Boxster : 1997- 25
Cayman : 2005- 16
Kettmark
PostPosted: Sat Sep 07, 2019 5:24 am    Post subject: Improving throttle response in 997 gen 1 c2s Reply with quote
As above. Anyone got any suggestions?
Was thinking about either retrofitting sports chrono or fitting a lightweight flywheel. Car is not a daily driver.
I want it to feel a little more alive.
sja360
2007 Porsche 997 Carrera 4S
PostPosted: Sat Sep 07, 2019 6:40 am    Post subject: Reply with quote
When we're the spark plugs last changed? I felt the car pulled better after I had mine replaced. I guess the other option is a remap to adjust the power and torque so it increases further down the bottom end.
Out of interest, what makes you feel its not that alive /responsive? Have you had faster cars in the past?
Kettmark
PostPosted: Sat Sep 07, 2019 6:56 am    Post subject: Reply with quote
I've not had faster cars in the past no.
Spark plugs were changed at last major service 1000 miles ago.
I'd just like it to feel a little more responsive. My indi is looking into remap options for me.
PostPosted: Sat Sep 07, 2019 9:03 am    Post subject: Reply with quote
Before spending lots of money try fitting a sprint booster , this fools the throttle into thinking your driving much more aggresivly than you are , the old style has 3 settings the new has multi settings . this worked really well on my 997.1 tip when I had it and is not an expensive mod to do. it yours a tip car or manual
MaxA
PostPosted: Sat Sep 07, 2019 9:09 am    Post subject: Reply with quote
I would have thought that in order to improve throttle response, you'll need to reduce rotating mass around the engine with a lightweight crank pulley and a lightweight flywheel, especially the latter. And an improved airbox and free flow manifold with sports cat to improve the breathing. And maybe bigger injectors. All followed by a decent custom remap to make the most of the changes. How far do you want to go?
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Sat Sep 07, 2019 10:47 am    Post subject: Reply with quote
Some great advice here.
I think I'd get the fault codes read first.
Are the coil packs new?
Sprintbooster, under drive pully first options.
Lwfw and balancing starts to get v pricey.
N/a 997 not normally noted for poor or unenthusiastic throttle response, so worth getting an indy to check it over perhaps.
997.1 Seal Grey c2s manual, ltt, mobridge, zunsports, Carrera S IIs (summer)
Mezgerite
PostPosted: Sat Sep 07, 2019 4:04 pm    Post subject: Reply with quote
Fit a solid flywheel. It makes a massive difference to response.
PostPosted: Sat Sep 07, 2019 5:30 pm    Post subject: Reply with quote
It does, but unless its a track car isn't the NVH and chatter unliveable with . I am sure thats the feedback I got when looking at that mod. Question Dont know
Gray79
PostPosted: Sat Sep 07, 2019 5:43 pm    Post subject: Reply with quote
I don’t know if it can be retro fitted, but the sport mode you get with the sports chrono package makes a massive difference to throttle response.
997.1 Carrera 2S
jl-c
PostPosted: Sat Sep 07, 2019 5:48 pm    Post subject: Reply with quote
I beleive it can but I understand not the stopwatch part. If fitted then you can go the DSC route to alter both throttle response and suspension set-up. Obviously you need PASM aswell!
PostPosted: Sat Sep 07, 2019 6:40 pm    Post subject: Reply with quote
Throttle response ..
DSC or sports chrono upgrade .. no clock .. it's just throttle response .. either are imho what you are after .
Hopalong64
PostPosted: Sat Sep 07, 2019 8:53 pm    Post subject: Reply with quote
I have had sports mode retrofitted to my 997.2 C2S and it has completely transformed the car. Best upgrade I have ever done to a car. In sport mode or sport plus the car now comes alive. 😀😀😀
-- 997 --
PostPosted: Sat Sep 07, 2019 10:29 pm    Post subject: Reply with quote
Is it possible to fit a Sports Mode to a Gen1 Manual? If so what is needed? Modules, wiring? How is the done, would difference is noticeble??
J
Kettmark
PostPosted: Sun Sep 08, 2019 7:35 pm    Post subject: Reply with quote
Mine's a manual. Does a sprint booster work on a manual car?
Any idea as to cost including fitting?
Mezgerite
PostPosted: Sun Sep 08, 2019 8:45 pm    Post subject: Reply with quote
If you use the OEM GT3 RS4.0 clutch plate it isn't an issue.
OYSTR
PostPosted: Sun Sep 08, 2019 10:47 pm    Post subject: Reply with quote
Here you go - get a pair of these race boots. Same effect as a sprint booster.
'06 997 C4S
PostPosted: Mon Sep 09, 2019 12:40 pm    Post subject: Reply with quote
thats worth knowing Thumb Thumb
Avail from D911 and others
https://www.design911.co.uk/fu/prod9584/Sprint-Booster-Throttle-Control-for-PORSCHE_2_2_2/
PostPosted: Mon Sep 09, 2019 12:44 pm    Post subject: Reply with quote
They do sprint boosters for manual and auto just be sure you buy the correct one. cost is under £200 and fitting is a 10 min job to try it , and if happy then a little longer to route the cable and controller to where you want them .
this is worth a read
https://www.6speedonline.com/forums/997/196447-installed-sprint-booster-my-997-c2-instructions-w-pics.html
There will always be those that say a sprint boosters only the same as having a heavy foot and stamping on the go button all the time , but in reality we dont drive like that on normal roads so we need a devise that fools the car into thinking your doing that when your actually driving with regular foot pressure . who actually stamps on the go pedal all the time. Grin
https://www.facebook.com/projectdriveaustralia/videos/1924654490878682/
The return of Marty Wild
PostPosted: Wed Sep 11, 2019 6:28 pm    Post subject: Reply with quote
+1 Sprint Booster, plan to get one on my Boxster.
Boxster S 986.1
