997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
Slippydiff
PostPosted: Tue Jun 25, 2019 1:21 pm    Post subject: WANTED Schroth 996 GT3 Clubsport harnesses. Reply with quote
As per the title, I'm looking for a passenger side (I assume they're handed ? or a pair) of secondhand, out of date, 996 GT3 Clubsport harnesses.
Will also consider new items if sensibly priced.
Many thanks.
Dieseldave
PostPosted: Tue Jun 25, 2019 1:47 pm    Post subject: Reply with quote
Any good?
https://www.ebay.co.uk/itm/Shroth-Harness-Porsche-GT3-RS-997-RED-Colour-Very-lightly-Used/293129792009?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D63bf4094ba324a3ea8d833c8fa1b834b%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D254271662894%26itm%3D293129792009&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Ab2259a3e-974f-11e9-8de8-74dbd1806755%7Cparentrq%3A8ee3b3ac16b0a860d8e65279ffb9b716%7Ciid%3A1
Turbojim997
PostPosted: Tue Jun 25, 2019 9:28 pm    Post subject: Reply with quote
They aren’t handed you can swap which one stays fixed to the buckle 👍🏻
Are you looking for the 4 or 5 point version. 997 ones fit the same and some come with the 2inch uppers for FHR/HANS which I find more comfortable than the full 3 inch wide versions
2000 996.1 GT3 - second 911
2008 997.1 Turbo - first 911
2015 Discovery 4 - Truckasarus2
2015 VW Golf GTD
crash7
PostPosted: Tue Jun 25, 2019 9:41 pm    Post subject: Reply with quote
The ones in the link will not work without modification to the car.
The anti-sub strap fits differently in 996 to the 997.
96 are loops which fit to a bar under the seat, not ideal, in the 97 they added threaded points in the floor to attach to, I have modified my 96 to take the 97 harnesses as I feel its a much more secure/safer solution.
Disco
2010 Porsche 997 GT3
PostPosted: Tue Jun 25, 2019 11:22 pm    Post subject: Reply with quote
Not quite - if you are buying OE harnesses with a Porsche part number the 996 and 997 are different parts but both are 6 point with rotary buckles and 3" belts. Harnesses with 2" HANS belts are available in GT3 fitment direct from Schroth suppliers (note though that you have to buy the whole thing - they don't just do the shoulder belts separately) but they aren't the official part as supplied with 997 Clubsports. Note also that it is still fine to use 3" belts with Schroth HANS devices (I checked with Schroth back before I bought my HANS). They also have a push button version of their harness buckle instead of the usual rotary, but I've never seen that fitted to a porker.
Colin
Turbojim997
PostPosted: Wed Jun 26, 2019 5:39 am    Post subject: Reply with quote
Ah good point I think my FHR ones are just Porsche figment maybe not OEM part numbers.
I just found the 3 inch versions bunches up in my FHR. I have the Simpson Hybrid. I also read an article about the merits of 2inch over 3, I think by Schroth themselves 🤔
2015 VW Golf GTD
Slippydiff
PostPosted: Wed Jun 26, 2019 1:59 pm    Post subject: Reply with quote
Thanks all. I'd prefer an original 996 set or just a passenger side harness if at all possible.
Slippydiff
PostPosted: Wed Jun 26, 2019 2:03 pm    Post subject: Reply with quote
Thanks for this thumbsup
Did this involve drilling the floor and using plates such as these to bolt the harness straps to ? :
https://www.demon-tweeks.com/uk/race-safety-accessories-fia-compliant-harness-bolt-stress-plate-dtmsplate/
