964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
abcarrera
PostPosted: Fri Mar 08, 2019 7:40 pm    Post subject: I need help keeping it up!!!!!! Reply with quote
Sorry for the click bait but made my inner child smile Floor
On a serious note, the headlights on my car are looking a little yellow and hazy, so I want to give them Some tlc with the DA. My lights have the headlight wash with the chromed plastic dome, what I would like to know is it possible to keep this raised so I can clean under it without fouling the polishing pad on it. Failing that is it straightforward to actually remove the washer part?
Thank you in advance for any advice. Thumb
Current car: 1998 996 C2,LSD, No sunroof, aero kit, sports seats, coil overs.
2002 996 C2, Braid Fuch (ex CLR), Exe-tc coil overs.
Boxster S 2015
BMW 535d Msport remapped 360 BHP 😊
Gone but not forgotten
2005 987 Boxster S
2007 997 Turbo
1990 964 C2 Cabriolet
1995 993 C2 with factory RS rep kit.
1987 911 3.2 Carrera
1982 911 SC
1983 911 SC
1991 944 Turbo
1981 924 Turbo
1991 944 S2 Cabriolet
1981 924 Turbo
1989 944 S2
1981 924 Carrera GT.
Headlight in need of TLC.
 Filesize:  747.83 KB
 Viewed:  792 Time(s)
PostPosted: Fri Mar 08, 2019 8:20 pm    Post subject: Reply with quote
You will have to remove it as its only the water pressure that raises it .
Your going to get wet here .. have someone operate it .. you grab it in the up position , you can see the locking tab and you use a pick tool to move it out and release the top part .. you can remove just the chrome cover or the jet .. your choice .
Chrome cover and its x2 plastic lugs .. easy to unclip and your best bet for what you want to do .
Pickse
PostPosted: Fri Mar 08, 2019 8:39 pm    Post subject: Reply with quote
I removed mine a couple of times.
You can pull the chrome cap up by hand, it's quite stiff but doable.
The chrome cover clips onto the spray jet.
The problem I found was that on the second attempt the chrome part, being aged and brittle, broke the small tabs which clip it into the spray nozzle.
The chrome parts seems not available separately so a complete nozzle at about £37 was my option.
The part diagram is here
https://www.deroure.com/diagrams.asp?TBL=3413&MAK=3&MDL=28&SMA=3&SMO=24&ST=bracket&SC=0
Cheers,
Pickse
2003 Arctic Silver 996 Turbo Tiptronic S
abcarrera
PostPosted: Fri Mar 08, 2019 8:53 pm    Post subject: Reply with quote
Thank you for the advice, I will give that a go, it’s always better with two anyway Friends
Do the lenses need any special coating when they cleaned up? I guess mine just look slightly yellow from 16yrs worth of sun and exposure to the elements.
Thanks again for the help 👍
Boxster S 2015
2005 987 Boxster S
2007 997 Turbo
1982 911 SC
1983 911 SC
1991 944 Turbo
1981 924 Turbo
1981 924 Turbo
1989 944 S2
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Mar 08, 2019 11:07 pm    Post subject: Reply with quote
Are you planning a proper headlight restoration?
I can’t imagine a polish would make much of an impression... the yellowed hazed top layer needs to be removed by sanding with gradually finer grades then use the polish. The 3M kit is excellent.
I think you can spray them with lacquer when done. I didn’t bother, just used UV glaze. They’ve not yellowed again but they do scratch easily if you’re not careful even when washing.
abcarrera
PostPosted: Fri Mar 08, 2019 11:38 pm    Post subject: Reply with quote
Yes I had intended to do the sanding etc, bought a Meguirs headlight product, guessing it just a cutting compound? I will get some of the sealer though. I pretty careful when washin, I had thought of PPPF for them but I don’t think that stops the discolouration. But it’s taken a lot of years for them to look like this so I hope once restored they will be ok for a few years to come.
Thanks for the advice 😊
Boxster S 2015
2005 987 Boxster S
2007 997 Turbo
1982 911 SC
1983 911 SC
1991 944 Turbo
1981 924 Turbo
1981 924 Turbo
1989 944 S2
maldren
PostPosted: Sat Mar 09, 2019 9:54 am    Post subject: Reply with quote
Hi Robert,
What is UV glaze? I tried a google search and got nail polish sealer!?!
thanks
Mike
Mike
EGTE
PostPosted: Mon Mar 11, 2019 9:33 am    Post subject: Reply with quote
Hi Tony,
I did do the 3M kit on the car about a year ago. Bit disappointing they've gotten like this so quickly. Good luck! Thumb
Robertb
PostPosted: Mon Mar 11, 2019 10:55 am    Post subject: Reply with quote
maldren wrote:
Hi Robert,
thanks
Mike
I use this
https://www.amazon.co.uk/GLASS-POLISH-Surface-Sealant-Repellent/dp/B00A3S1RGU
I’ve not noticed any deterioration, even on my daily driver which 3M’d a while ago.
abcarrera
PostPosted: Mon Mar 11, 2019 1:14 pm    Post subject: Reply with quote
EGTE wrote:
Hi Tony,
Thanks for the update. I will have a chat with the chap who details my wife’s car and see what he suggests. It probably due to UV as others have mentioned and possibly just needs a coat of some product to shield it (sunscreen factor 50 😂)
Hope all is well with you and the Evora providing plenty of thrills! Pleased to report your old steed performing perfectly! 👍
Boxster S 2015
2005 987 Boxster S
2007 997 Turbo
1982 911 SC
1983 911 SC
1991 944 Turbo
1981 924 Turbo
1981 924 Turbo
1989 944 S2
TurboRob
PostPosted: Mon Mar 11, 2019 1:32 pm    Post subject: Reply with quote
Same problem with the Hella headlamps sold in to BMW's of a similar vintage - on my M5 I sanded back 400,800,1200 grit then polished with DA and sprayed with a heavy duty lacquer like this :
[img]https://i1.adis.ws/i/washford/204581?$pd_main_v2_H2$[/img]
Anything else never lasted more than 9-12 months before starting to degrade again.
