997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
P911X50
PostPosted: Wed Apr 03, 2019 1:50 pm    Post subject: Fitting turbo actuators Reply with quote
Hi
It seems one of my actuators rods has broke. I have bought a set of Porsche actuators and I am considering fitting these myself. Is this a good idea or should I leave this to an Indy?
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
Mac996t
2004 Porsche 996 Turbo
PostPosted: Wed Apr 03, 2019 4:29 pm    Post subject: Reply with quote
If you don’t have any corrosion issues then they are easy to fit however they also need to be set up correctly which requires a pressure tester.
The corrosion issues could be that the two mounting bolts may be seized into the turbo cover and may shear.
Another problem can be getting the rods out of the pivot on the wastegate arm.
The pipe to the actuator body is also a very tight fit.
Once you’ve managed to fit the actuators they need adjusting with a pressure pump so that with 0.5 bar applied the rods have moved by 4mm from the fully shut position, you achieve this by adjusting the nuts either side of the pivot and obviously both sides need to be exactly the same so each turbo does the same amount of work.
Also those settings are for a standard turbo, don’t know if an X50 is different!
Mac
Mac996t
PostPosted: Wed Apr 03, 2019 4:36 pm    Post subject: Reply with quote
Ps quite a few people have repaired their original ones by either welding a new bit of rod on or fitting a threaded collar!
cheshire911
PostPosted: Thu Apr 04, 2019 5:25 pm    Post subject: Re: Fitting turbo actuators Reply with quote
P911X50 wrote:
Hi
Personally, I'd have them fitted by an indy specialist. They require calibration, they are not the easiest for access without a ramp to stand under the car.
996 2002 X50 Turbo Manual
sinky
PostPosted: Fri Apr 05, 2019 4:10 pm    Post subject: Reply with quote
Made this up when i replaced one of mine[/url]
 Filesize:  918.1 KB
 Viewed:  783 Time(s)
ok51mon
PostPosted: Thu Apr 18, 2019 7:20 am    Post subject: Reply with quote
Just buy a vacuum gun
4.1L Incoming
ok51mon
PostPosted: Thu Apr 18, 2019 10:13 am    Post subject: Reply with quote
Or borrow mine, providing you send it back Floor
4.1L Incoming
