997 : 2004- 65
996 : 1997-2005 35
964 : 1989-1993 1
Lukec4s
PostPosted: Wed Sep 25, 2019 10:43 am    Post subject: Hibernation Reply with quote
Hi All,
I have parked up my 360 in the garage for the winter. Are there some things I MUST do in order to avoid issues when I take it out. I will prob leave it in the garage until march. My C4S remains a daily regardless of the season.
I have charged up the battery and then used the battery cut off switch. And it has the indoor car cover on it. garage is not heated.
cheers
Ferrari 360
996 c4s
Clio 182 track car - it’s fun
Wh1t3Kn1ght
2001 Porsche 996 Carrera 2
PostPosted: Wed Sep 25, 2019 11:05 am    Post subject: Reply with quote
Fuel stabiliser? Tyre savers? (or increase the tyre pressure to prevent flat spots)
2000 Violet 911 Carrera 2 3.4
1990 Panther Black 944 Turbo
isysman
PostPosted: Wed Sep 25, 2019 11:24 am    Post subject: Reply with quote
Mouse trap! There's a guy in YouTube had a 991 GT3 and mice chewed through his wiring loom. Cost $14,000 to replace it.
I've never used fuel stabilizers and I've been storing my cars for long periods for years. Not saying don't do it just that I have not done it and do not see any issues.
I do use wheel chocks, they are a faff but worth it.
That's it really:
clean it,
wheel chocks,
trickle charger,
mouse trap
cover it
chicb
PostPosted: Wed Sep 25, 2019 11:38 am    Post subject: Reply with quote
Wash & polish, ensure the brakes are completely dry to prevent discs rusting & pads gripping. Parking brake off. I also spray the discs with Bilt Hammer Atom mac which prevents disc rust, fill the petrol tank, add fuel stabiliser, add extra 10psi to tyres, connect Ctek & leave it permanently on. Indoor car cover. Car always starts first time come the spring.
Lidl have their Ctek clone on sale from tomorrow £13.99, gets good reviews.
isysman
PostPosted: Wed Sep 25, 2019 12:01 pm    Post subject: Reply with quote
Oh yes brakes.
My car has PCCBs so I’ve forgotten
pzero
PostPosted: Wed Sep 25, 2019 12:51 pm    Post subject: Reply with quote
OP, there are several threads on here for laying one's Porsche up for winter. Not sure how different any of the advice would be for a Ferrari. Have you asked the question on a Ferrari forum?
991.1 Carrera GTS
MaxA
PostPosted: Wed Sep 25, 2019 2:22 pm    Post subject: Reply with quote
This sounds like good advice, I use a fuel stabiliser in the boat (it has a Honda 4 stroke outboard) and that helps with the first start in the spring.
PostPosted: Wed Sep 25, 2019 2:31 pm    Post subject: Reply with quote
993 Illuminati are masters of storage solutions albeit they normally store for 364 days allowing one day out for MOT/Service Rolling Eyes
I'm sure they'll be along soon. But for me:
Trickle charge or disconnect
Tyres to 50psi
ACF-50 to underside components
Cover and leave Thumb
The game's afoot. It's time to put a bit of (Colini) stick about......964/993 wanted. Cash waiting. No dreamers
PostPosted: Wed Sep 25, 2019 3:04 pm    Post subject: Reply with quote
I did a long post of here some years ago about all of the things you should do. The problem is that they are mainly based on what was best practice with much older vintage cars than these and different fuels, tyres, mechanicals, etc... etc.... I regularly Rolling Eyes lay my cars up for 6 months and I just do the following:
- clean them (make sure they are dry before storage)
- over inflate tyres by 2-4 PSI (stops flat spots), in 6 months time they will be around OEM PSI
- fuel to the brim
- fit an indoor breathable cover
- make sure there are pest control traps around the car
- put on a battery conditioner or disconnect the battery
- lock the car
Other things would depend on the location eg security and how damp it is eg some say you should close interior vents, some say you should open them Rolling Eyes , some say you should leave a window a little open, some say you should not Rolling Eyes , some say you should put dehumdifier gel inside.......bottom line is if the storage location is on the damp side them ensure the interior of the car is vented eg to me leave vents open / window ajar but security is then a consideration. Personally I just leave vents open and close the car up but I store in a secure vented (ie not damp) location.
Flat spots / fuel stabilizers etc.... are just not as big an issue for 6 months storage with modern products IMHO
ps I've just laid up my boxster in storage today, cleaned it, filled it, pumped it, covered it, locked it, plugged it in.......forget it for 6 months....job done Thumb
After 6 months I just uncover, unplug, start and drive it no prblem at all Cool
moorhouse
PostPosted: Wed Sep 25, 2019 3:19 pm    Post subject: Reply with quote
For a car of that value I would certainly consider a Carcoon or something similar. I don't tend to lay the 911 up in the winter, just be a bit more choosy about the days I take it out - I started using one last year and the car has certainly benefitted from it. I was a bit sceptical to be fair but it didn't cost cash as I did a swap for free storage for several months against a once used Carcoon with a lad who stores his classic car with me and had bought the wrong size. Now converted and have bought another smaller one for another car as well. Usual problem with rust forming on the discs has gone and it stops any form of dampness forming, starts better and the car doesn't get stale inside either. It's the frame type so its very straightforward to drive in and out - basically drive in, zip up leaving the breather zip open for a day until all the residual heat/damp had blown down and then zip shut. If you really want you can add extra dessicant bags as well but I don't think you would need them especially if you were just leaving the car for a long period. Even putting the car away soaking, it is generally dry within 12-15 hours with the recirculating fans on.
Anyway, might be an option. Cheers....Ian
Edit - Oh yes, will probably help with any vermin issues as well as they have to get through the plastic tent first!
40th Year Anniversary #698
PostPosted: Wed Sep 25, 2019 3:34 pm    Post subject: Reply with quote
Surprised Have you applied any Oil of Ulay to the carbonique Dont know
cheshire911
PostPosted: Wed Sep 25, 2019 3:46 pm    Post subject: Reply with quote
If it is a paddle shift F1, leave it in 1st gear (or manual car same)
Leave handbrake off.
CTEK trickle charger is a must - isolating the battery by switching the master switch to off will render the car without power for the alarm systems and central locking. So better to use a trickle charger - in any case leaving the battery isolated for so long may discharge it.
As its indoors, no need for waxoyl or such like - but a nice to have it for preventative maintenance in season.
I add an extra 5 PSI per corner.
Move it forwards and backwards from time to time - and I start my hibernating Italian and run to warm-up about twice in that period you are proposing moving it up and down the drive way (SORN'd) before putting it away.
Come March/April it will be fine to fire up on first turn.
996 2002 X50 Turbo Manual
PostPosted: Wed Sep 25, 2019 3:53 pm    Post subject: Reply with quote
Hand ..... I would not touch the cheap stuff.......La-Mer all the way ....plus I like watching the cichlid fish tank they always have Thumb
Lukec4s
PostPosted: Wed Sep 25, 2019 4:14 pm    Post subject: Reply with quote
Thanks everyone some good advice. I gave it a good clean, wax and covered. I have a trickle charger. I will add some psi to tyres and put a few mice traps around the underside which I had not considered.
Don’t get me started on the spiders in my garage 🤣
Ferrari 360
996 c4s
PostPosted: Thu Sep 26, 2019 12:54 am    Post subject: Reply with quote
Make sure you leave some sandals and socks hanging on the rear view mirror Thumb
cheshire911
PostPosted: Thu Sep 26, 2019 2:32 pm    Post subject: Reply with quote
The vehicle is a Ferrari 360, not a 993. I dont think the 360 guys are a sandals and socks brigade.
PostPosted: Thu Sep 26, 2019 5:19 pm    Post subject: Reply with quote
Correct, false moustache and hairy chest it is then Grin
Boba fett
PostPosted: Thu Sep 26, 2019 8:53 pm    Post subject: Reply with quote
I’m just mauring up my Car. Sadly the Italian exotics are not made quite as well as the German cars.
I would ACF the underneath, lube all the rubbers, and if you have a Spider, lube the roof mechanism as well as what others have said.
PostPosted: Thu Sep 26, 2019 10:12 pm    Post subject: Reply with quote
Floor
PostPosted: Thu Sep 26, 2019 10:15 pm    Post subject: Reply with quote
A lot of Lube action going on there F boys
