997 : 2004- 65
Boxster : 1997- 26
love154
PostPosted: Mon Sep 02, 2019 10:45 pm    Post subject: Should I change the shocks Reply with quote
Hi my car is in having the top mounts and bearings done and been told the shock are rusty. Car is a 2009 so should I just change the shocks why it’s all being done. There are no leaks and it fills fine. What’s the life of these shocks.
kurlykris
PostPosted: Mon Sep 02, 2019 10:57 pm    Post subject: Reply with quote
The shocks on my 1998 996.1 C2 are just fine according to testing on the vibrations analysis at Centre Gravity, the defacto Porsche suspension Gurus Grin
So are the PASM shocks on my 2006 Boxster S Very Happy
Are yours PASM or standard Bilsteins Question
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
hermes
PostPosted: Tue Sep 03, 2019 5:16 am    Post subject: Dampers Reply with quote
I have a 2006 C4, my dampers tested fine but I decided to replace them with B4's when I recently switched to Eibach springs.
I don't know how long the dampers had been on the car, possibly from new and 70,000 miles, or what contribution the new springs made, but the difference now is night and day in terms of ride quality.
Mad Mark911
PostPosted: Tue Sep 03, 2019 6:12 am    Post subject: Reply with quote
So the car is 10 years old, but you don't mention the miles or how long you've owned the car.
That the top mounts need replacing is no surprise at that age, so likely that the shocks have worn somewhat, but they may still have some life in them.
However if you have the budget for it and can replace with original specification or better, plus you're going to keep the car, then new ones will provide an improvement. Often one that is night and day in terms of ride and handling ....
Smile
991.1 C2S - Rhodium Silver
Golf R - Lapiz Blue
Honda Civic Type R JDM - All white
Too many previous cars to list ...
PostPosted: Tue Sep 03, 2019 7:10 am    Post subject: Reply with quote
Buy some shocks online & when they come to do the job, get them to check them out. If they're tired or goosed fit the new ones, if not, return them.
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Tue Sep 03, 2019 10:04 am    Post subject: Reply with quote
The shocks do rust but are very high quality and can go intergalactic mileages whilst still functioning fine.
Buzz the rust off with a wire wheel and POR15 them.
Or go the upgrade route as many of these are second cars now so you could fit something less liveable.
PostPosted: Tue Sep 03, 2019 10:11 am    Post subject: Reply with quote
I've recently fit new front shocks and top mounts. Although the 18 year old originals still worked, I could move the shaft up and down by hand. The new ones are solid.
Its now highlighted the fact my rears are needing changing, especially when hard braking at 3 figures.
If I bounce my front its rock solid. If I bounce my rear theres a couple of bounces before it settles.....until next week Smile
love154
PostPosted: Thu Sep 05, 2019 6:31 pm    Post subject: Reply with quote
have gone with the new shocks saves me doing it down the line
