997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
stuttgartmetal
PostPosted: Sun Mar 24, 2019 7:50 pm    Post subject: Bleeding power brakes Reply with quote
Any good tips or a follow step guide
1996 C4S with ABD ABS Power Brakes
How’s it done.
I have that globe up by the fuel tank.
Look at the fluid coming out of it. Grin
 Filesize:  836.57 KB
 Viewed:  1423 Time(s)
stuttgartmetal
PostPosted: Mon Mar 25, 2019 6:31 pm    Post subject: Reply with quote
Not so long ago, I’d have had an answer.
How do you bleed power brakes from dry ?
I have an intermittent ABS and ABD warning light showing.
I can flip the ignition off/on and it goes out for a short while.
I recently had the four calipers refurbished, and changed brake fluid at the bleed nipples on each separate one, starting at rear right.
I never knew about the globe.
I’m guessing I must have to change the fluid again, starting at the globe.
Any advice ?
ras62
PostPosted: Tue Mar 26, 2019 6:19 pm    Post subject: Reply with quote
Link to Rennlist post 7 details the job
https://rennlist.com/forums/964-forum/672389-c4-brake-bleed-hydraulic-system-bleed-procedure.html
stuttgartmetal
PostPosted: Thu Mar 28, 2019 6:37 pm    Post subject: Reply with quote
Eye thank yew.
andyobro
PostPosted: Fri Mar 29, 2019 11:44 am    Post subject: Reply with quote
Wow, rather man milky Floor
993 Carrera
www.instagram.com/993andy
ras62
PostPosted: Fri Mar 29, 2019 1:00 pm    Post subject: Reply with quote
I think a test of the ABS system is in order on the first damp/wet drive. The internals of the pump seize if not exercised.
