991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
NedHan79
PostPosted: Mon May 06, 2019 8:57 pm    Post subject: Eps track control arms Reply with quote
Has anyone tried these?
Are they worth the money?
Are there any alternatives? Can a bush be got anywhere else or adapted from something else because as far as I can see it’s quite simply 2 halves of poly and metal inserts. Looks very simple.
#modified996mk1
JTT
PostPosted: Wed May 08, 2019 11:52 pm    Post subject: Reply with quote
I've got them on all four corners now. Nice tight setup, no play or rubbers to wear out.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu May 09, 2019 1:07 am    Post subject: Reply with quote
Which type do you mean as there was an issue with the EPS arms where they replace the articulating bush with poly, I once considered them myself but didn't like the design and (I can't find it at the moment) there was a thread where someone was saying theirs had failed (I think broke) due to the bush not having enough movement for the suspension?
NedHan79
PostPosted: Thu May 09, 2019 5:29 am    Post subject: Reply with quote
I mean the bush at the chassis end of the tuning fork. I like the idea of changing it but not so keen on having to buy a whole new fork. I know the standard one isn’t a bush and that the eps is more expensive but I would have thought someone on here would have got round that by now and sourced their own solution
#modified996mk1
