991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
DJones
PostPosted: Wed May 15, 2019 3:16 pm    Post subject: Painted callipers Reply with quote
I’ve just freshly painted my callipers, thought I’d stick up some new pictures.
I’m pleased with them.
Darren.
2002 996 GT2 recreation in Nogaro blue
2017 Ferrari 488 GTB Nero black
2006 Ford GT40 Gulf Racing colours
1994 AC Cobra 427 Guardsman blue
 Filesize:  305.94 KB
 Viewed:  1085 Time(s)
 Filesize:  111.99 KB
 Filesize:  166.13 KB
James03C4S
PostPosted: Wed May 15, 2019 3:59 pm    Post subject: Reply with quote
Looks like a top job you've done there. I've get yellow calipers on my c4s too and love the colour contrast.
Trouble is people now think im trying to make it look like it's on ceramics when really I just like the colour Very Happy
Winny911
PostPosted: Wed May 15, 2019 5:03 pm    Post subject: Reply with quote
Nice
What paint did you use and do you have any tips as I was thinking of painting my new calipers yellow.
Winny
DJones
PostPosted: Wed May 15, 2019 5:13 pm    Post subject: Reply with quote
James thanks.
Winny no real tips as such, cleanliness is everything when painting anything. I’ve painted numerous cars over the years and more recently race helmets, it just takes patience.
These had just been refurbished in red so to start with I degreased them with solvent and then flattened them off with 600 grit wet and dry paper. I then painted them white with solvent base paint to block out the red. This was followed by the yellow solvent base. Following this I cut the decal from black final and applied in the correct place. A quick wipe with a tack rag followed to remove any dust and the clear coat was then added. I used a 2k clear coating.
The main tip is block out the red before changing colour.
Good as new!
Darren.
Winny911
PostPosted: Wed May 15, 2019 5:45 pm    Post subject: Reply with quote
Thanks I think I'll give it a go then. Thankfully my 944 calipers don't need a decal so should make it a bit easier
Winny
Armagreggon85
PostPosted: Wed Jun 05, 2019 12:50 am    Post subject: Reply with quote
Hi Darren
Lovely job. What paint did you use? I'm assuming high temp. Was the logo cut from a special heat resistant vinyl or just standard?
DJones
PostPosted: Wed Jun 05, 2019 7:46 am    Post subject: Reply with quote
Thanks, I used solvent base coat with 2k clear over the top. The vinyl was just standard and stuck on top of the yellow prior to locking it down by clear coating over the top.
Hope it helps
Darren.
