991 : 2011- 19
996 : 1997-2005 33
993 : 1993-1998 7
Cayenne : 2003- 4
Locosaki
PostPosted: Tue Aug 06, 2019 1:17 pm    Post subject: Top Gear Cats 200 cell Reply with quote
I’m selling my Top Gear 200 cell cross over cats, these have done approx 1000 miles since I fitted so are as new.
These were fitted to my 996.
£375 delivered.
Carrera 4 MY99 with full Hartech rebuild
Kingb4
PostPosted: Tue Aug 06, 2019 6:24 pm    Post subject: Reply with quote
Hello - PM Sent Smile
2002 996.2 C2 Cabriolet
OllyW
PostPosted: Wed Aug 07, 2019 4:39 pm    Post subject: Reply with quote
I'm guessing it's a no, but these won't fit a 997.2 C2S will they?
Locosaki
PostPosted: Fri Aug 09, 2019 9:10 am    Post subject: Reply with quote
I’ve no knowledge if these will fit the 997.2 or not, maybe worth a check on Topgears site.
Locosaki
PostPosted: Fri Aug 09, 2019 3:25 pm    Post subject: Reply with quote
Here’s a picture of the cats removed from the car.
 Filesize:  351.18 KB
 Viewed:  1422 Time(s)
Locosaki
PostPosted: Sun Aug 18, 2019 10:48 am    Post subject: Reply with quote
Still have these for sale, I’m open to an offer as a few messages have all indicated there priced too steep.
The return of Marty Wild
PostPosted: Sun Aug 18, 2019 11:27 am    Post subject: Reply with quote
Take it they don’t fit a 986? Would be interest perhaps if they did.
Boxster S 986.1
coullstar
PostPosted: Mon Aug 19, 2019 11:42 am    Post subject: Reply with quote
Wont fit a 986. 997 they will bolt up but the link pipes are a little shorter so you would need a longer sleeve to connect back box.
PostPosted: Mon Aug 19, 2019 12:10 pm    Post subject: Reply with quote
Cheers for the heads up.
Boxster S 986.1
NLW73
PostPosted: Mon Aug 19, 2019 2:14 pm    Post subject: Reply with quote
you need to trim the ends by about 45mm to fit a 997.
or the sleeve as you said but TG advice is to trim for 997.
997 C2s Schwarz
coullstar
PostPosted: Mon Aug 19, 2019 2:42 pm    Post subject: Reply with quote
Sorry yeah I wast clear there, forgetting these are originally for 996.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Mon Aug 19, 2019 3:39 pm    Post subject: Reply with quote
why would you need a longer sleeve if you need to trim the ends? surely you need a shorter sleeve? Question
coullstar
PostPosted: Mon Aug 19, 2019 6:22 pm    Post subject: Reply with quote
I was thinking about it the other way i.e. 997 ones are shorter than the 996, therefore if fitting 996 pipes (which are longer) then you need to trim some off.
Basically 996 cats to 997 back boxes = interference.
NLW73
PostPosted: Mon Aug 19, 2019 7:15 pm    Post subject: Reply with quote
not really as when you buy the 200 Cells for 997 or 996 its the same piping and set up.
TG will cut off the 45mm for you if you specify 997 fitment or get it done by specialist.
the piping you cut off is the straight join to the exhaust into the clamps so its not any of the curved bits just straight piping
however once you have cut the piping you can only sell on as 997 fitment really. or get the cut off bit welded back on.
997 C2s Schwarz
Locosaki
PostPosted: Tue Aug 20, 2019 12:20 pm    Post subject: Reply with quote
Now sold Very Happy
