997 : 2004- 63
Boxster : 1997- 25
Croydon
PostPosted: Mon Mar 25, 2019 4:56 pm    Post subject: BBS LM for 993 Reply with quote
Gents I've found a lot of old posts but I want to ask the questions again sorry as sometimes things change.
Where is the best place to purchase in the UK?
Is the correct sizing for a NB car:
Front 8J x 18" ET 52
Rear 10J x 18" ET 65
Thanks in advance and sorry to annoy if we are going back around in circles again (no pun intended ).
Ian
stuttgartmetal
PostPosted: Mon Mar 25, 2019 6:22 pm    Post subject: Reply with quote
I’m all ears.
You have an S or Turbo ?
I’d love some LMs
Croydon
PostPosted: Mon Mar 25, 2019 6:55 pm    Post subject: Reply with quote
C2 Narrow body
ch3tman
1995 Porsche 911
PostPosted: Mon Mar 25, 2019 7:22 pm    Post subject: Re: BBS LM for 993 Reply with quote
They are the same spec as Speedline RS wheels, so you shouldn't have any issues running them on a narrow body - I run the same size wheels without issues. You could push to 8.5J on the front if you wanted...
Pics in the meantime... Cool
..and this car below is just stunning...
Photos | instagram.com/ch3tman
cableguy
Watkins Glen
PostPosted: Mon Mar 25, 2019 8:51 pm    Post subject: Reply with quote
^^^^ The Speed Yellow car is running BBS E88's not LM's. Much nicer wheel IMO. Thumb
C.
Pork!
Gazc2
Watkins Glen
PostPosted: Mon Mar 25, 2019 8:58 pm    Post subject: Reply with quote
Try Tom he had a set for sale think he still has them (Tp81 on here )
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
cableguy
Watkins Glen
PostPosted: Mon Mar 25, 2019 9:32 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?p=1298824&highlight=#1298824
Wrong offsets for NB.
C.
Pork!
Croydon
PostPosted: Tue Mar 26, 2019 7:24 am    Post subject: Reply with quote
C.
That was my follow up question regarding whats best for use on the road as again there is conflicting info out there, LM or E88.
Appreciate the info above chaps.
CarraraWhite
2011 Porsche 991 Carrera
PostPosted: Tue Mar 26, 2019 8:03 am    Post subject: Reply with quote
Croydon wrote:
C.
LM for the road
E88 is a motorsport wheel, but can be used on the road
991Turbo, dont need the S
stichill99
PostPosted: Tue Mar 26, 2019 12:45 pm    Post subject: BBS LM Reply with quote
Mine are 8.5 on the fronts and are spot on with the offsets as above.
 Filesize:  202.63 KB
 Viewed:  4564 Time(s)
andyobro
PostPosted: Wed Mar 27, 2019 11:38 am    Post subject: Reply with quote
Please stop posting pictures of LM's. Making me want to get some toooo much.
993 Carrera
www.instagram.com/993andy
Croydon
PostPosted: Wed Mar 27, 2019 11:55 am    Post subject: Reply with quote
GROUP BUY!!!! LOL
Jet Jock
PostPosted: Wed Mar 27, 2019 9:21 pm    Post subject: Reply with quote
Croydon wrote:
GROUP BUY!!!! LOL
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, FD Motorsport SSK and Golden Rod, MPL Clutch Slave Cylinder, HID conversion...
instagram.com/bazzer_a
tp81
1997 Porsche 993 Carrera 2S
PostPosted: Wed Mar 27, 2019 9:46 pm    Post subject: Reply with quote
I really must sell these, insane to have them sitting about. They haven't been used since they were refurbished. None of my cars will take these and I have gone older now so no chance in the future.
Here is why I won't be needing them, different era but a good wheel is a thing of beauty. Cool
1973 911E (restoration project)
1975 2.7MFI
1995 993 RS
2013 110 Defender
2018 Panamera Hybrid
tp81
PostPosted: Wed Mar 27, 2019 9:55 pm    Post subject: Reply with quote
This has got me looking through old pictures.
1975 2.7MFI
1995 993 RS
2013 110 Defender
andyobro
PostPosted: Wed Mar 27, 2019 11:28 pm    Post subject: Reply with quote
Stop it 🥴 WB fitment only I'm guessing?
993 Carrera
VB911
PostPosted: Fri Mar 29, 2019 2:08 pm    Post subject: Reply with quote
I agree - BBS LM's look perfect on a 993 . I spent a very long time sorting a set for my nb C2 . The sizes you state fit just fine without issue as I did have a set of 996 sport classics on my car previously in those sizes.
I personally am not keen on the flat look the BBS LM in this size give - together with the difficulty I had finding some that size for a reasonable price.
I bought a secondhand set 8.5x18 et56 fronts / 10x18 et 50 rear . They were fine on the front but the rears rubbed . I looked at rolling arches and altering camber angles but wasn't keen on either option . In the end I sent them to TT Tools in Chelmsford. They plugged the stud holes , machined off 10mm from the rear face of the centres and then remachined the holes . This effectively gave me an et of 60 . I run Bilsteins set at -30mm and have no issues with rubbing or clearance and and very pleased with the results .
The fronts I have since reverse mounted which makes around 14mm difference I believe so have an et of 42 on the front - again with no issues .
Hope this helps .. as it may open up some options for you
VB911
PostPosted: Fri Mar 29, 2019 2:10 pm    Post subject: Reply with quote
This photo is with the fronts reverse mounted
 Filesize:  133.53 KB
 Viewed:  4197 Time(s)
VB911
PostPosted: Fri Mar 29, 2019 2:12 pm    Post subject: Reply with quote
and these shows the centres after machining
 Filesize:  86.12 KB
 Viewed:  4190 Time(s)
 Filesize:  79.67 KB
stuttgartmetal
PostPosted: Fri Mar 29, 2019 2:52 pm    Post subject: Reply with quote
Shoulda just took of a half inch with a grinder
