997 : 2004- 58
Boxster : 1997- 27
Cayman : 2005- 22
NedHan79
PostPosted: Sat Jul 13, 2019 2:01 pm    Post subject: Replacement arches Reply with quote
Has anyone been able to find replacement rear arches for a narrow body 996?
I’m in the middle of cutting out and replacing sections of my inner and outer sills. When I’m at it I’ve cleaned up around the arches and they’re not in the best of shape. I could very easily bluff them up for a year or 2 but I’d much rather sort it now when I’m at it.
I can’t seem to find the arches anywhere online and I don’t need a quarter panel. It is only the lip that’s rough. I could possibly make all that I need but would much rather have a proper piece to set in.
Any help would be much appreciated.
#modified996mk1
 Filesize:  937.95 KB
 Viewed:  1378 Time(s)
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sat Jul 13, 2019 2:38 pm    Post subject: Reply with quote
I've not heard of any being available but I have done this several times for other cars by using fresh metal and shaped to fit before welding in place.
NedHan79
PostPosted: Sat Jul 13, 2019 2:44 pm    Post subject: Reply with quote
I think that’s gona be my only option.
This is a big learning curve for me. The sills have been a bigger job than expected as they seemed to be rotting from the inside out as the inners are worse than the outer. I’d say a few people will get a surprise when they go to fix some small crusty bits.
#modified996mk1
willy
PostPosted: Sun Jul 14, 2019 4:09 pm    Post subject: Reply with quote
I took a cursory look a few months when I had a rear arch repaired. Couldn't find anything, but the bodyshop where quite happy to weld a small amount of metal in.
Good luck!
1998 996 Carrera Ocean Blue
NedHan79
PostPosted: Sun Jul 14, 2019 9:30 pm    Post subject: Reply with quote
Thanks willy. I’ve a good idea of what to do but I’ve no experience. Sure I’ll give it a go and if I ***** it up, I’ll get a pro to sort it. It’ll have to go for paint anyway so a pro will have to give it the once over
#modified996mk1
NedHan79
PostPosted: Tue Jul 16, 2019 7:37 pm    Post subject: Reply with quote
Had a go at making the arch tonight. It’s not 100% but it fits perfectly to the old 1. It’ll just need a little work here n there but I’m very happy with it
#modified996mk1
 Filesize:  863.98 KB
 Viewed:  971 Time(s)
Kbald
PostPosted: Tue Jul 16, 2019 8:45 pm    Post subject: Reply with quote
Looks like a good effort so far. Thumb
2000 Carrera C4 Cabrio Tiptronic
