Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
stichill99
PostPosted: Sun May 05, 2019 11:50 am    Post subject: petrol Reply with quote
A quarter tank of petrol you say, I would have been happy with that,when mine was delivered I took it out and 1 mile down the road the fuel light came on! 3 miles down the road the brake pad wear indicator light came on!
Luddite
PostPosted: Sun May 05, 2019 1:20 pm    Post subject: Reply with quote
crypticc, Congrats on your "new" Porsche... Boy would I be pleased to have it in MY garage..(-: It would appear you have done all and more that could be thought of as due dilligence relative to it`s purchase, all you need to do do now is derive as much enjoyment as seems possible during your ownership.... In your list of niggles I would be surprised if the oil pressure/temp gauge terminals would need cleaning at the dashboard end of things as any dirty termination would seem far more likely at the engine end of things, though it also seems logical that they may have had the gauge out to carry out checks..? I would think that if I had just bought a vehicle of that age, I might expect some gremlins to show up and if the only gremlin was down to an item of ICE equipment, I would be a happy chappie indeed.... ENJOY crypticc ENJOY thumbsup thumbsup
crypticc
PostPosted: Sun May 05, 2019 10:13 pm    Post subject: Reply with quote
Yeah. Good 200 mile round trip today. (Significant fraction of previous few owners annual mileage) and the Engine didn't miss a beat, if anything getting better as the miles added. Once up to speed and cruising oil pressure a solid 4.5 but mostly 5 all the way until coming back down to urban traffic. Temp also planted firmly on rhe first dot (1/3rd) temperature more or less all the way. Thermostat on Aircon I think is a fine art but manages both toasty hot and super cold when requested at the extremes, but not too subtle in the middle. Reading 993 companion further now I'm home it seems 0 fanspeed is the fully automatic/mixing mode I should've been using and whacking fan up doesn't guarantee hotter air unless you also manually increase the temperature dial.
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Mon May 06, 2019 6:46 am    Post subject: Reply with quote
Nice. Hope it brings many hours of happiness. Does it live on the street?
ollster
PostPosted: Mon May 06, 2019 8:34 am    Post subject: Reply with quote
I wasn't aware 0 on the ccu was a variable speed function, can anyone else confirm this as i thought I knew most things about my car after 10 years but would be nice to find something new Laughing
9xxnick
PostPosted: Mon May 06, 2019 9:28 am    Post subject: Reply with quote
I don't believe setting 0 for fan speed is automatic. I've never experienced it doing anything other than blowing at ultra low speed when in that position.
If the temperature setting works OK at its extremes but not well in the intermediate range, it's possible that the thermistor (temperature sensor) needs looking at. It's located in the CCU. Tore B may have a fix for this.
crypticc
PostPosted: Mon May 06, 2019 7:23 pm    Post subject: Reply with quote
I went from the "note" from the 993 essential companion - extract attached - though I don't think in my case that is what is happening. Initially it operates and car gets warm quickly but then thermometer begins to miss-read.
Elsewhere I've read both fluff-blockages and a failing fan within the CCU can cause it to read internal control-unit temperature rather than accurately measure the car interior - though the site didn't say if that was a mini fan within the unit or the mixer one behind the unit can hear in the background if I turn on the ignition without starting the car. To diagnose mentioned hooking up diagnostic to read the absolute temp from OBD but I've tried my DCAN+K cable and the rennlist app to no avail.
 Filesize:  121.36 KB
 Viewed:  474 Time(s)
9xxnick
PostPosted: Mon May 06, 2019 8:53 pm    Post subject: Reply with quote
I'd read that to mean that although setting 0 is always for minimal fan speed, the actual speed the fan runs at is dependent on the temperature of the resistor pack which controls the fan speed on the various available settings.
This resistor pack sits in the airflow of the ventilation system and it would make sense for it to receive additional cooling (higher fan speed) if it's getting hot.
I wouldn't interpret it to mean that the system works like a fully automatic climate control system where fan speed as well as air temperature is controlled automatically to provide the chosen interior temperature.
I believe the CCU fan is integral with the unit. Fluff on the thermistor could potentially cause it to mis-read but there could be other issues at work too.
crypticc
PostPosted: Tue May 07, 2019 11:10 pm    Post subject: Reply with quote
Garaged...was only allowed if I could make the sums with with garage/gated covered rental. Less to do with security and more because people can't park and the bin men are brural Actually with £270 pa to add to the multi car policy is not too bad, . So with a bit of man maths I made it work
crypticc
PostPosted: Fri May 10, 2019 11:17 pm    Post subject: Re: petrol Reply with quote
To be fair they're going to make this bit good for me. I can't fault the Comms. Time will tell on the car... Going into Torque for a once over and a couple of things I want doing in a couple of weeks
crypticc
PostPosted: Sat May 25, 2019 5:57 pm    Post subject: quick update after post purchase inspection Reply with quote
Hi
Car's been with Sid at Porsche Torque this week. Apparently it's a "good one".
Needed
OSR wishbone (bushes worn - I was expecting this as NSR was done a couple of years ago at Centre Gravity, but not this one)
Front ARB links (slight play, apparently a few years left in them with sub 5000 miles a year - but I figures why miss out on the benefit now?)
Power steering hose had some weeping - replaced.
Slight oil weep between crankcase and head ( I think that's what he said) - advised very minor and not to worry until something else determines engine needs to come out. Probably won't even notice the oil. Rest of the usual gaskets/culprits are dry.
That's it - apart from a temperamental dash backlight and temperamental drivers door light switch- I'd spotted both but forgotten to ask to get them done until I went to pickup the car. I was relieved that Sid managed to find a spare switch in his box of tricks in the loft and had a thoroughly good natter while he dealt with those last few things.
Happy bunny ! Only slight downer is that next door is a wood-working shop and I think my car had been parked under the extractor - so had lots of lovely sawdust. No harm done and an excuse to give the car a quick rinse when I got home. Smile
Chris
p.s. Anyone know a Burnt Orange 911 GT3 RS ("?Dr Zeus?"). Crossing the blackwall tunnel. Nice car!
crypticc
PostPosted: Sat May 25, 2019 6:08 pm    Post subject: G64 21-20 vs G64 21-20 Reply with quote
p.s. definitely notice the longer range gearbox in this one compared to the cross-over with the Varioram+pre-Varioram gearbox. 2nd in this is well over 65 and almost too leggy and 6th feels almost like a 6.5 ratio. - But fine for the road and mpg isn't too bad and the engine doesn't seem to mind it - which I guess is the point. Can't help thinking though if the car was designed-for the shorter ratios - The Arena at WC had the shorter ratios so hope whoever has that knows what they've got !
Goto page Previous  1, 2, 3
Page 3 of 3
