991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
kozzi
PostPosted: Sun Apr 28, 2019 4:43 pm    Post subject: Turbo with coolant leak Reply with quote
Well took the kids out and noticed coolant on the floor in the car park of a fun park and it just kept hitting the floor for over and hour
So instead of doing my normal and driving home I called the AA and they couldn’t spot the source so called a truck. Having a nice meal as we wait but I am wondering if it is a split pipe or the water pump? It is coming from quite high up and he check a couple of lower pipes for tightness and splits
Never had a car on a lorry but son is happy as he doesn’t have to keep telling me I am going over 70 all the time!!
I am the beast that feeds the beast
116618LN
PostPosted: Sun Apr 28, 2019 5:59 pm    Post subject: Reply with quote
Unfortunately its probably the coolant fittings on top of the engine. Its a common problem on the 997tt, the elbows are plastic and split and fittings around the water pump can leak.
I just had mine all welded and replaced the elbows with sharkwerks metal ones.
If it is that, send me a PM and ill tell you where I got it done for a very reasonable amount.
09 997tt - Build in progress
79 911 targa
Turbojim997
PostPosted: Sun Apr 28, 2019 8:17 pm    Post subject: Reply with quote
As above likely to be the elbows, so annoying s £5 part is such a ball ache to change.
I did mine last year but couldn’t warrant the expense for the sharkwerks ones when the original ones had done 75k. It’s not a difficult job but is time consuming. Quite a few little coolant hoses worth doing whilst in there as the whole inlet manifold has to come off.
Depending on where you are based I know someone who would be happy to do them.
2000 996.1 GT3 - second 911
2008 997.1 Turbo - first 911
2015 Discovery 4 - Truckasarus2
2015 VW Golf GTD
kozzi
PostPosted: Mon Apr 29, 2019 4:54 am    Post subject: Reply with quote
Thanks for the replies. I am In Suffolk and will get my indi to do it I reckon. Need to go in for aircon rads and turbo hoses and GT2rs inter oilers anyway.
Many thanks
drabux
PostPosted: Wed May 01, 2019 8:35 pm    Post subject: Reply with quote
Agree with the above. I had this problem. Engine out job and now £2k lighter. Sorry.
2008 Porsche 997TT
2007 Mazda 6 Derv
1977 Saab 99 with 900T engine and 9-3 Trionic engine control
Turbojim997
PostPosted: Wed May 01, 2019 10:05 pm    Post subject: Reply with quote
£2000!!! What else did you have done whilst they were in there?
2015 VW Golf GTD
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu May 02, 2019 5:48 am    Post subject: Reply with quote
By the time the engine has been out and back in again the labour clocks up. Ican believe the £2k figure.
Turbojim997
PostPosted: Thu May 02, 2019 7:17 am    Post subject: Reply with quote
It really doesn’t take very long to take the engine out of a 911, probably the most fiddly job of swapping the elbows is stripping the bits off around the inlet. At £2000 you must be paying about £100 labour?
2015 VW Golf GTD
