997 : 2004- 64
Cayman : 2005- 22
Macan : 2014- 7
Cameltoe & Heel
PostPosted: Thu Aug 01, 2019 11:57 am    Post subject: t-OBD Reply with quote
Folks, I bought a t-OBD reader from Tore....
I've installed the software and hooked it up to the car successfully, I get the red flashing light and it reads Motronic, ABS, Climate control, Alarm without any issues.
Problem is when I switch for it to read SRS Air Bag, nothing happens, I select in the software and hit the switch on the unit, red light goes out and nothing. I'm trying to turn off my airbag light but no dice at the moment.
Can anyone help please?,
Trev
pzero
PostPosted: Thu Aug 01, 2019 12:51 pm    Post subject: Re: t-OBD Reply with quote
Trev
Tore?
991.1 Carrera GTS
andyobro
PostPosted: Thu Aug 01, 2019 2:13 pm    Post subject: Reply with quote
switch to airbag before trying to get into the airbag?
993 Carrera
www.instagram.com/993andy
stichill99
PostPosted: Thu Aug 01, 2019 3:24 pm    Post subject: Airbag light Reply with quote
When I bought my car the airbag light was on and although the seller was paying for it to be put right it ended up being a right hassle.
I twice had the car at independents who used Durametric and Bosch Hammer who could not extinguish the light.
The car went to Newcastle OPC where after getting new software from Germany and a new airbag module the light eventually went out.
I also have just bought plugs from Tore and going to download software so interested to hear how you come on.
ToreB
Approved Trader
PostPosted: Fri Aug 02, 2019 5:26 am    Post subject: Reply with quote
The Scantool software is not compatible with the SRS air bag control unit fitted to late 993 models. This unit has a 996 part number, and as far as I know was this used in some '96-models and all '97 and '98 models. The Bosch Hammer is also incompatible with these units, Porsche had launched the PST-2 diagnostic system by then to cover this.
The replacement part was (is) the same unit, so if the unit has been changed due to faults during the car's lifetime, it is highly likely that this is a 996 unit as well.
It is possible see the part number on the unit, it is placed in front of the centre console and has a orange harness connector.
Cheers,
Tore
'95 993 C4
Bergvill F/X
stichill99
PostPosted: Fri Aug 02, 2019 6:31 am    Post subject: airbag Reply with quote
As Tore says when I got a new airbag module on the 993 it had a 996 part number.
