991 : 2011- 19
996 : 1997-2005 33
993 : 1993-1998 7
Boxster : 1997- 33
Cayman : 2005- 20
Jam911
PostPosted: Mon Sep 02, 2019 7:25 pm    Post subject: Brake Refresh - Parts Needed Reply with quote
I am sorting out parts for a brake refresh and wanted to check that I have the right parts....can anyone confirm please.
2 x Serbro Front Discs
2 x Textar Front Pads
2 x Front Wear Sensors
8 x Dampening Plates Front
2 x Sebro Rear Discs
2 x Textar Rear Pads
2 x Rear Wear Sensors
8 x Dampening Disc 30mm Rear
Current '07 997 C4S
Ex '99 2.5 Boxster
chowgar
PostPosted: Mon Sep 02, 2019 7:34 pm    Post subject: Reply with quote
I replaced all my brake pads yesterday and all I replaced with them were the sensors. I used Pagid brake pads and reused my existing caliper pins, clips and dampers, after giving them a good clean. They were all in perfect working order and after driving the car and a short bedding in, all is in normal working condition. No squeals or other noises have been experienced.
I have no issue in purchasing and replacing parts, but only when actually necessary. Not when the original parts are in correct working order and fully functional.
Poker2009
PostPosted: Mon Sep 02, 2019 11:26 pm    Post subject: Re: Brake Refresh - Parts Needed Reply with quote
4 Dampening plates Front & Rear, not 8. Rest is fine.
997.1 C2S, black, coupe, manual, Feb '05:
65k miles, tiny IMS bearing, Millers NT+ 10W50, driven above 3000 RPM.. original engine.
Billy Bumpsteer
PostPosted: Tue Sep 03, 2019 6:37 am    Post subject: Re: Brake Refresh - Parts Needed Reply with quote
Not quite;
4 x 28mm and 4 x 30mm on the rear
Poker2009
PostPosted: Tue Sep 03, 2019 6:40 am    Post subject: Reply with quote
Apologies - I thought just 4 on the rear.
maldren
PostPosted: Tue Sep 03, 2019 9:09 am    Post subject: Reply with quote
Plus stainless nipples?
Mike
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Tue Sep 03, 2019 10:19 am    Post subject: Reply with quote
Might be worth considering calliper bolts and the fixing screws for disc/hub as well. I replace these every time I change the discs. My OCD just wont let me re use old fixings on new parts Dont know
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
