997 : 2004- 73
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Apr 12, 2019 4:39 pm    Post subject: Dash vent removal help Reply with quote
Hello all
After a bit of help with dash vent removal, please.
One of mine has an issue with the direction tab adjusting the vanes vertically, not horizontally, I guess its somehow disconnected.
Q1
Anyway, having done the tricky bit of pulling the metal tabs down and pulling the vent out, I'm struggling to undo the tiny electrical connector for the light. It doesn't help there is 2.5mm of slack on the cable, but can't help that.
Q2
The fix - For those who've done this, how have you resolved it ? Is it a case of simply glueing it back together
TIA
997.1 Seal Grey c2s manual, ltt, mobridge, zunsports, Carrera S IIs (summer)
timbo1811
PostPosted: Fri Apr 12, 2019 5:30 pm    Post subject: Re: Dash vent removal help Reply with quote
jonno_ wrote:
Hello all
Q1
Q2
TIA
Hi, cant help with the connectors, but I have the same problem with the vent, however, I haven't managed to get as far as you, whats the trick to getting the vent out, I'd be grateful for any info.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
jonno_
PostPosted: Fri Apr 12, 2019 7:10 pm    Post subject: Reply with quote
Hi Tim
If you look through the vanes, the top of each vent has 2 x metal loops.
Using a strong pick or small flat-bladed screwdriver you pull both downwards simultaneously, and using your 3rd and 4th hands (!) pull the unit horizontally from the dash.
Don't use to much force or you'll damage the small electrical cable, which is the bit I'm struggling to undo.
There are some pictures on the web, flat 6 online iirc.
Hth
Jon
PostPosted: Fri Apr 12, 2019 7:31 pm    Post subject: Reply with quote
I know the connector very well i'm afraid .. it's used in many different places on the car and it is a pain ..
Look on the flat side each side of the connector .. you are looking for a tiny square hole with a dimple in the middle .. that's the lock ..
use a watch makers screwdriver or a small right angled pick ..
Slide it under the lower connector and toward the dimple .. you only have to lift it slightly for it to unplug so don't go mad Smile
The veins often unclip and can be re assembled but if any of the retaining clips have snapped off then its a new vent im afraid .
timbo1811
PostPosted: Fri Apr 12, 2019 7:34 pm    Post subject: Reply with quote
jonno_ wrote:
Hi Tim
Hth
Jon
thanks jonno
jonno_
PostPosted: Fri Apr 12, 2019 7:47 pm    Post subject: Reply with quote
Thanks VM Iain, much appreciated .
jonno_
PostPosted: Sat Apr 13, 2019 5:11 pm    Post subject: Reply with quote
By way of an update.....
The easiest way of tracking this job is, imo, to leave the units in the dash and carefully remove the vanes.
If you gently lever them out (starting from the side without the adjuster wheel) you can fully remove them from there and then replace. This seems much easier than the '4 handed' task of getting the whole unit out.
I am, though, missing 2 of the plastic 'forks' that fit on the reverse side of the vent angle adjuster, don't suppose anyone has any bright ideas on those?
It's fully how the small jobs can take nearly as long as the major ones!
Barneybee
PostPosted: Sun Apr 14, 2019 1:47 pm    Post subject: Reply with quote
This is a reply I wrote back in 2012 to the same problem on Boxanet, when I had a Boxster.
Its quite difficult to remove the vents. When two of mine went I used a pair of locking forceps to guide the actuator home. You should find it floating around inside the vent somewhere, they tend not to break but just come out of their slots. It is a bit of a struggle with lots of patience and even more swearing!!! I thought about using glue but with super glue and the time it takes to insert the end I would have probably stuck it to some other part inside the vent! This was 3 years ago and they are still there thumbsup
I also did the same on my 997. It takes a lot of patience! but it does work.
You just need to locate the vane in the vent assembly and fiddle it into the right location. You may be able to spot some glue on it but I never bothered as they were a tight fit.
Hope you have some success.
Never drive faster than your Angels can fly!
Current 16 Disco Sport
Sold 62 RR Evoque Prestige
Sold 05 Boxster S, 07 997 C4S Cab
jonno_
PostPosted: Sun Apr 14, 2019 4:40 pm    Post subject: Reply with quote
Cheers Barney, it does help, thanks.
/Off topic
Is your avatar pic at the gliding club on Long Mynd? A beautiful spot if so!
Cool
