991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Cayman : 2005- 16
squelch
PostPosted: Tue Jan 30, 2018 10:54 pm    Post subject: Reply with quote
rhino-man wrote:
If you are talking about your GTS, isn't that lower than a 4S anyway by 10mm?
(which I know is 10mm lower than a non S)
Didn't the GTS have some sort of supersport option as standard which was lower still?
The "PASM sports chassis (- 20 mm) with limited slip rear differential lock" was an option on the GTS.
From Stuttgart: 997 GTS, 997 GT3 (Kermit)
From Munich: 535d M Touring
From Bologne: Ducati Superlight
Gone but not forgotten: 996 C4S, 964, 924
rhino-man
PostPosted: Tue Jan 30, 2018 11:06 pm    Post subject: Reply with quote
Which makes it 10mm lower the standard PASM chassis then I think which is 10mm lower than standard. So the "sports" springs could be an option for us in warranty then.
2010 997.2 C4S
2001 996 C2 Convertible
rhino-man
PostPosted: Tue Jan 30, 2018 11:17 pm    Post subject: Reply with quote
A quick glance (so please verify these part numbers are correct) shows 2 different front springs listed for a GTS, around £150 each + vat
99734353150504 Coil Spring, 1 Set - Identification, Red, Red, Green CARRERA GTS | valid for Special model 911 Carrera GTS (I011) / valid for PASM electronic damper control (I475) | COUPE
99734353149504 Coil Spring, 1 Set - Identification, Silver, Silver CARRERA GTS | valid for Special model 911 Carrera GTS (I011) / valid for Sport-type chassis (I030) | COUPE
and same for rears around £120+ each
1 99733353164504 Coil Spring, 1 Set - Identification, Red, Red, White valid for Special model 911 Carrera GTS (I011) / valid for PASM electronic damper control (I475) | CARRERA GTS
1 99733353173504 Coil Spring, 1 Set - Identification, Silver, Silver, Yellow valid for Special model 911 Carrera GTS (I011) / valid for Sport-type chassis (I030) | CARRERA GTS
2010 997.2 C4S
Thefinn
PostPosted: Fri Feb 02, 2018 11:52 am    Post subject: Reply with quote
My new springs have just been delivered so you should all get a knock on the door soon!
997.1 C4S CAB
 Filesize:  235.91 KB
 Viewed:  3583 Time(s)
weebz
PostPosted: Fri Feb 02, 2018 12:28 pm    Post subject: Reply with quote
Thumb Forgot to mention, my arrived yesterday, now need to arrange fitting, may get around to it by the summer Grin
2010 Basalt Black 997 Carrera S - 'J-Lo 2'
2004 Atlas Grey 996 C4S - 'J-Lo' (sold)
badbox
PostPosted: Fri Feb 16, 2018 9:26 pm    Post subject: Reply with quote
are the techart springs also the best suited for a Gen 2 with pasm
ALso does it matter if its a Targa 4s Gen 2?
Targa 4S 997.2 PDK
PostPosted: Fri Feb 16, 2018 10:20 pm    Post subject: Reply with quote
Techart are fine for gen2 but make sure you get the ones for the Awd 4S as the rear springs are bigger the the ones for the 2S Thumb Targa option should be listed if its different to the non targa cars
badbox
PostPosted: Wed Mar 14, 2018 11:43 pm    Post subject: Reply with quote
When I have the stiffer setting actived the car bounces more and seems to hop....is that what I will be getting in normal mode once springs are on?
Targa 4S 997.2 PDK
PostPosted: Thu Mar 15, 2018 12:35 am    Post subject: Reply with quote
MMM what you have just described you need the DSC pasm upgrade module
theres a long thread on here about a group buy a few months ago , they are not cheap but totally transform the suspension . have a read of the thread and the link before deciding what to do next . I really like the way it makes my car feel subtle but how it should have come from the factory
http://www.tpcracing.com/dsc.html
roocat
PostPosted: Thu Mar 15, 2018 1:35 pm    Post subject: Reply with quote
I have the DSC module and I’m having the techarts put on soon. Will let you know the results.
weebz
PostPosted: Thu Mar 15, 2018 4:52 pm    Post subject: Reply with quote
I've had the springs fitted for a while now, no different to OEM in my eyes.
Mix of British and European roads over the last 1000 miles or so.
badbox
PostPosted: Tue Mar 20, 2018 12:54 am    Post subject: Reply with quote
food food I look forward to this
Targa 4S 997.2 PDK
roocat
PostPosted: Thu Aug 08, 2019 10:49 am    Post subject: Reply with quote
hi all, after a long time i've finally got around to getting my car booked in to have the techart springs installed. My Indy has just phoned me to say the front springs are considerably bigger compared to the stock spring they have removed from the car, and so he's asked if it's possible i have the wrong ones. Are there more than one type for PASM/Non PASM cars etc?. Mine is a gen 2 C2S. I'm hoping the size difference is just down to the spring rates but he made it sound like the difference was significant, so i just want to check if its possible i've got the wrong ones. Anyone else notice this?. I bought them via the group buy on this thread (some time ago now). Thanks!
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Thu Aug 08, 2019 11:06 am    Post subject: Reply with quote
Which part number did you get from Techart?
roocat
PostPosted: Thu Aug 08, 2019 11:41 am    Post subject: Reply with quote
i cant check the springs themselves but the part number on the box they were sent in, which i still have looks correct - 097.200.100.009
-- 997 --
PostPosted: Thu Aug 08, 2019 10:14 pm    Post subject: Reply with quote
Is your 997 a PASM or non? Also check your receipt what springs you paid for!! I still havent fitted mine, still in box chucked in the garage somewhere and to be honest i have seen them since the group buy.. but check.. what is your part number, can cross reference online..
J
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Thu Aug 08, 2019 10:49 pm    Post subject: Reply with quote
This thread just reminded me there’s a box in my garage attic with my springs from the group buy! Rolling Eyes
Anyway, just checked the invoice and the part number corresponds with my model/year.
If it’s of any use I checked here: http://www.techart-shop.de/techart-young-classics/997-carrera/fahrwerk/242/federnsatz-097-carrera-4/4s-coupe/cabriolet.
997.1 C4S Meteor Grey Manual
roocat
PostPosted: Fri Aug 09, 2019 7:46 am    Post subject: Reply with quote
Thanks all. Seems we have all been sitting on them for a while lol.
I can’t find the receipt but the box serial number checks out, my Indy is going ahead with it and will let me know if things don’t look right. Will post a pic here when done in case anyone is interested.
PASM car btw
Wattso
PostPosted: Sat Sep 07, 2019 6:29 pm    Post subject: Reply with quote
Hi all,
If anyone has a set that they've changed their mind about I'd be interested in purchasing them off you.
I need c2c 997.1 097.200.100.009
Goto page Previous  1, 2, 3, 4
Page 4 of 4
