996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
heed
PostPosted: Sat Mar 23, 2019 9:36 pm    Post subject: Quick check on a couple of photos? Reply with quote
Looked at a C4S today. Car looked good. Needs a new exhaust, but seller let me know that beforehand so no big deal.
Nothing of any concern when I looked at the car, but there were a couple of tiny things I wanted to check.
Water was dripping out a joint in the exhaust. I assume it's just a knackered joint, and would be resolved when new boxes were put in?
Only other thing was that there was a bit of weird bubbling on both arches. Is this common, and what causes it?
thecarfixer
PostPosted: Sat Mar 23, 2019 10:03 pm    Post subject: Reply with quote
Water vapour out of that exhaust joint is normal.
The bubbling on the arches is the stone chip, the first pic looks like there's some rust on the bottom of the arch, above the sill..?
Griffter
PostPosted: Sun Mar 24, 2019 7:44 am    Post subject: Reply with quote
As above, the “bubbling” on the lower section (the end of the sill) is a rubberised coating under the paint to protect from stone chips. Unfortunately the wings didn’t receive this so the bubbling on the upper section (the edge of the wheel arch on the wing) is bubbling due to rust where the paint has been broken by stones chipping the paint. It’s not bad though and can be easily rubbed down, protected and painted.
heed
PostPosted: Sun Mar 24, 2019 8:13 am    Post subject: Reply with quote
Great. Makes sense. Thanks, both.
996mike
PostPosted: Mon Mar 25, 2019 9:45 am    Post subject: Reply with quote
Just a thought it may be worth checking your exhaust I have a
996.1 c2 year 2000 the joints had gone and assumed I needed a
New exhaust investigated new but was not happy with the sound
Current system is a factory fitted PSE with a epic sound so looked at repairs found a company that wielded in new flex is for £200 massive saving on a
New system plus in my view a much better sound 👍🏻
 Filesize:  1.12 MB
 Viewed:  509 Time(s)
heed
PostPosted: Mon Mar 25, 2019 10:05 am    Post subject: Reply with quote
Interesting, thanks Mike. To be honest though the seams looked liked they were going so at some point I expect it would need new boxes regardless.
