997 : 2004- 58
Boxster : 1997- 27
Cayman : 2005- 22
Maccy
PostPosted: Mon Aug 05, 2019 8:40 am    Post subject: Strange drivers window behaviour on cabriolet Reply with quote
Morning folks,
90% of the time when putting the roof up on my cab, at the end of the sequence the drivers window will start going up and get to about 2/3 of the way and then drop back down to around 1/4 of the way up. The passenger side behaves fine and goes all the way up.
I've tried the 30 second holding the switch thing (not sure if it's supposed to be with engine on or off and with the roof up or down!) and it's still not resolved it.
Before I contact the supplying dealer (Ashgood) as it's still in warranty, is there anything obvious I've missed?
Silver 997.2 GTS Cab
PostPosted: Mon Aug 05, 2019 8:47 am    Post subject: Reply with quote
The window is getting tight 2/3rds of the way up and thinks its trapped something (like your arm). You could try the following:
Wax your window with car polish.
Lubricate your regulator cable.
Silicone lubricant in the front glass runner (where the wing mirror is)
Maccy
PostPosted: Mon Aug 05, 2019 9:58 am    Post subject: Reply with quote
Ah cool thanks Alex, I'll give those suggestions a go.
I can get it to go up by holding the switch until it goes all the way up but it's just annoying!
Magic919
PostPosted: Mon Aug 05, 2019 1:09 pm    Post subject: Reply with quote
It’s a 997.2 thing, in my experience.
997.2 C4S PDK
PostPosted: Mon Aug 05, 2019 1:22 pm    Post subject: Reply with quote
My 996 did it.
Magic919
PostPosted: Mon Aug 05, 2019 1:34 pm    Post subject: Reply with quote
I don’t doubt that. I mean with a 997.2 you’ll struggle to get rid of it. I’ve had regulators and even a new motor and controller. Still does it from time to time. I heard they tried thinner glass for a while.
997.2 C4S PDK
Roro
PostPosted: Mon Aug 05, 2019 7:26 pm    Post subject: Reply with quote
My 997.1 does this, a bit annoying but not annoying enough to really do anything about it
2007 997.1 GT3
2017 F87 M2
PostPosted: Mon Aug 05, 2019 7:54 pm    Post subject: Reply with quote
It's a reasonably common occurrence im afraid .. the roll back function has been activated .. basically the car sees or thinks it sees an obstruction so rolls back the window .
you have to reset the windows so hold in the closed position for 5 seconds to reset the window position .
I'm afraid then on the 997 it's often the window motor that needs replacement .. it seems to learn an incorrect setting .
Basically 9/10 times its the motor with the odd time it's a stiff runner .. lubricate as mentioned but if it persists then it's a new motor required .
The control unit , which is the faulty part is part of the window motor .. hence that's what needs replacing .
This will only effect the one touch operation .. manually holding the button in the closed position will always shut the window .
Indy Mechanic .
Maccy
PostPosted: Tue Aug 06, 2019 8:45 am    Post subject: Reply with quote
Thanks deMort, fingers crossed I can solve it with the cheap/easy suggestions!
Is a new window motor a pricey job??
PostPosted: Tue Aug 06, 2019 7:05 pm    Post subject: Reply with quote
I'm afraid i fit the parts not do the costing .. but like anything with Porsche it's not going to be cheap .. i would guess at about £500 knicka though .
They also have to be coded to the car .. it can be a faf as it starts by working opposite .. down is up .. etc .
Try lube on the runners first .. something with ptfe in it .. open the window then spray down the runners .
To prove 100% you need to have a free moving window and feel it as it moves up and down for tight spots.
I'm afraid most i've seen since they were released turned out to be the control unit on the motor learning a wrong value on the roll back setting .. it's always random though .. sometimes it works .. others it rolls back and has to be reset to get one touch working .
It will Always work on manual though ( holding the button ) .
Indy Mechanic .
Maccy
PostPosted: Wed Aug 07, 2019 8:16 am    Post subject: Reply with quote
Cheers mate, I've got some WD40 lubricant spray so will give that a go.
icekay
PostPosted: Thu Aug 08, 2019 7:25 am    Post subject: Reply with quote
Same thing started happening to mine recently, and also had one occasion where the driver window didn't roll down whilst the roof was closing and so I had to do it manually.
2011 997 C4 GTS Cab
Maccy
PostPosted: Mon Aug 12, 2019 8:36 am    Post subject: Reply with quote
Well the lubricant spray didn't solve it sadly, I've reached out to the dealer as it's still under warranty to see what can be done.
PostPosted: Mon Aug 12, 2019 6:48 pm    Post subject: Reply with quote
if you disconnect a battery then you have to teach the window settings to the car .. hold the window button in the closed position for 5 secs ..
if the window rolled back due to this fault or indeed an obstruction then you have to teach it again .
if the car doesnt know the position as its not been taught then it may well open the roof with no window opening ..
I would have thought it wouldn't as its safety related .. but it seems it does .
Indy Mechanic .
Maccy
PostPosted: Wed Aug 14, 2019 2:28 pm    Post subject: Reply with quote
Well I took it back to Ashgood today and they plugged it in, cleared all fault codes and it was still doing it.
One of the guys did a few up and downs, locked it with the window down etc and just played about with it - and it seemed to fix it!
So all being well, it's resolved Smile
PostPosted: Wed Aug 14, 2019 2:36 pm    Post subject: Reply with quote
Doubt it.
Maccy
PostPosted: Wed Aug 14, 2019 3:31 pm    Post subject: Reply with quote
Alex wrote:
Doubt it.
I guess we'll wait and see.
Magic919
PostPosted: Wed Aug 14, 2019 4:07 pm    Post subject: Reply with quote
Mine was resolved for good at least three times.
997.2 C4S PDK
PostPosted: Wed Aug 14, 2019 6:13 pm    Post subject: Reply with quote
Floor
