997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
allenh
PostPosted: Mon Nov 04, 2019 12:00 pm    Post subject: When is my next service due? Reply with quote
Hi there,
997 C2 here. Service book is a bit cryptic in the way it explains service intervals.
It says minor service at 30k, 90k miles
and major service at 60k, 120k miles
So in theory 4 services from new to 120k miles.
Then there is a time interval override
2, 6 and 10 years (I assume from new?) for minor
and for major
4, 8 and 12 years
So if I have got the following 2 most recent stamps:
- Major service 5 November 2014 21,000 miles
- Minor service 8 February 2019 38,000 miles
Current mileage is 45,000
Then when is my next service and what is it? Car is registered Nov 2006.
I'm trying to avoid the conclusion that it must be a major service and it must be now.
Allen
me&my997
PostPosted: Mon Nov 04, 2019 12:26 pm    Post subject: Reply with quote
Its difficult to know what was included when you say "major" & "minor" but as you haven't mentioned the 12yr MAJOR being done in 2017/2018/2019 its safe to say that is what should ideally done .
Virtually returns the service schedule back to the start of its cycle from where you can effectively start again knowing the slate is clean so to speak .
Around £1200 at OPC / £850/£900 recognised Porsche indy just be sure it covers everything it should like filters , diff oil , gearbox oil , plugs, polybelt etc Thumb
964 C2 / sold in haste - 2010
996 C2 / bought in haste - 2011
997 C4 / back in the game - 2019
http://911uk.com/files/dsc_5307_2_764.jpg
https://www.instagram.com/andy911wheels/
PostPosted: Mon Nov 04, 2019 12:32 pm    Post subject: Reply with quote
As above, I'm sorry to say that it looks like it needs the 12 year service, a major + other things next.
If it hasn't had a major done since 2014 and you're planning to put miles on it I'd treat it to that service asap.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Mon Nov 04, 2019 12:46 pm    Post subject: Re: When is my next service due? Reply with quote
allenh wrote:
Hi there,
and for major
4, 8 and 12 years
Allen
Its every 2 year OR 20,000 miles which every come soonest.
so for your 2006 car which is clearly under the mileage I would expect to see at least 6 services over the time to give a 'full history':
Minor service 2008
Major service 2010
Minor service 2012
Major service 2014
Minor service 2016
Major service 2018
So due a Minor service in Nov 2020.
Looks like a previous owner has missed the schedule with a big old gap between 2014 and 2019 Dont know
Personally Ill be performing oil changes every year in between the schedule for my own piece of mind. Thumb
allenh
PostPosted: Mon Nov 04, 2019 12:46 pm    Post subject: Reply with quote
It wasn't a particularly bad swear word. honest.
me&my997
PostPosted: Mon Nov 04, 2019 1:00 pm    Post subject: Reply with quote
Razz let the expletives go , we've all been there
When i started my hunt for a 997.1 all my target cars were at the 12yr or already past marker , obviously service history is a major factor hunting down the right car , nearly always these cars are described as having a FSH which yes i suppose they had but whenever i received the breakdown of how the history was formed every car was out of sync with what should have been done & when .
Furthermore i found regardless of mileage or number of owners only the car i bought had the 12yr service stamped & fully documented ( OPC it has a major checklist where green ticks or red crosses tell all )
It wasn't the primary reason i bought the car but did tell me a lot about the guy i was buying it off & how the car had been treat in his 4 yrs ownership .
Bite the bullet , get the 12yr MAJOR done then crack on safe in the knowledge that from a service perspective you can do no more , after that revert to following the schedule as laid out in service book with a interim yearly oil change too ( make a note but no need to stamp book )
Costwise i think for what gets done the £750/£1k figure isn't that high , its on a par with BMW ///M service costs & they are more frequent than 12yrs :
PostPosted: Mon Nov 04, 2019 7:40 pm    Post subject: Reply with quote
At 12 years you have gearbox and front wheel drive oil change needed if fitted .
 Filesize:  364.61 KB
 Viewed:  732 Time(s)
me&my997
PostPosted: Tue Nov 05, 2019 8:49 am    Post subject: Reply with quote
Are you meaning those items are done additionally to others like oil , filters , plugs etc ?
I'm away from home so can't photograph my service book where it shows what is covered at each 6/8/12yr point but checking online at OPC service options its the same as my book & the 12 yr or 120k service lists far more than that as requirements
Suppose its down to how you interpret the schedule Dont know
 Filesize:  258.09 KB
 Viewed:  645 Time(s)
PostPosted: Tue Nov 05, 2019 7:57 pm    Post subject: Reply with quote
A quote for a service is just the basic service .. Porsche list additional items separately .. and charge separately for these to be done as do we.
Ie brake fluid is changed every 2 years .. that's a seperate charge .. plugs again at 4 years and a seperate charge .
At 12 years old your gearbox oil is due to be changed and 4wd if fitted then the oil needs to be changed... again a seperate charge .
Technically you are also due a drive belt change , it should have been done at 6 years ... if so its due again now .
As with any of these items its time OR milage .
Indy or OPC work the same way here FYI .
