997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
segart
PostPosted: Mon Mar 11, 2019 5:15 pm    Post subject: How wide is my 997...with mirrors? Reply with quote
I am a few miles away from the 911, so cannot get a tape measure on it. Here is the question. I am about to move house and need to figure out if the 911 will fit in the garage. The 997.2 c2s is 1808mm wide, according to the spec. But is that with the mirrors or without?
Rick
997.2 Carrera 2S pdk
Ex 996 C4S Manual
PostPosted: Mon Mar 11, 2019 5:17 pm    Post subject: Reply with quote
1808mm is the width of the rump.
I can never remember whether the mirrors stick out wider. I'll go and have a look.
PostPosted: Mon Mar 11, 2019 5:25 pm    Post subject: Reply with quote
That was interesting exercise.
I can't tell you the width at the mirrors but my car is 1852mm wide and the mirrors stick out wider than that. Yours will be the same at the mirror tips as mine.
It's nice to know that if the mirrors fit through a gap the rest of the car will too. That's how I'll remember in future. Very Happy
TB
PostPosted: Mon Mar 11, 2019 5:41 pm    Post subject: Reply with quote
1952 with mirrors - from info in manual.
segart
PostPosted: Mon Mar 11, 2019 6:33 pm    Post subject: Reply with quote
Ok thanks but its not what i wanted to hear!! That gives me 74mm either side as i squeeze it into the garage through the door. Should just be able to get out of the car hopefully. Cheers Rick
Ex 996 C4S Manual
FZP
PostPosted: Mon Mar 11, 2019 6:43 pm    Post subject: Reply with quote
All you need is day light Thumb
Better you than me Surprised
How long before planning permission goes in for a much larger garage? Grin
segart
PostPosted: Mon Mar 11, 2019 6:50 pm    Post subject: Reply with quote
Ha! Snag is i had to go down the back of the sofa to raise the last few quid to finance the move!
Cheers rick
Ex 996 C4S Manual
DucatiRob
PostPosted: Mon Mar 11, 2019 6:55 pm    Post subject: Reply with quote
That is very tight, they do make garages a bit small these days! I have been all over my car recently with a tape measure as I am planning a driveway and garage, width is less of a problem, it’s the fairly steep slope up the side of the house which is causing me headaches to make sure my lowered GT3/Aero front bumper will not be ripped off with only 80m ground clearance!
If it is a single garage you will probably have another 10 - 12” clearance each side once the car is in, some neoprene glued to the wall will be a good idea!
Mercedes CLK DD
Ducati 996
segart
PostPosted: Mon Mar 11, 2019 8:05 pm    Post subject: Reply with quote
Carpet pieces and Gorilla glue at the ready!
First world problems i guess! The new house will be great but the garage is the weakest point. Made worse as i also need to somehow shoehorn my Triumph Sprint ST in there too!
Ex 996 C4S Manual
FZP
PostPosted: Mon Mar 11, 2019 9:54 pm    Post subject: Reply with quote
Post a pic when the mirrors are at the door, Grin
segart
PostPosted: Mon Mar 18, 2019 8:27 pm    Post subject: Reply with quote
So the mission is to get the Triumph Sprint, and the 997 into what is a fairly tight garage as seen here.
[img][/img]
Someone on this board suggested a piece of timber that would stop the car getting too close to the wall on the left side as I backed it in, and another bit of wood to stop the car butting in to the bike.
[img]
[/img]
The garage has a door opening of 2.1M which I think is a standard single garage width. Frankly not enough for wider modern cars, and barely enough to let the 997 go in. I had about 60mm spare overall in width, so a bit more than an inch either side. Not ideal but doable.
[img]
[/img]
Its a bit of a squeeze getting into and out of the car but its ok!
Rick
Ex 996 C4S Manual
monster
PostPosted: Tue Mar 19, 2019 12:59 am    Post subject: Reply with quote
May not be of use - but the mirrors can be folded back manually to give you a bit more clearance - not a particular practical thing to have to be doing mind!
