day and when I do it's only for short journeys.
What's the way forward with this, should I buy a maintenance charger like a CTEK for example to use when the car is sat idle or is their another way?
Billy Bumpsteer
PostPosted: Fri Nov 15, 2019 3:31 pm    Post subject: Reply with quote
These cars are very susceptible to low voltage problems, it will get worse as it gets colder, ours did all sorts of crazy things with a low voltage battery, doors wouldnt lock, diff light came on.................I now put it on a charger if it doesnt get a good run every week
PostPosted: Fri Nov 15, 2019 5:10 pm    Post subject: Reply with quote
That does sound like the answer and short journeys are the probable cause .
A ctek or you can get solar chargers if no power where you park it .. either one will do the job.
golfprorich
PostPosted: Fri Nov 15, 2019 7:01 pm    Post subject: Reply with quote
Looking through the history of my Cayenne and it had an identical issue earlier this year, 4wd fault that was caused by a low battery voltage so it's certainly not uncommon!
Cayenne S 4.5 V8
