964 : 1989-1993 5
Boxster : 1997- 18
Cayenne : 2003- 3
Macan : 2014- 1
Zorro
PostPosted: Fri Mar 01, 2019 4:25 pm    Post subject: Headlights (again) Reply with quote
Main beam this time.
I've fitted Tore B's HID dipped beam units which passed an MOT OK and are superb. The only problem is the main beam is pathetic by comparison. I really fancy a LED main beam. I realise this will probably not be OK for an MOT, but they'll just have to get changed for the day. What I would like to know though is which LED bulbs. I know some on this forum have fitted them and are pleased with them, but which manufacturer, degrees K, model reference would be helpful, especially if you are running with the HID dipped beam conversion and know that it all fits. Thanks in advance.
Endoman
PostPosted: Fri Mar 01, 2019 5:40 pm    Post subject: Reply with quote
There are 2 good options:-
1. Swap original projecors for Morimoto https://www.6speedonline.com/forums/993/391490-i-did-bi-xenon-projector-retrofit-993-here-s-what-took.html
Make sure you order the rhd kit!
2. Fit Led highbeams, these are the ones I have:-
https://rennlist.com/forums/993-forum/972122-led-high-beam-mod.html
If you fit the Morimotos use Tores Hids with them not the ones they supply.
Both ways require some internal modification and it's a bit more diifult to get the morimotos in because of the levelling mechanism which they do not have in the USA. You just rotate them slightly to get the frame in and then lock them back. A bit tight but it all fits in the pod.
There is a led highbeam which uses copper braids as a heat sink easier to fit but output not as good.
Bit overkill but I did both, benefit of led highbeam is instant flash.
Zorro
PostPosted: Wed Mar 06, 2019 9:46 am    Post subject: Reply with quote
Thanks for your reply. The Cyclops units look a bit more involved than some I have seen advertised with an extra "box of tricks" as part of the unit and some adaptions required. I was thinking of something a bit more plug and play.
Endoman
PostPosted: Fri Mar 08, 2019 12:47 am    Post subject: Reply with quote
The ones with the braided heatsinks are the easiest to fit and give a reasonable light output but they tend to scatter the light more than the cyclops. All the decent output leds require some sort of heatsink or fan and there's not much room in there.
The Morimoto conversion is not too difficult and is reversible. the beam pattern is quite different to the std. projector with a shrap z-line cut off. You get the benefit of HID highbeam+dip + whatever you have in the main (e.g. Osram nightbreakers). Still retaining instant flash with the main.
Pricey though.
Do not use hids in the main they don't work well in the reflector bowl.
Tbh Toe's kit is ideal for normal driving but if you live out in the countryside a powerful main is very handy.
With the Cycops main beam it gives glaring reflections back from motorway signs but great for night rallies.
A shot of the led main with braided heat sink.
 Filesize:  82.19 KB
 Viewed:  227 Time(s)
