Boxster : 1997- 20
steve1
2002 Porsche 996 Carrera 2
PostPosted: Tue Aug 13, 2019 2:52 pm    Post subject: Sticky calliper piston Reply with quote
Hi guys I have noticed that my near side calliper is grabing occasionally and suspect a sticky piston.
Days gone by I would just pop the Pistons clean and replace with some calliper grease, maybe change the seals as well, is this doable on these callipers or can I put some brake fluid behind the seals and exercise then.
Opinions appreciated.
Steve
2002 996 C2 cab red
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Aug 13, 2019 3:24 pm    Post subject: Reply with quote
I would do what you say, not a difficult job Just hope the bolts come out of the upright OK.
steve1
PostPosted: Tue Aug 13, 2019 3:53 pm    Post subject: Reply with quote
Would you not do them in situe. Rather than chance them bolts stripping
2002 996 C2 cab red
MisterCorn
PostPosted: Tue Aug 13, 2019 4:05 pm    Post subject: Reply with quote
If you have seen my other threads you will know I'm not one for taking the short route Floor I would probably take the pair of calipers off the car, clean them, strip them and change seals, pistons changed as required. They need to be able to come off to change disks, so if there is going to be a problem might as well face it now.
Luddite
PostPosted: Tue Aug 13, 2019 8:24 pm    Post subject: Reply with quote
Might be worth looking at this thread...?
http://911uk.com/viewtopic.php?t=135263
