997 : 2004- 67
Boxster : 1997- 31
PostPosted: Thu Oct 10, 2019 10:25 pm    Post subject: Power steering fluid - how old's yours? Reply with quote
A couple of weeks ago my low pressure pipe blew off the end of the rack (common fault according to Demort). My mechanic fixed it for me last weekend and at the same time filled with new Pentosin CHF stuff. As far as I know the original was original, i.e. 19 years old. I must say, the steering is different - so much lighter. Can't believe the new stuff has made a difference. One of those things you never really think of changing but surprised at how different it's made it. Dont know
Who'd've thunk?
kurlykris
PostPosted: Thu Oct 10, 2019 10:54 pm    Post subject: Reply with quote
My low pressure pipe blew off at the ferrule on the steering rack about 3 years ago, I fixed with 2 x jubilee clips, can`t say that I noticed any difference in the steeing with new fluid, maybe it had been replaced, I`d have to check through the mountain of paperwork to see if it has Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
PostPosted: Thu Oct 10, 2019 11:17 pm    Post subject: Reply with quote
Maybe mine had previously been topped up with 7UP Dont know
P0tential
PostPosted: Fri Oct 11, 2019 7:16 am    Post subject: Reply with quote
I've been replacing mine gradually by sucking the reservoir dry with a syringe and topping up with fresh fluid every 100km or so. All changed now, and the pump is definitely quieter. Little to no difference in steering feel.
996 Carrera 4 Coupe
PostPosted: Fri Oct 11, 2019 7:21 am    Post subject: Reply with quote
Just for info: there's 1.3 litres in there.
steve1
2002 Porsche 996 Carrera 2
PostPosted: Fri Oct 11, 2019 10:28 am    Post subject: Reply with quote
Is there a way to drain the system and re-fill, without having to disconnect the pipes to the steering rack.
2002 996 C2 cab red
PostPosted: Fri Oct 11, 2019 10:51 am    Post subject: Reply with quote
I suppose you could disconnect from the reservoir and let the new stuff pump through. Its bright green like snot new so you'd see when its all pumped through.
GMG
PostPosted: Fri Oct 11, 2019 12:47 pm    Post subject: Reply with quote
...if it were me then I would be inclined to drain the reservoir and fill with fresh fluid, drive it for a bit and rinse,repeat....
This would be the simplest way of refreshing the system...in fact I think I will...
takeflight
PostPosted: Fri Oct 11, 2019 5:32 pm    Post subject: Reply with quote
I have just done my Vito, take off low pressure pipe to reservoir, connect a metre or so of clear tube, oh have a drip tray under car and as you remove the hose from the reservoir replace it with a bent over bit of rubber pipe held together with a zip lock to stop fluid escaping. Jack front of car up enough to have wheels off the ground.
Have a helper to turn the steering slowly from lock to lock, the fluid will start to come out the clear pipe, as it does so top the reservoir up, don’t let the fluid get to low before topping up, I used a funnel with a piece of tube on, the diameter size of the reservoir hole.
Remember you do not won’t to get air into the system, you should see the fluid colour change, when you do, you know you have replaced it completely.
Reattach the low pressure hose, again turn the steering lock to lock just to clear any air you will see inside the reservoir any bubbles, if air is present. Top to correct level and that’s that. Keep everything spotlessly clean, clean around the reservoir before and after, you do not won’t any grit or whatever in the system. Can mess up your rack.
You must use the correct fluid spec for your car, pick your moment and get 60%off eurocar parts or gsf, or of course Porsche.
Please note I am not a mechanic, this is just what I did, personally if there’s nothing wrong leave well alone, sounds like it’s more to do with the pipe fittings, I would check those.
PostPosted: Fri Oct 11, 2019 7:37 pm    Post subject: Reply with quote
I must admit this is not something i've ever considered ..
There is no service interval for changing this fluid and i always assumed it wouldn't make a difference .. for an owner to say it does then i go along with that .. i'm not a driver and so dont know these things .
To the point it might be worth recommending this on a service
Question
A total drain out would be problematic , old connections don't come undone that easily .
using a large bore syringe though would take out the reservoir contents though , top up with new .. perhaps run the car for 10 mins then do the same again to mix new with old then drain it out .
unsure atm .
Yup i still see corroded low pressure pipes about to fall apart even these days when i assumed all would have jubilee clips on them or have been replaced by now .
takeflight
PostPosted: Fri Oct 11, 2019 9:06 pm    Post subject: Reply with quote
Question
unsure atm .
Griffter
PostPosted: Sun Oct 13, 2019 8:52 am    Post subject: Reply with quote
I never changed mine on the 911 but I did it on an Audi once.
Disconnected return pipe at the reservoir iirc and directed it to a catch bottle. Started car and poured fresh fluid into the reservoir to keep the level up while a helper turned the rack from lock to lock.
You can see the colour change when the fresh fluid comes through or do it based on system volume.
Effectively you’re flushing the system through and replacing the fluid at the same time. You must keep the fluid level up though, so if you reverse roles make sure you trust your helper, and when you’re finished, get that return pipe back on quick!
Surprised it isn’t a service item but I think manufactures often only schedule 7-10 years ahead so things like coolant, trans fluid etc are left off.
BK911
1990 Porsche 964 Carrera 4
PostPosted: Mon Oct 14, 2019 8:59 pm    Post subject: Re: Power steering fluid - how old's yours? Reply with quote
Who'd've thunk?
Sounds like good house keeping Alex.. Will have mine looked at next service!
Good steer Grin
996 C4s
GT4 ClubSport
Ex - 1990 964 C4
