997 : 2004- 58
Boxster : 1997- 27
Cayman : 2005- 22
John H
2011 Porsche 997 Carrera GTS
PostPosted: Mon Jul 29, 2019 4:21 pm    Post subject: Air/Con re-gassing problem Reply with quote
I had my Air/Con re-gassed last month at ATS Euromaster - where I bought my Michelin Pilot Sport 4S tyres last year.
The service there is first class, but yesterday my Air/Con started to blow warm again! I took the car back to have it checked.
I was told that it looks as though I have a leak in the condenser pipework - probably from stone chips under the bonnet?
They suggested I take it to my OPC as the front-end needs to be removed to get to it.
Has anyone here had this problem and know what the likely cost will be?
Any advice would be gratefully received... many thanks.
"Things turn out best for people who make the best of the way things turn out."
911rpd
PostPosted: Mon Jul 29, 2019 5:54 pm    Post subject: Reply with quote
I had to have a new condensor fitted last year, same problem the system was gassed and two/three weeks later it was warm - off side condensor was corroded at the bottom looking at the invoice a few other jobs were done but roughly ex vat
Condensor £198
O Ring & Vacuum line £70
Labour £190
(Another!) gas re-charge £80
That was with a local indi but also worth noting that I had some of the work and parts covered under warranty.
P9XX
PostPosted: Mon Jul 29, 2019 6:35 pm    Post subject: Reply with quote
Most likely is leaking condenser as these are prone to corrosion and stone damage. Looking through the lower grills with a torch, it's possible to see the left and right (2) condensers. Any green dye staining or black oil staining on the aluminium prove the leak.
I had my LHS condenser replaced at OPC in 2017 (car 9 years old).
Condenser, Dryer Bottle, 4 'O' rings, Re-gas and labour approx. £820 inc. VAT.
New condenser Black painted, old RHS condenser silver !!!
6 months later, RHS condenser leaking.
Decided to replace it myself with ECP Behr-Hella rad. and OPC 'O' rings + local re-gas at cost of about £190 inc.vat.
Moral of the story is to replace both rads together at an Indi.
If you're handy with spanners, job do-able at home. You Tube has several videos how to do the job.
2008 997.2 C2S PDK Basalt Black
PostPosted: Mon Jul 29, 2019 6:59 pm    Post subject: Reply with quote
An overview of the faults on a 996 which are similar to a degree to the 997 .. leaks on the condensers and pictures here that will show you the leak .
http://911uk.com/viewtopic.php?p=1473138#1473138
Indy Mechanic .
DucatiRob
PostPosted: Mon Jul 29, 2019 9:57 pm    Post subject: Reply with quote
Changed both of my condensers a couple of years ago, really easy job, probably about 2 hours max if you know what you're doing, used the cheap ones on eBay, decent quality, about £150 for both including the dryer and O rings. Still in good condition too, mesh fitted to the intakes to keep all the leaves and crud out is a good idea Thumb
Carrera C2S Manual-Full Hartech Rebuild-Ohlins R&T
Ducati 996
maldren
PostPosted: Tue Jul 30, 2019 1:51 pm    Post subject: Reply with quote
and fit some mesh grills over the intakes to stop it happening again.
Mike
John H
PostPosted: Thu Aug 08, 2019 1:19 am    Post subject: Reply with quote
Many thanks for the replies...
I had Zunsport grills fitted in March 2016 - obviously too late as the damage was probably already done or so it seems?
I rang my OPC at Wilmslow on 30th July and the earliest date they could book me in was 19th August for 2 days!
Heaven knows why they're so busy? It's not as though business is booming right now??
Clanky
2007 Porsche 997 Turbo
PostPosted: Sat Aug 10, 2019 9:05 am    Post subject: Reply with quote
I know the condenser rads are the go to suspects on these, but I found something else a couple of years back.
Started out on the NC500 & by Inverness the car was blowing warm air.
I took it in to Kwikfit & they tested & re-gassed the system & all seemed fine.
I was sat in the car park before leaving when the whole lot dumped out through the pressure transducer near the fill point. I'm glad It happened in the car park as the gas was instantly sucked in through the fan to the cabin. Not a fun experience!
Now, I'm sure the machine did it's job properly & added the correct amount of gas. But it was always in the back of my mind that it might have been over filled & exited out of the weakest link.
On the other hand, It's likely that the transducer was where it leaked from in the first place & the re-gas was enough to cause it to fail spectacularly.
something to bear in mind...
996 C4s (Gone)
997 Turbo
S3 Daily Driver
John H
PostPosted: Sun Aug 25, 2019 10:05 pm    Post subject: Reply with quote
Got my 997 GTS back from the OPC on Friday.
They had fitted two new A/C Condensers, four A/C O-Rings and a Desiccator - followed by a re-gas.
The total cost was £1192.10 incl. VAT.
Also included in the price was a 34 point Health Check which all received a green rating - meaning no other issues are currently apparent...
Personally I think that this is decent value for total peace of mind.. Thumb
RUDDY
PostPosted: Mon Aug 26, 2019 12:39 am    Post subject: Reply with quote
That is daylight robbery,
I recently bought two new condensors from Germany £62, four O rings from Porsce £19, Hella desiccator £24 (£8 versions are available)
To swap the condensor is literally a 5 minute job once the bumper is off
FZP
PostPosted: Mon Aug 26, 2019 8:50 am    Post subject: Reply with quote
John,
I've been putting off the same issue. I was advised by Wilmslow of a couple of damp patches on the condensers. My aircon still pushes out cold air, so it's not been on the top of my list.
I got in contact with a guy called http://www.mistercool.co.uk
He quotes me £400ish from memory for doing the job. He sourced Behr Hella condensers which were the the factory condensers. Even had the correct Porsche part number yellow sticker on them.
After reading Ruddys post, I might have a crack myself.
John H
PostPosted: Mon Aug 26, 2019 5:29 pm    Post subject: Reply with quote
Ruddy - good for you, I wish I had your expertise but I don't!
There's possibly something musical that I could do better than you - so everyone to their own I guess... bye
FZP - Ruddy good luck to you mate... Wink
PostPosted: Mon Aug 26, 2019 5:44 pm    Post subject: Reply with quote
Its fixed and that's the main thing .. i would just say have a look for any Indys in your area .. ask here if they are any good and perhaps use them in future for things like this ..
Speaking as an Indy of course Very Happy
What instruments do you play if you don't mind me asking ?
Most people here know what i do .. but i never know what you lot do for a living and i do find it interesting .
Indy Mechanic .
RUDDY
PostPosted: Mon Aug 26, 2019 6:23 pm    Post subject: Reply with quote
I get the feeling you’ve taken offence where non was intended.
I have no interest in music
FZP
PostPosted: Mon Aug 26, 2019 6:32 pm    Post subject: Reply with quote
John
Perhaps Sat week you can pop by the NW catch up and we can compare air con temps. Would be great to have you along Thumb Details in the meet section
John H
PostPosted: Tue Aug 27, 2019 8:36 pm    Post subject: Reply with quote
No offence taken Ruddy - just a bit miffed with myself for not being capable of doing what you did! Sorry if I gave the wrong impression - I was comforting myself that, at least I could do something else.. Cheers
John H
PostPosted: Tue Aug 27, 2019 8:41 pm    Post subject: Reply with quote
FZP wrote:
John
Thanks for the 'heads up' - I'll do my best to make it, but Saturdays are the busiest days of my week. I'll let you know next week.. Thumb
John H
PostPosted: Tue Aug 27, 2019 9:02 pm    Post subject: Reply with quote
I'm an ex-professional musician - mainly guitar and keyboards. After many years touring theatres and clubs, I opened my own. Now, together with two of my sons, I own and run a string of late-night live music venues.
Still wish I could be more hands-on with mechanical issues, but I don't have a clue!! worship
brownspeed
PostPosted: Wed Aug 28, 2019 8:33 am    Post subject: Reply with quote
Everyone back to Johns club for the afterparty then?
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
GARY S
PostPosted: Wed Aug 28, 2019 8:58 am    Post subject: Reply with quote
2016 I had to have both condensers on my 997.1 replaced. OPC charged £1200 including regas.
