997 : 2004- 57
Boxster : 1997- 27
Dammit
PostPosted: Sun Sep 29, 2019 11:10 pm    Post subject: Reply with quote
They're lovely, but the wrong colour.
Dammit
PostPosted: Sat Oct 05, 2019 5:44 pm    Post subject: Reply with quote
Chris from CG recommended using a harness for track days as I've got a Recaro SPG seat which is designed for a harness.
However- I have no idea how I'd mount the shoulder straps, and fitting an actual harness bar seems somewhat over the top:
 Filesize:  134.66 KB
 Viewed:  2943 Time(s)
Jamie Summers
1992 Porsche 964 RS
PostPosted: Fri Oct 11, 2019 1:19 pm    Post subject: Reply with quote
The problem you have is getting the harness angle correct as it passes over your shoulders. Mounting the harnesses to the rear seat-belt anchor points is easy, and is what many people do, but that creates a very acute angle over your shoulders and transmits loads down through your spine, which is a no no, so you need something to create the correct angle.
There are basically three options.
1.)Harness guide bar - the harness mounts to the rear seat belt anchor points but passes over the bar which creates the proper angle over the shoulders. These are pretty quick and easy to install / remove, though I'm not sure I've seen one fitted to a 996 cab as they tend to attach to the B-pillar upper seat belt mounting point.
2.)Harness truss - this is rather more substantial with a greater number of anchor points. The harness mounts direct to the truss. This sort of thing.....
https://www.bkauto.com/R_1035_Harness_Mount_Truss_p/R_1029_p/r-1029.htm
3.)Full roll-cage - harness mounts to cage, but this is probably overkill in this scenario.
A less invasive solution may be to fit eyebolts into the rear bulkhead, though I have no idea how strong a mounting point that is in a 996. It was generally deemed acceptable in a 964. Hopefully someone else might be able to advise on this......... ?
Jamie
'06 Autofarm Cayman RS Development Car
‘99 996 C2
Ex '92 964 RS
Ex '93 968 CS
Ex '90 Clio Mk1 Cup Racer
Ex '90 964 C2
Ex '89 Carrera 3.2
Dammit
PostPosted: Sat Oct 12, 2019 7:31 pm    Post subject: Reply with quote
Harness - I hear you on the angle aspect, I do wonder whether I'd be within the 20 degree range that's considered ok (and would pass scrutineering) as the lower seat belt mounts are really pretty high up when compared to my shoulder harness openings on the Recaro SPG. I may get a tube welded in behind the front seats and use it primarily to attach the upper edge of a luggage net, but secondarily as a harness bar, if I go ahead and delete the rear seats and turn that area into a luggage storage compartment.
In seat related news:
Just need to strip the paint, make the hole a little larger, wave the TIG at it and wallop. Plus a squirt of satin black rattle can.
Jamie Summers
1992 Porsche 964 RS
PostPosted: Mon Oct 14, 2019 1:01 pm    Post subject: Reply with quote
If those are for fitting eyebolts for harness lap belts, the genuine 964 RS mount has the threaded boss already attached.
It's generally felt to be better to mount the belts direct to the chassis eg lower B-pillar seat-belt mounting point than to the seat rails. This tends to be difficult on the transmission tunnel side, so the 964 RS mount is a solution to that, allowing fitment of the seat belt receiver and an eyebolt for the harness lapbelt. The fact that the seat rail mounting bolts are made of cheese always made me nervous - I've seen the seat mount towers on the chassis crack as well. The solution is to drill the transmission tunnel and weld an eyebolt mounting plate on the inside of the tunnel.
I have no idea what the access is like to do that on a 996, but it was certainly a viable solution on the older cars.
‘99 996 C2
Ex '92 964 RS
Ex '93 968 CS
Ex '90 964 C2
Ex '89 Carrera 3.2
Dammit
PostPosted: Mon Oct 14, 2019 1:12 pm    Post subject: Reply with quote
I've got the 964 RS mount in the car at the moment - challenge with that is that it doesn't line up with the mounting bolts on the side-mounts/runners.
The two brackets pictured do, having been supplied with the seat mount, but they didn't have the 7/16th threading which the 964 RS mount does.
Essentially the bungs in the picture are direct copies of the inserts in the 964 RS mount, and will convert the brackets that came with the seat mount to BBI-racing/964-RS hybrids.
I'd then need to have a think about mounting harness lap belts, I'd probably screw an eyebolt into the mount and clip to that - I don't mind ten minutes of faff at the start and end of the track day.
Jamie Summers
1992 Porsche 964 RS
PostPosted: Tue Oct 15, 2019 1:10 pm    Post subject: Reply with quote
Yes, taking harnesses in and out is not a big deal, though the tunnel side can be pretty fiddly - small hands / strong fingers required !
I'd also recommend fitting a GT3 sub-bar under the seat to attach sub straps. To my mind four point harnesses aren't great as you can slide under them in a frontal impact. Five point as a minimum for me.
(It's a bit of a pet peeve for me - you so rarely see harnesses fitted properly using the correct double strap-wrapping technique, and even if they are, they're seldom adjusted properly by the wearer, with the buckle usually somewhere around the navel !)
‘99 996 C2
Ex '92 964 RS
Ex '93 968 CS
Ex '90 964 C2
Ex '89 Carrera 3.2
Dammit
PostPosted: Tue Oct 15, 2019 4:07 pm    Post subject: Reply with quote
The BBI seat base I used has mounting points for either five or six point harnesses, so that's no problem. The only question is the shoulder straps.
Dammit
PostPosted: Mon Oct 28, 2019 8:41 pm    Post subject: Reply with quote
Many thanks to Slippydiff for lending them and Mister Corn for moving them - these are now with BG Developments to have my new brakes designed.
I'm interested to hear what size rotor these 18" LM's can hold.
coullstar
PostPosted: Mon Oct 28, 2019 10:40 pm    Post subject: Reply with quote
Nice!!! Cool
Y2K
PostPosted: Thu Nov 14, 2019 5:03 pm    Post subject: Reply with quote
Hey bud, is there a chance you can weight the LMs please? Just wanted to know the difference between them and OZs.
Don’t particularly want E88s cos of the road use element.
2005 996 GT3 mk2
1999 Integra DC2
Dammit
PostPosted: Wed Nov 20, 2019 1:02 pm    Post subject: Reply with quote
Sure- will pop them on the scales when I have them.
Just dropped the car off for its new Blaupunkt Bremen DAB- excited to finally have the ability to stream direct to the head unit from my phone, whilst said head unit looks like it was made at the same time as the car.
Also had a chat about turning the rear two seats into a big luggage bin for European touring, which I’ll get to in Spring.
The Recaro SPG is going to be trimmed in leather to match the passenger seat/interior with Porsche heating elements just after Christmas.
Dammit
PostPosted: Wed Nov 20, 2019 1:25 pm    Post subject: Reply with quote
Dammit
PostPosted: Mon Dec 02, 2019 11:09 am    Post subject: Reply with quote
Dammit
PostPosted: Mon Dec 02, 2019 1:12 pm    Post subject: Reply with quote
^You can see the sub in that picture btw, the installer trimmed it with leather so it looks like part of the lower dash.
Dammit
PostPosted: Wed Dec 04, 2019 10:02 am    Post subject: Reply with quote
Chilly this morning.
Dammit
PostPosted: Thu Dec 05, 2019 3:30 pm    Post subject: Reply with quote
Sadly the DAB performance of my new radio is unusably bad, I've spoken with the place that installed it and they're going to check it out. Other than that it's pretty good, need a bit more time with it really.
I have to say the Beckers CD performance is excellent, so that's the standard I'm judging this new stereo by.
PostPosted: Thu Dec 05, 2019 6:50 pm    Post subject: Reply with quote
I'm guessing the dab performance will be down to the antenna Dont know
Is the knob on the front always that big........or is that something to do with Radio 4? Grin
PostPosted: Thu Dec 05, 2019 8:13 pm    Post subject: Reply with quote
logically there should be no difference between radio one and radio four .. that's not the case however as yours and many cars i have worked on have poor reception of radio four .
A DAB is a digital signal whilst the standard is analogue .. both seem to have issues so my theory is its the transmitters and not the receiving equipment.
DAB and it will stop playing with large gaps in the sound , analogue and it tends to crackle a fair bit due the the reduced signal in certain areas .
I think i would investigate the transmission a bit more ( google perhaps ) as i for one would like to know why it affects not just your car .
the radio company may well get a better response but i'm afraid an aerial is an aerial and if the signal is weak it can't do much.
just my thoughts anyways as newer cars have dual antennas and more complicated systems which i suspect is to get around problems like this ..
well out of my depth here though .
Indy Mechanic .
Dammit
PostPosted: Fri Dec 06, 2019 7:49 pm    Post subject: Reply with quote
Goto page Previous  1, 2, 3 ... , 43, 44, 45  Next
Page 44 of 45
