997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
Slippydiff
PostPosted: Mon Mar 04, 2019 11:54 pm    Post subject: REDUCED !! JRZ 12-31 3 way adjustable dampers 996 GT2/GT3/C2 Reply with quote
SOLD
crash7
PostPosted: Tue Mar 05, 2019 12:54 pm    Post subject: Reply with quote
I run these and can echo the comments on them being about as good as it gets!
Customer service from the guys in the Netherlands is excellent and Ian Gardiner can service / rebuild if required
http://www.igracing.co.uk/dampers.html
Good luck with the sale Thumb
Slippydiff
PostPosted: Wed Mar 06, 2019 2:03 pm    Post subject: Reply with quote
Thank you C7 !!
The JRZs are hugely impressive, and if I didn't have the Ohlins with their road biased spring rates and valving on the shelf, I'd definitely keep the JRZs.
Slippydiff
PostPosted: Thu Mar 14, 2019 10:25 pm    Post subject: Reply with quote
Bump. Price reduced.
Slippydiff
PostPosted: Sun Mar 24, 2019 6:39 pm    Post subject: Reply with quote
Bump.
These will also fit 996 C2 Mk1 and Mk2 when used in conjunction with the correct anti roll bar droplinks and either OE 996/997 GT3 front top mounts or aftermarket items form the likes of Tarett :
https://www.tarett.com/items/996-997-products/996-997-991-suspension/996-997-991-monoballs~bushings/996-986-front-camber-plate-set-996fcplta-detail.htm
Slippydiff
PostPosted: Mon Apr 22, 2019 9:48 pm    Post subject: Reply with quote
Slippydiff
PostPosted: Mon Jun 10, 2019 10:52 am    Post subject: Reply with quote
BUMP Price reduction.
Slippydiff
PostPosted: Thu Aug 29, 2019 2:02 pm    Post subject: Reply with quote
SOLD
