991 : 2011- 20
997 : 2004- 77
Boxster : 1997- 25
Cayman : 2005- 17
Cameltoe & Heel
PostPosted: Mon Jul 08, 2019 11:59 am    Post subject: Airbag Warning Light Reply with quote
Guys, managed to remove all warning lights on the dash post-build but I'm struggling with my airbag warning light.
I've attempted to connect a number of readers and none of them will communicate with the car. Not sure if I'm missing something here, surely it can't be that difficult, I've done this before with OBDII.
Does the 993 require a specific reader, I'm assuming that connecting a reader an cancelling the code is the only way to remove the light warning?.
Trev
wilsonny
PostPosted: Mon Jul 08, 2019 6:05 pm    Post subject: Reply with quote
the one from bergville works for me with the scantool software. there's a specific position to contact the airbag on the device and I seem to remember that i have to ensure the immobiliser is not active.
1996 C2 manual
decgraham
PostPosted: Tue Jul 09, 2019 7:07 am    Post subject: Reply with quote
Hi Trev,
I had a Airbag warning light issue many years ago. Not sure if you have the same issue as I did, but OPC Kuwait sorted my warning light out by simply changing the bulb. "That was it?" I asked and got "Yep that was the problem". Cheapest repair ever. Could it be that simple?
Good luck on fixing the problem. Thumb
ATB Smile
Cameltoe & Heel
PostPosted: Tue Jul 09, 2019 4:07 pm    Post subject: Reply with quote
Just bought an OBD-T reader from Tore so hoping that puppy will do the trick and of course highlight any other potential issues.
Trev
