Lee997 said:I would expect disks to be consumable parts sakes as pads which are all not covered by warranty! Meaning you won't breach warranty replacing them with another make!
2k for 4x disks and pads is absurd ?
I changed front pads on 2different cars today, Landrover sport 2016 and an Audi Rs4 2017, both sets came in less than £100.
Rgds Lee.
Seventy Seven said:Found some good prices on the links provided.
However, been talking to a few local Indy's and they have recommended Brembo or Textar.
One said Brembo discs with Textar pads, as Brembo pads can be squeaky....?
The other said he can do either for the front, fitted for £445 all in!
Any advice re the above? Go both Brembo or both Textar; or mix as above?
easternjets said:Replacing the bolts is a precautionary measure but not an essential one.
The bolts aren't from my recollection a 'stretch' bolt so only need re torquing to about 63 ft lb's, you could put a bit of Blue Loctite onto the bolt as a precaution, not Red Loctite!
