997 : 2004- 67
Boxster : 1997- 31
hopeydaze
PostPosted: Tue Apr 09, 2019 12:20 pm    Post subject: Reply with quote
Counter Of Beans wrote:
Shown as sold on Williams Crawford's website.........did you buy it, OP?
Crawford’s has another 993 C4 for sale. The new ones in Arena Red and looks good in the photos. Too cheap so far as I’m concerned at 85k miles and under £50k.
crypticc
PostPosted: Tue Apr 09, 2019 12:38 pm    Post subject: Reply with quote
9xxnick wrote:
crypticc wrote:
Needle at max. Hence is temp gauge issue rather than cooling related? Surely engine woukd have siezed otherwise
Agreed, so long as the needle goes to maximum immediately when the ignition is switched on, in which case I presume the sender is defective (short to earth?).
Probably not wildly expensive to sort, but you would expect it to be properly fixed before sale.
It did and it will be. I didn't realise but thanks for confirming
And to next post I did with conditions
tim993
2016 Porsche Boxster 981
PostPosted: Tue Apr 09, 2019 1:33 pm    Post subject: Reply with quote
tyinsky wrote:
I just bought a handful of those nipple things at the price Tobesetc was quoted! PC
Macadamia type. I always go for monkey nuts Thumb
Looks like the boot was overfilled or as you surmise something stuck as they tried to close it.
Compressor would be least of my concerns, it's when you have to change the evaporator and the 10+ hrs of labour cost for a £100 part Rolling Eyes
That said Crawfords are not know for selling turds rolled in glitter what
Agree with Zingers on this. On any 993, I'd certainly want to know when the evaporator was last replaced. Also, I've not seen bargain £100 units - isn't it more like £300+ from an OPC? Unfortunately (!) it's fairly easy to use one of the commercial 'leak stop' additives and a fresh re-gas to get an a/c system running nice and cold to 'pass a cursory inspection'. But it is just putting off an inevitable and large bill. Another thing I've found is that rear top mounts are not cheap and are an expense some would happily avoid. On the plus side though, a 993 which has been properly maintained is a joy to drive and the best maintained examples appear to hold their value quite well.
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
9xxnick
PostPosted: Tue Apr 09, 2019 5:34 pm    Post subject: Reply with quote
The NRF units are fine so far as I can tell, and are about £75 or so. Time will tell, but mine's been in for a couple of years now and no problems to date.
Oddly enough, the OEM Behr unit I previously fitted to replace the original condensor failed within 3 years, and the replacement for that was an NRF unit too, which came recommended from the well respected Porsche independent's aircon guy, so I feel reasonably happy with my selection.
There are some upmarket units available from a US company, but they are quite expensive and possibly a little OTT for UK weather. They do look nicely made though and would hopefully be ultra-reliable.
Luddite
PostPosted: Wed Apr 10, 2019 12:50 pm    Post subject: Reply with quote
Crypticc, seems like you are somewhat skilled and thorough relative to your inspection processes, admirable indeed. I do wonder in general just how perfect Porsches of this age are expected to be relative to the possible realities..? I suspect if on balance the priorities are investing more than driving enjoyment then it would seem that the importance of ZERO accident damage may indeed figure highly on the list of priorities..? If one intends to partly use a Porsche then it seems that the responsibility of protecting one`s investment may just have the potential to dilute the real enjoyment of the very special and different driving experience that a Porsche can provide.
There are those who can derive enjoyment of their Porsche by it`s mere existence in the garage and may never or rarely take it out on the road which in terms of investment may work out rather well.... each to their own.
I bought my present "classic" car from a garage owner with specialist knowledge in the marque who stripped all of the body chassis and ancilliaries and refinished it to a higher standard than the original finishes using stainless steel fixings wherever possible and paying special attention to all the usual problem areas of which he had gained knowledge of over many years with a view to extending the machines longevity..... which has indeed proven it`s worth over my circa 16 years of ownership...
The chap who rebuilt what was his car at the time did use it for at least one trip to France though given how much time effort and money he must have put into the machine perhaps caused him to cringe every time a stone hit the paintwork.... I don`t know for sure.
Me, I have used my car on trips to Southern Europe and as a result it has gathered signs of usage..... In terms of investment potential... it has arrived at the stage where I feel it owes me nothing given the enjoyment it has provided over many years of ownership, though admittedly has perhaps only covered circa 25k miles in that time... hmm!
As is my habit I have rambled on a bit though the misalignment you highlighted in the bonnet and the drain channel may well have been caused by someone forgetful like me working in the frunk and having placed a screwdriver in the drain channel as a handy place, forgot to remove it prior to lowering the bonnet, which would also explain why the lip of the drain channel was deformed to the extent shown in your pic... Question
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Wed Apr 10, 2019 12:55 pm    Post subject: Reply with quote
Luddite wrote:
...I have used my car on trips to Southern Europe and as a result it has gathered signs of usage..... In terms of investment potential... it has arrived at the stage where I feel it owes me nothing given the enjoyment it has provided over many years of ownership...
Love using mine. Could not care one bit what it is worth down the line. Would be wonderful if I manage to get to 300,000 miles before they ban petrol cars or death (whichever comes sooner)
nickjonesn4
PostPosted: Wed Apr 10, 2019 2:04 pm    Post subject: Reply with quote
Funny I had almost the exact conversation with my mate this morning.
1996 Carrera S Vesuvius Metallic
2016 Golf R
2005 AMG E55K Wagon
crypticc
PostPosted: Wed Apr 10, 2019 6:40 pm    Post subject: Reply with quote
Thank u
And WC are being thorough in addressing each of my concerns. New photos (that I should've taken myself). SpareWheel and battery out to show no structural damage inside. (I forgot the battery). Wheels all off and inspections on the more structural areas of the car. Already had when, I think front bumper coming off too... And will have photos at that point of the whole underside. New venturi will be installed when it's all put back together.
So to be clear I've no concerns currently with how I'm being treated - maybe I'm being a nervous ninny
crypticc
PostPosted: Tue Apr 30, 2019 7:35 am    Post subject: Brief update Reply with quote
Hi
This is a post to update.
Concerns addressed :
Bonnet alignment done and with video.
Front and wings dismantled to show no underlying damage
Under tray repainted while there as was concerned for a scrape.
The only thing that shows is of dirt and perhaps someone overtightened one of the fan shrouds.
Oil sensor contacts cleaned (want to get description of how that'll help although I guess an earthing fault might be that)
Rear brake pipes
Gear shift gaitor clips.
Tiny amount of rust in bottom of door jam sorted. Taken back to metal.
They're forgotten to correct the paint on the roof.
I also chated with previous owner who advised its okay (he used it in for a 996 turbo). The only thing I'd missed was apparently aircon high stops working. He also said clutch was mentioned and was a negotiating point on his sale. (the clutch is only few thousand miles old)
Photos of front end below
Payment due though will be looking for written assurance on oil sensor and aircon and clutch will be covered by their warranty if they return, and then get a post purchase inspection.
Chris
Luddite
PostPosted: Tue Apr 30, 2019 9:37 am    Post subject: Reply with quote
Interesting update, I suspect that your inspection regime far exceeds anything I was ever involved with over more than 50 years of buying transport, but then I was rarely buying into the idea of investment potential, or re-sale value as a priority.
From all you type it seems you have confidence in the machine, it`s history and perhaps more importantly it`s capability to provide you with confidence in it`s purchase... I do hope that it brings you all that you would hope for in whichever way you choose to enjoy your Porsche....
Each to their own when it comes to deriving enjoyment from their cars, and as I typed it seems all too easy to become a slave to a machine, though my personal ideals determine that the machine exists to be a slave to my desires of it .... (-:
My old car was as perfect as one of it`s type could be when I bought it given the processes applied to make it so, it even won a concours trophy at an event I did not enter it into as it sat in the hotel car park while attending a marque weekend gathering in the Lakes some years back...even though the first day I had it home I had driven it up an unmade road with stones flying everywhere, preferring to get IT over with, as opposed to feeling the equivalent of death by a thousand cuts each and every time a stone hit... Check out the attached pic of a back-road we travelled while touring parts of Spain a few years back.... I suspect the tyres kicked up a stone or two on that trip which was just one of a many exploring back-roads in a few different countries over the years... Returns on the investment..?? You bet.. I even have loads of pics to look back on and enjoy from those trips.... (-:
I am just about to go out into the garage and continue the rather too slow re-commissioning process of my old car after too many years off the road, it is jacked up on axle stands and surprisingly the underside is not scarred to bare metal, the paint is still looking good, a tad dusty but no real damage.... which would seem to suggest that good quality workmanship can take on the rigours of the road and if maintained well enough and can continue to do so for longer than some might imagine..? Such was the design and quality of Porsche as I came to know them as ever being quite special, compared with all the other older cars I had CARnal knowledge of over many years... (-:
Keeping my fingers crossed all goes as well as you might hope. Thumb
 Filesize:  439.57 KB
 Viewed:  2404 Time(s)
crypticc
PostPosted: Tue Apr 30, 2019 6:20 pm    Post subject: Reply with quote
Pictures Inc touching in some scrapes (not as good as respray but I wouldn't expect for that)
They've attached in reverse order for some reason. The top photos are post reassembly
 Filesize:  292.61 KB
 Viewed:  2348 Time(s)
 Filesize:  83.45 KB
 Filesize:  353.23 KB
 Filesize:  299.6 KB
 Filesize:  288.65 KB
 Filesize:  294 KB
 Filesize:  223.85 KB
 Filesize:  358.56 KB
stichill99
PostPosted: Tue Apr 30, 2019 6:48 pm    Post subject: scabs Reply with quote
The bottom edge of front wings where they meet the bumper look quite scabby.They could probably do with a sandblast and paint.
crypticc
PostPosted: Tue Apr 30, 2019 7:10 pm    Post subject: Re: scabs Reply with quote
Yeah. Those was to put my mind at ease structurally and the chip coating because it had been done b4 but with bumper on. Didn't think I'd be able to negotiate as I saw more. On balance got to see more up front probably than a ppi.
Luddite wrote:
Interesting...,.
@luddite.. basically went through the jackals list like a checklist.
P.s. is that a Morgan?
Luddite
PostPosted: Tue Apr 30, 2019 7:39 pm    Post subject: Reply with quote
Good set of pics, nothing really jumps out at me. Fine looking machine.
Yup old +8 Morgan.
crypticc
PostPosted: Tue Apr 30, 2019 10:42 pm    Post subject: Reply with quote
Dance Thumb
crypticc
PostPosted: Sat May 04, 2019 6:29 am    Post subject: Mine now Reply with quote
Hi
Mine now and first drives done.
First observation= right purchase. Oil pressure nice and high and engine right (to my informed layman's opinion). Suspension settles well, which surprised me with OE style shocks.
Questions=
1) Oil temperature does it's up and then down thing before it settles once up to temperature. But it settles quite low at 1/4 when driving around. It was cooler last night and of course no traffic.
(Update: daytime and traffic raised temp and I could hear the fan kicking in at appropriate times like on the first test drives)
Niggles=
A) I think they've dislodged an earth for the backlight for the oil pressure/temperature when 'cleaning the contacts for the gauge itself)
B) As predicated by previous owner the OE CD player makes occasional noise like trying to load a disc even when turned off and display is dark. Actually putting a disc in sorted that out both when playing and not. So that's taken care of - I don't think previous owner mentioned that it could be fixed so easily.
C) I'd agreed a full tank of petrol. Arrived with quarter.
That's it. 😁
Counter Of Beans
PostPosted: Sat May 04, 2019 9:09 am    Post subject: Reply with quote
That C4 looks nice. Why do you say it's too cheap - do you just mean "it's a bargain"?
I'm Mike and I count beans for a living.
crypticc
PostPosted: Sat May 04, 2019 11:21 pm    Post subject: Reply with quote
crypticc wrote:
pictures
The rubber seals lookin uneven turned out to be that clearly someone had leant on the them. I just pulled them onto the seams sorted that out.
crypticc
PostPosted: Sat May 04, 2019 11:25 pm    Post subject: Reply with quote
It was a bit of a dilemma this morning though after fetching the car from the garage... Big car or little car
 Filesize:  1.27 MB
 Viewed:  2015 Time(s)
crypticc
PostPosted: Sun May 05, 2019 9:31 am    Post subject: Reply with quote
Look at the photos more closely. Wink. It's an honest car and honestly presented but wasn't for me.
P.s. I updated my OP as link started to point to this arena one.
Goto page Previous  1, 2, 3  Next
Page 2 of 3
