991 : 2011- 20
997 : 2004- 77
Boxster : 1997- 25
Cayman : 2005- 17
tp81
1997 Porsche 993 Carrera 2S
PostPosted: Thu Mar 21, 2019 3:59 pm    Post subject: Reply with quote
Is there a company name?
1971 Alfa GT 1300 Junior
1973 911E (restoration project)
1995 993 RS
2013 110 Defender
2018 Panamera Hybrid
Endoman
PostPosted: Fri Mar 22, 2019 11:44 am    Post subject: Reply with quote
The shop was "Bargain Booze" they don't carry Buckfast either.
Diddi
PostPosted: Sun Mar 31, 2019 10:25 pm    Post subject: Reply with quote
…..I hope it will be better from now on with this delivery service
Grüsse, Diddi
 Filesize:  49.17 KB
 Viewed:  2074 Time(s)
9xxnick
PostPosted: Mon Apr 01, 2019 10:58 pm    Post subject: Reply with quote
Hang on a minute - you sent mine by DHL. I hadn't realised there was an option to upgrade... Cool
Diddi
PostPosted: Mon Apr 01, 2019 11:28 pm    Post subject: Reply with quote
….next time Thumb
Grüsse, Diddi
Diddi
PostPosted: Mon Apr 01, 2019 11:30 pm    Post subject: Reply with quote
….DHL next time Thumb
with Hermes, it worked out again.
Grüsse, Diddi
Kat1
PostPosted: Tue Apr 09, 2019 3:53 pm    Post subject: Reply with quote
wilsonny wrote:
thought id be clever over the weekend and lift the car up, put it in gear, then turn the wheels to get the engine to the timing marks so I can remove the distributor. turns out I don't understand very well how differentials work ! (turning one wheel spins the other in the opposite direction and trying to turn both simultaneously was beyond the strength of me and my helper). no way could I get the engine turning in this situation.
presume you guys who have removed the dizz have managed by putting in gear and rolling the car back and forth (while on the ground) ?
1. Lift car on ramp.
2. Release hand brake.
3. Remove right hand rear wheel only.(see below)
4. Slacken handbrake adjuster on this side only.
5 Apply handbrake.
6. Select 5th or 6th gear.
7. Turn hub with the 32 mm driveshaft nut until timing marks align.
I managed to view the timing marks whilst at the same time turning the hub with my foot.
If you are a left footer then remove left hand wheel if you want to make it easy!
Diddi
PostPosted: Tue Apr 09, 2019 5:14 pm    Post subject: Reply with quote
…..why so complicated to jack up etc. simply insert the 3rd gear and push the 11er on Position - first your own woman to push get (later the girlfriend)
Grüsse, Diddi
Diddi
PostPosted: Thu Apr 18, 2019 11:34 am    Post subject: Reply with quote
......….that's how it looks inside
Grüsse, Diddi
 Filesize:  190.19 KB
 Viewed:  1715 Time(s)
Diddi
PostPosted: Wed Apr 24, 2019 6:30 pm    Post subject: Reply with quote
1.5.2019...see you in DINSLAKEN ,..🇬🇧….for all my English guys hit me on the shoulder or a kick in the ass - we want to drink ! 🇬🇧👍👍👍
https://www.facebook.com/groups/porschefreunde/permalink/2469187773100146/
Grüsse, Diddi
 Filesize:  32.96 KB
 Viewed:  1584 Time(s)
Kat1
PostPosted: Sun May 19, 2019 3:49 pm    Post subject: Reply with quote
Due to an issue with a courier there is now a spare set of replacement parts for a DIY dizzy refurb in the UK. (bearings belts and screws).
This set normally costs 228 euro however Diddi is prepared to sell this one off set for just 170 euros.
You will have to collect from Ely, Cambs or arrange your own courier.
Payment direct to Diddi.
I have just replaced the belt and bearings on my 115k mile C4. Biggest issue was removing the distributor from the engine - removed fan housing and used pry bars and penetrating fluid.
Whilst superficially the old belt and bearings looked Ok - when the dizzy was striped one of the bearing sounded dry, there was evidence of fretting corrosion and the belt whilst still intact was easily pulled apart.
I feel like I dodged a bullet on this one.
Kat1
PostPosted: Mon May 20, 2019 10:58 am    Post subject: Reply with quote
Yes you are right!!
Using a ramp - jam one wheel and rotate the other whilst in a high gear.
Goto page Previous  1, 2, 3
Page 3 of 3
