997 : 2004- 67
996 : 1997-2005 34
Boxster : 1997- 21
Cayenne : 2003- 3
kingroon
PostPosted: Mon Mar 18, 2019 9:24 am    Post subject: Reply with quote
cont.
Weight Saving & Horses Released, so a Win Win in my Book..
Top Tip, remove the Fan Shroud and attach to the Bypass Pipe, then install the two together.. Way easier.
 Filesize:  164.22 KB
 Viewed:  1966 Time(s)
 Filesize:  246.25 KB
 Filesize:  158.54 KB
 Filesize:  191.13 KB
H0ME
PostPosted: Fri Mar 22, 2019 2:17 pm    Post subject: OBD Reply with quote
Had my OBD reader from Tore delivered last week. Pleased to report only 3 codes all for air-con flaps and motor as I'd expected. The tool makes it very easy to fix specific problems. A great addition.
1996 993 C2 Tip
adrian993
PostPosted: Fri Mar 22, 2019 10:46 pm    Post subject: Reply with quote
is there a custom set of titanium exhaust bolts that anyone makes which fit the 993 by any chance!?
Endoman
PostPosted: Fri Mar 22, 2019 11:14 pm    Post subject: Reply with quote
This place may be able to help:-
http://www.porschetistuds.co.uk/
speedracer
PostPosted: Sat Mar 23, 2019 4:30 pm    Post subject: Reply with quote
- All original Porsche shifter linkages and plastic bush
- Clutch master cylinder
- Double relay blower
- Distributor cap and rotor
- Oil pressure sensor
'97 Carrera S Schwarz Black/Tan
Millomboy
1997 Porsche 993 Targa
PostPosted: Sat Mar 23, 2019 4:38 pm    Post subject: Reply with quote
MOT.
Oil, oil filters, sump washers, brake fluid, rear brake pads, rear brake discs, brake pad wear sensors, anti squeal shims, gearbox oil and air con re-gas. Plus a set of Tore B led's for the panel in front of the gear stick as a couple of the lights have stopped working.
Ocean blue targa.
The only true freedom, is freedom from the heart's desires. And the only true happiness, this way lies.
Allan E
PostPosted: Sat Mar 23, 2019 6:10 pm    Post subject: Reply with quote
Fitted new front screen outer seal, bargain off eBay, genuine part 99354192500, £40 delivered, awaiting delivery of front bump stops and dust covers from the “Homeland”.
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
kingroon
PostPosted: Mon Mar 25, 2019 9:04 am    Post subject: Reply with quote
I, like many in the South of the UK this weekend, took advantage of what felt like the First Day of Summer [!] and washed the Pig in the glorious Sunshine.. Aqua Waxed 'n' all.. Cool
 Filesize:  394.9 KB
 Viewed:  1592 Time(s)
 Filesize:  416.75 KB
 Filesize:  316.54 KB
 Filesize:  356.02 KB
 Filesize:  392.37 KB
hudat
PostPosted: Sat Mar 30, 2019 7:46 pm    Post subject: Reply with quote
Finished hunting for a GT3 and following completion of front ARB refurb with a recoat and a new set of bushes and clamps, new drop links and a clean up.
I took delivery of a new set of Beru leads, dizi caps, rotors, bonnet strut and a set of wipers of all things.
Stripped out the top and bottom of the engine for access to the leads - fun begins tomorrow - ***** it’s mother’s day...
Maybe next week then Floor
AndyS
PostPosted: Sun Mar 31, 2019 8:51 am    Post subject: Reply with quote
MOT yesterday - passed again Very Happy
Andy
1996 Polar Silver 993 Coupe - AKA 'the money pit'
kingroon
PostPosted: Mon Apr 01, 2019 8:04 am    Post subject: Reply with quote
Not sure I’ll mount this to the 993 as a permanent feature, but had some [stressfully patient!] fun with an exact Arctic Silver colour match wrap on the Rear Centre Section..!
Very RUF I thought.. Cool
What do you think..?
 Filesize:  281.61 KB
 Viewed:  1338 Time(s)
 Filesize:  245.25 KB
 Filesize:  217.82 KB
911livin
PostPosted: Mon Apr 01, 2019 9:22 am    Post subject: Reply with quote
PSS10, RS top mounts, drop links, control arms, replace all bushes Very Happy
kingroon
PostPosted: Mon Apr 01, 2019 9:31 am    Post subject: Reply with quote
Do you have a photo of your RS Top Mounts..? Been thinking about these for my 993..
gunner
PostPosted: Mon Apr 01, 2019 1:30 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=132797
993 C2 Tip Aventura
gunner
PostPosted: Mon Apr 01, 2019 1:32 pm    Post subject: Reply with quote
993 C2 Tip Aventura
Millomboy
PostPosted: Wed Apr 03, 2019 7:41 pm    Post subject: Reply with quote
Lots of fuel and a track day at Spa.
Ocean blue targa.
ch3tman
1995 Porsche 911
PostPosted: Thu Apr 04, 2019 7:46 pm    Post subject: Reply with quote
T-LED kit from Tore/Bergville Smile .
New ambers for the front + new fog light units to match the recently replaced headlight lens.
...meaning clear corners + fog light clusters will be available in a few weeks, if anyone is interested...
Photos | instagram.com/ch3tman
kingroon
PostPosted: Fri Apr 05, 2019 8:23 am    Post subject: Reply with quote
That'll look great, really brighten up the corners..
I went the DIY route and bought Fog Lamp Lenses which I am yet to install to the Fog Units..
Easy Job..? I have a feeling it might not be..
ch3tman
1995 Porsche 911
PostPosted: Fri Apr 05, 2019 3:21 pm    Post subject: Reply with quote
Thanks - I've long admired 993s running ambers on the front Cool.
I would've done the same if I were as DIY-capable as you Laughing.
You may find these links helpful, plenty of pictures to help you on your way...
https://rennlist.com/forums/993-forum/249088-fog-lights-yellow-here-s-a-way-to-make-them-shine.html
http://911uk.com/viewtopic.php?t=130666
Good luck! thumbsup
kingroon
PostPosted: Mon Apr 08, 2019 2:06 pm    Post subject: Reply with quote
Good luck! thumbsup
Awesome, thanks Cool That's next Weekend's activities sorted..!
Goto page Previous  1, 2, 3 ... 123, 124, 125 ... 129, 130, 131  Next
Page 124 of 131
